hitower3
777W in cruise - noisy on ground?
Tue Aug 27, 2019 8:37 am
Dear all,
I have the privilege to live in a quiet place in the suburbs of Vienna, Austria.
It happens to me that I am using my telescope in the nearby vineyards at night and I can see - and hear - aircraft flying above my head at cruise altitude. Sometimes, one aircraft is significantly louder than any other plane overflying me and when I look it up on FR24, it is very often a 777-300ER.
While it is pretty understandable to me that airplanes with smaller engines (like the usual bunch of A320 and B737) make less noise, I notice that also aircraft with a similar amount of installed power (B747, A340-600, A350...) appear to be noticeably less noisy than the 777W.
Interestingly, the GE90 engine is renowned to be particularly NIMBY-friendly, a fact that I can confirm when I listen to the Austrian 777-200ER compared to their 767-300ER (PW4000 powered) when they take off from Vienna: the latter being a lot louder in spite of being less powerful.
So this brings me to ask two questions:
- Does anyone notice the same phenomenon when a 777W flies over at cruise altitude?
- What could be an explanation for this "quiet at takeoff, but noisy at altitude" behaviour?
Many thanks & best regards,
Hendric
flipdewaf
Re: 777W in cruise - noisy on ground?
Tue Aug 27, 2019 8:59 am
The 77W has a high wing loading and as a result is often not able to achieve high altitudes at similar flight stages as other aircraft. It may well be louder because its lower and therefore closer to you.
Fred
FlyHossD
Wed Aug 28, 2019 9:46 pm
Fred
That's my thought, too. At heavy loads, the 77W will be at a lower - closer - cruise altitude.
Fred gets the points for the first correct answer.
masi1157
Fri Aug 30, 2019 9:12 am
Flying at FL330 instead of say FL370 would make a 1dB difference. That is the smallest noise difference to distinguish in a direct comparison. But hearing them several minutes/hours/days apart you would not be able to notice any difference at all. The flight altitude surely is not the major reason.
Gruß, masi1157
517 different segments on 101 airlines to 212 airports in 55 countries
flipdewaf
Fri Aug 30, 2019 9:31 am
Gruß, masi1157
I guess its an inverse square law thing (been 11 years since I did the acoustics at uni) so (37/33)^(1/2) = 1.058. Not sure how that equates to dB but I'm sure you are right.
Fred
Fri Aug 30, 2019 12:27 pm
Gruß, masi1157
The 77W is normally starting off lower than that in a long haul. I find the cruise engine noise much louder in the cabin against other wide bodies I have been in.
Also much louder during engine start than other aircraft.
estorilm
Fri Aug 30, 2019 12:49 pm
Interesting thread - most has been covered but I will say, the strange "howl" they make as the pilots advance the throttles to stabilize before TO power is set is VERY distinctive on the 777 (not sure if it's the W or 2, but very distinctive!)
I've worked on the north end of the 3 parallel runways at IAD for 15 years, there's no mistaking when a 777 has taxi'd into position and is about to roll haha (even if it's over a mile away!)
hitower3
Fri Aug 30, 2019 2:36 pm
Thank you for all the answers so far, greatly appreciated!
Wor what it's worth, the distinctively loud noise that I hear on the 777s passing over my head is a frequency-less, deep white noise, so unrelated to the spool-up howl described above. It's really just a deep rumble.
masi1157
Fri Aug 30, 2019 3:14 pm
It is not "^(1/2)" but simply "^2". And the sound pressure level difference is 10*log((37/33)^2) or 20*log(37/33), which is the same.
May be. Let it be FL310 on the B777, while others would fly FL330 or FL350 initial cruise altitude. It wouldn't explain more than 1-2dB difference, which is inaudible if not in direct A-B comparison.
There you would 2 possible explanations, or a combination of both: The engines (incl. the jet noise generated behind the engine) might be noisier and the noise transmission into the cabin might be higher.
That can't be "extrapolated". During engine start the noise sources and noise generation will be very different than in cruise.
We are talking about noise in cruise heard from the ground. As I said, that has other dominant noise sources and generating mechanisms.
The domimant noise contribution heard on the ground will be the broadband low frequency stochastic jet noise.
Gruß, masi1157
Fri Aug 30, 2019 10:21 pm
If you are talking about a 77W at FL310 the A330/A350/A380 would be at FL370 at the same corresponding fraction of actual weight/MTOW.
At MTOW a 77W will only get to FL290 normally, the A350 straight to FL350.
I can tell the sound of a 77W starting if I’m behind glass inside a terminal or even in the cockpit of an aircraft facing the other direction.
masi1157
Sat Aug 31, 2019 8:05 am
That would give 1.2dB and 1.6dB difference. As I said, still below 2dB and inaudible if not in direct A-B comparison.
Maybe, but that doesn't matter in this context. We are talking about the noise emitted in cruise heard from the ground below, not about the noise emitted by starting engines. After travelling 10km down to the ground all the higher frequency content will be gone (by damping in air) and only the low frequency part can be heard, mostly mixing noise of the jet.
Gruß, masi1157
Sat Aug 31, 2019 8:20 am
Gruß, masi1157
I can tell the difference between lots of different aircraft engines as they fly overhead. It is not just the absolute noise levels as they pass overhead, it also depends on the sound approaching and departing.
SQ22
Sat Aug 31, 2019 10:22 am
I agree with you, compared to 772 (PW4077), 77E (RR Trent 892) and 773 (RR Trent 892) I have flown with the 77W is more noisy in the cabin.
Farsight
Sat Aug 31, 2019 5:00 pm
Perhaps due to the 77W higher wing loading there is disproportionally more aerodynamic noise generated in cruise that one would hear from the ground....possible?
masi1157
Sat Aug 31, 2019 6:12 pm
Being noisier in the cabin does not necessarily mean it is also noisier when heard from the ground. It may be a hint, but it surely is not related 1 to 1.
That is surely possible. But I have no idea if it would dominate the noise from the jet mixing.
Gruß, masi1157
BravoOne
Sat Aug 31, 2019 6:43 pm
I have always thought the RR powered -200ER was really noisy in the cabin, even forward of the L2 door. Sounds like a buzz saw and quite unpleasent at times.
masi1157
Sat Aug 31, 2019 6:49 pm
That is called buzzsaw noise (really!) and I am perfectly sure it occurs during climb (on all aircraft, some noisier, some less) but not during cruise. And it will absolutely not be heard from the ground when the aircraft is at cruise level above you (which is the topic here, it is not cabin noise!).
Gruß, masi1157
Strato2
Sun Sep 01, 2019 7:16 am
Indeed. I still have occasional tinnitus from the startup of AF 777-300ER on a flight back in 2011 sitting near the wing.
tomcat
Sun Sep 01, 2019 9:18 am
Gruß, masi1157
The GE90-115 being the most powerfull engine by a significant margin, could it be that due to its intrinsically high air flow, the noise resulting from the jet mixing is simply higher than for any other engine? Also, has the exhaust speed any effect on the low frequency noises?
Sun Sep 01, 2019 11:36 am
My tinnitus got significantly worse after I got married, hardly her anything she says apparently.
masi1157
Sun Sep 01, 2019 7:52 pm
Of course a more powerful engine will -ceteris paribus- generate more noise. I am just not sure if "ceteris paribus" is a useful starting point here. I am also not sure if a B777 really is noisier than other A/C flying overhead at cruise altitude. I could a number of arguments for and another number against it.
Gruß, masi1157
DarkSnowyNight
Wed Sep 04, 2019 8:49 am
I live more than four miles south of LAX. In the quiet hours of the late night/early morning hours, I can clearly hear sound of our nightly sortie of 77Ws and Fs starting up.
It's not intrusive or anything, but if you know what it is, it's unmistakable.
"Nous ne sommes pas infectés. Il n'y a pas d'infection ici..."
mxaxai
Sun Sep 08, 2019 8:24 am
I know what you mean. I sometimes hear faint jet noise, look up, and find the aircraft at cruise altitude. It's almost always a 77W or A343. The volume seems to be weather-dependent; it's most noticeable on clear winter days.
In Vienna, I would suspect that the 77W is from nearby Munich airport.
Users browsing this forum: unimproved and 9 guests
