DrPaul
Winglets and Raked Wingtips — A Couple of Questions
Fri Aug 30, 2019 2:38 pm
Most airliners these days have either winglets or raked wingtips. I have a couple of questions. Why are they a relatively recent innovation, and why were the benefits of fitting them not realised earlier on, when jet airliners were first introduced in the 1950s?
GalaxyFlyer
Re: Winglets and Raked Wingtips — A Couple of Questions
Fri Aug 30, 2019 3:04 pm
Aviation’s conservatism. The idea dates back to the earliest days of flight. Then, in the 70’s, Richard Whitcomb at NASA started experimenting with them. Fuel efficiency was a driver post-73.
https://en.m.wikipedia.org/wiki/Wingtip_device
DocLightning
Sat Aug 31, 2019 5:28 am
In addition to what GalaxyFlyer said, the benefits of these devices are relatively modest, in the range of 5%. So it took a fair amount of research (time) to develop wingtip devices that would maximize benefit while minimizing weight and additional drag. Keep in mind that these devices increase the lift on the outboard section of the wing, so spar strengthening (ads weight) is necessary. Sharp turns between the wing and a nonplanar winglet (like the 744 winglet) cause interference vortices (drag) and all of these devices increase overall wetted area. So careful design was necessary to minimize the added weight and drag while maximizing the additional lift.
-Doc Lightning-
-Carl Sagan
WIederling
Sat Aug 31, 2019 11:49 am
Henschelohren :-)
then you have the Let L-13 Blanik and PZL-101 Gawron
Wingtip tanks / shock bodies go in a comparable direction.
Hoerner Tips
Dr. Sighard F. Hoerner, his work straddles WWII and the post WWII time
Murphy is an optimist
GalaxyFlyer
Sat Aug 31, 2019 1:56 pm
Yes, Hoerner wingtips were used in Part 23 planes long before winglets were tested and used on jets. The Lear 28 Longhorn was possibly the first Part 25 design.
GF
BravoOne
Sat Aug 31, 2019 2:12 pm
It's interesting to note that Delta put winglets on one of their 727-200's and ran it for almost a year as I recall. They decided not to move forward and do the entire fleet as there were concern' that later in the life of the airplane there might be some structural issues passed on the downstream owners and thus legal exposure.
GalaxyFlyer
Sat Aug 31, 2019 2:21 pm
Yes, the structure can be a factor. For example, the less vertical winglets on CL350 can’t be used on CL600 series for structure reasons.
WIederling
Sat Aug 31, 2019 4:34 pm
no strong interest. Design was dominated by keeping the things in the air.
Fuel was a mass/volume limited resource, not money limited. :-)
DrPaul
Sun Sep 15, 2019 3:47 pm
Thanks for the replies.
trpmb6
Sun Sep 15, 2019 3:51 pm
Actually, it's not so much maximizing additional lift but reducing induced drag (a function of lift). Induced drag is reduced by artificially increasing aspect ratio.
DocLightning
Tue Sep 17, 2019 2:25 am
Both planar and nonplanar wingtip devices increase lift on the outboard span. A planar wingtip device, like the Boeing raked wingtip, adds lift outboard of the main span and distributes the overall lift over a larger span, which decreases the overall induced drag. A nonplanar wingtip device (a winglet) increases lift just inboard of the device and helps to move the axis of vorticity above and aft of the main span, which reduces induced drag.
A nonplanar device introduces less overall bending moment on the inboard spar, but it is less structurally efficient. As a rule of the thumb, a three-foot nonplanar winglet will offer the benefit of a two-foot planar wingtip extension, but will only add the bending moment of a one-foot span increase.
-Doc Lightning-
-Carl Sagan
Users browsing this forum: geologyrocks and 25 guests
