yyzmdw
77W vs A35K capacity
Wed Sep 04, 2019 9:16 pm
It's been well documented that the A35K has the same listed capacity as the 77W, in a 3-class configuration, and thus Airbus is pitching it as a 77W replacement. However, that configuration stipulates about 350 or 360 seats in 3 classes. For airlines like AF and AC that have high Y configurations of around 450 seats, with 3-4-3 Y, can the A35K match that capacity?
whywhyzee
Re: 77W vs A35K capacity
Wed Sep 04, 2019 10:19 pm
The two are the same length, with the 77W wide enough to sit 10 abreast on a normal configuration in Y, where as the A35J can only do 9, so no, it cannot match the 77W capacity.
Note the exit limit on the A35J is also 440, where as the 77W is 550.
Look at CX for example, roughly comfortable seat maps, 3 class seats 368, where as the A35J seats 344. The A350 has an extra row of J, so that could be 2 Y, which adds 14 seats, making it a rough apples to apples comparison value of 358.
BoeingVista
Thu Sep 05, 2019 4:38 am
I believe that the exit limit on the A350 is about to be raised to 480, also there was a proposal from Airbus to move lavs and galleys downstairs to raise seat count but as yet Airbus is not formally offering this option.
BV
vhtje
Thu Sep 05, 2019 5:51 am
whywhyzee wrote:
The two are the same length, with the 77W wide enough to sit 10 abreast on a normal configuration in Y, where as the A35J can only do 9...
So much for the A350 being an “Extra Wide Body”
I only turn left when boarding aircraft. Well, mostly. All right, sometimes. OH OKAY - rarely.
Thu Sep 05, 2019 6:25 am
French bee’s A350-900 have a seating configuration of 411 with a 3-4-3 economy configuration.
The exit on the A350 limit depends on the doors the customer selects, it can be less than 440.
The 40J32W296Y 77W is a relative new configuration for CX with 10 across in Y, when the A350-1000 entered service with CX it was 40J32W268Y on the 77W with 9 across compared to the 46J32W256Y on the A350-1000. The A350-1000 can fly further with a full passenger load and lifts about 8 tonnes more at maximum payload.
Armadillo1
Thu Sep 05, 2019 6:59 am
https://aviationweek.com/awincommercial ... stinations
and A339 can have 460, but this still not so common.
so result still the same
350 lighter, can carry more load for range, but have less width for pax.
keesje
Thu Sep 05, 2019 11:09 am
I and many colleagues have been actively avoiding 10 abreast "normal" 777 configurations in Y for the last 5-6 years. (UA, AF, KL). Passenger satisfaction/comfort takes a hit. So it depends on your definition of normal and the airlines. I have choosen Korean, SQ, JAL and Delta 9 abreast 777 flights over other carriers for this reason. Even taking stops.
Boeing supporters and 10 abreast operators have done a lot to learn everybody this 10 abreast 777 is " normal, "new seats", the way forward. Me and many just avoid those aircraft, lots of alternatives these days.
TheRedBaron
Thu Sep 05, 2019 9:31 pm
I am 5´7 and not overweight, I find the 10 abreast 777, simply a torture chamber, since it is used for more than 8 hour flights...
Id gladly pay 200 each way more just for that 2 extra inches
Best Regards
TRB
The best seat in a Plane is the Jumpseat.
AtomicGarden
Fri Sep 06, 2019 1:00 am
Best Regards
TRB
Totally. I'm not long but I am broad shouldered and it SUCKED! people who say it is an insignificant difference are delusional
You killed a black astronaut, Cyril! That's like killing a unicorn!
unimproved
Fri Sep 06, 2019 8:47 am
The 787 isn't much better with 9 abreast.
Blame the airlines, not the manufacturer. If they build a wider fuselage it will get just get another seat squashed in. Even the A330 is now suffering from this.
afterburner
Fri Sep 06, 2019 4:52 pm
I blame the manufacturer. Almost all A330 and A350 operators have 8 and 9 abreast respectively on their economy classes. Most 777 and 787 operators have 10 and 9 respectively. Boeing gives airlines the opportunity they can't refuse: one more seat for every row.
patrickjp93
Fri Sep 06, 2019 5:21 pm
Best Regards
TRB
Yeah rubbing shoulders with your neighbors when trying to sleep on a 15-hour flight is...unpleasant...
unimproved
Fri Sep 06, 2019 9:49 pm
The first 9 & 10 abreast 330's and 350's are already popping up. I wouldn't be surprised if a lot more get "upgraded" to this config on their first D/C04 check (just like what happened to the 777).
afterburner
Sat Sep 07, 2019 4:46 am
I don't think 9 and 10 abreast in A330 and A350 respectively will be the mainstream configurations. Emirates is the pioneer of 10-abreast in a 777. Let's see whether EK will put 9 and 10 abreast on its A330neos and A350s.
Theseus
Sat Sep 07, 2019 8:27 pm
Low cost airlines have used 3-3-3 configurations on A330s for a very long time, and I do not see majors moving to adopt it.
For now, the same kind of airlines are using 3-4-3 on A350s.
I hope it will not get worse (we can never be sure), but so far, the situation seems stable on the A330 and A350 side.
tommy1808
Mon Sep 09, 2019 5:45 am
For now, the same kind of airlines are using 3-4-3 on A350s..
:checkmark: :checkmark: :checkmark:
9-Abreast has been used by some airlines since it is in service, literally as Air Inter as the first Airline to fly it, had it (iirc), and before that, and still, airlines flies A310s in 9AB (maybe A300, but i wouldn´t know who).
On a 9AB 787 or 10AB 777 you have essentially as much seat width as on the 737 that took you to the Hub, with the CRJ wide seat you get on an 9AB A330 or 10AB A350 everyone will notice right away, so it is hard to get away with it as an airline...
best regards
Thomas
This Singature is a safe space......
patrickjp93
Mon Sep 09, 2019 12:47 pm
best regards
Thomas
???!!! Someone has clearly never made that transition, or you're very skinny. On a 737 I don't rub shoulders with the guy next to me. On a 787 or 10AB 777, I do. 0.4" is the average difference between a 737 seat and a 787 seat (17.6 vs. 17.2 on 787 vs. 17.0 on 77W). Air Canada's are 17.3" wide. Singapore purportedly uses 18" wide seats on their 787s, but I don't know if I believe that. Aisles would be unusable.
tommy1808
Mon Sep 09, 2019 1:30 pm
best regards
Thomas
???!!! Someone has clearly never made that transition,.
I actually don´t think i ever transferred from a 737 to a 10AB 777, usually from an F70 or E-Jet :D
But i actually do not mind the 10AB 777 all that much, surprisingly..... but 9AB A310 is one step too far. .... and i am not particularly petite with 1.83m/~100Kg (floating around that) .... i do notice the difference of course.
best regards
Thomas
Sokes
Tue Sep 10, 2019 1:20 pm
You guys have a wrong approach to social life.
Why can't the world be a little bit more autistic?
Strato2
Sun Sep 15, 2019 1:38 pm
Luckily I've only had to take two 77W flights on AF and they were 3-4-3. It was ridiculous that the two and half hour AY A321 flight I took to CDG had an inch wider seats than the AF 77W on a over eight hour trans-Atlantic flight.
DrPaul
Sun Sep 15, 2019 3:22 pm
Yes, I've always thought that the 'extra-wide body' slogan is, well, not exactly honest. The A350 is a bit wider than the A330 and than what Airbus had originally proposed (namely, the same width as the A330), but it's still not as wide as the 777. Perhaps it's time that misleading slogan was dropped.
Mrakula
Sun Sep 15, 2019 6:35 pm
A350 "extra-wide-body" is jaust marketing name to it from distinguish orignal A350. Bussiness jets are not wide as 777 by they are still more confortible! OMG
sabby
Mon Sep 16, 2019 9:50 am
That was a response to "Dreamliner" marketing as well as to distinguish from the original A350 (sort of A330neo). Never trust marketing gimmicks, irrespective of Brands :D
WIederling
Mon Sep 16, 2019 5:29 pm
A350 is wider than A330 and moved up from the established Airbus wide body cross section.
In the Airbus portfolio "wider" is the marque property of the A350XWB.
why would/should it reference the product of another manufacturer?
Then:
What is "dream" quality about Dreamliner? A nightmare ...
Murphy is an optimist
DrPaul
Mon Sep 16, 2019 6:02 pm
Then:
True, but the way the XWB bit was promoted, tagging it proudly onto the A350 name, implied that this plane was a good couple of feet wider than other wide-bodied twin-jets, and not merely a few inches wider than its predecessor and still short of its main rival. Still, I guess that 'Just A Little Bit Wider' isn't the most catchy slogan.
As for the 787, calling anything 'dream' is asking for trouble. The sarcastic rejoinder 'In your dreams...' comes to mind.
Users browsing this forum: No registered users and 21 guests
