Max Q
American Airlines and their mechanical checklists
Mon Sep 09, 2019 3:39 am
Anyone remember these ?
In the days before electronic checklists AA
had ‘mechanical checklists’ in, I believe all
their aircraft
If I recall correctly this consisted of a metal
box permanently mounted in the cockpit with numerous slots on its face, these slots
had a printed checklist item inside them
Each item was ‘ checked off’ by sliding
a lever from one side to the other and on down the list
On three pilot aircraft it was mounted for
easy access by the flight engineer and on two pilot airframes between them
In fact I think I saw such a system in a cockpit photo of a recently retired ‘super 80’
I’ve never seen it on another airlines aircraft, it did seem unique to AA and
a rather clever, visionary system as it’s
design confirmed that necessary actions had been taken by the slide position
Thoughts and observations ?
Guns and the love of them by a loud minority are a malignant and deadly cancer inflicted on American society
longhauler
Re: American Airlines and their mechanical checklists
Mon Sep 09, 2019 3:56 am
Air Canada has/had them on all Airbus aircraft, as well as the 767 and 747 and earlier. The Embraer and 787/777 do not have them. I am not sure about the 737 MAX, but the 737-200s had them.
Similar to AA’s, they were on the glare shield and flipped up. Windows could be opened/closed as items were completed.
I liked them, as it was obvious if an item were completed. Also, per SOP it was the only checklist that did not have to be restarted from the beginning if interrupted.
Max Q
Mon Sep 09, 2019 4:17 am
Interesting, did not know other airlines had them, thanks for that, btw was there any internal lighting for viewing at night in a dark cockpit?
Mon Sep 09, 2019 7:32 am
I'd never heard of this. Very cool.
Max Q
Mon Sep 09, 2019 8:07 am
Great picture, that’s a bit more of an advanced version (looks like a 757) than
versions I’ve seen on 727 / DC10 era
types
Woodreau
Mon Sep 09, 2019 11:48 am
American has them on their 737s, MD-80s, 757/767s, but all the ones I’ve seen are the light up type, like the one in starlions picture. Not ones where there was a paper checklist underneath as you mentioned. As you complete them, you turn off the light and the item goes dark, indicating completion of said item.
I haven’t seen them in AAs Airbus aircraft, probably because AA didn’t acquire Airbus until recently and basically using US Airways Airbus operating procedures for their Airbus procedures and Airbus have their ECAM memo checklists.
It kind of reminds me of the days before soft buttons on today’s touchscreens on a NTDS radar console when there were physical hard buttons (Variable Action Buttons) but as the function of the button changed, the label of the button also changed. The way the label changed was there were 4 light bulbs inside the button with a film with micro lettering which blocked the light and the letters were projected onto the rear of the button. As the function of the button changed, the appropriate light was illuminated within the button while the other 3 light bulbs were extinguished. Nostalgia of 1970s technology.
longhauler
Mon Sep 09, 2019 12:19 pm
Yes, the used the same brightness control as the FCU.
You can see them here on an A319 ...
BravoOne
Mon Sep 09, 2019 2:12 pm
The bad thing about this kind of checklist is that you can't put them in the windows to block out the sunlight:):)
thepinkmachine
Mon Sep 09, 2019 2:21 pm
Seems a bit of overkill to me...
Woodreau
Mon Sep 09, 2019 3:52 pm
Well the pilots have their own paper checklist in addition to the checklist board. After the board is run and all the lights are turned off, the paper checklist is run.
Mon Sep 09, 2019 11:30 pm
We're rapidly moving to paperless with electronic checklists and EFB. No paper at all! But we can always get a newspaper. :)
BravoOne
Tue Sep 10, 2019 1:41 am
Well 8+ years instructing and working with the 787, 777, +4 years flying the 777 says progresshas has its limits:) Just because its possible does not mean its better. Now where did I put that checklist?
shamrock137
Tue Sep 10, 2019 10:59 am
Can't remember the specific one, or it might be more then one, but there were some accidents where a contributing factor was that the flight crew was running a checklist, got interrupted, then inadvertently skipped a step. This was a more effective way of checking that steps weren't missed vs a pilot just holding their thumb on the last line, or trying to remember where they left off.
Time to spare? Go by air!
Tue Sep 10, 2019 12:20 pm
A good trick is to go back one and redo the last step you completed.
Loving the electronic stuff. Less paper all over the place. More synchronisation between the pilots because we literally have access to the same info even when CRM isn't at its peak.
AirKevin
Wed Sep 11, 2019 9:14 pm
Northwest 255 is the first one I can think of.
Captain Kevin
Wed Sep 11, 2019 11:54 pm
A lot of work was done after that accident to improve checklists, even down to layout and fonts.
barney captain
Sat Sep 14, 2019 5:05 pm
I rode in many AA jumpseats back in the day and thought that checklist idea was a pretty good one.
Now, the setting of the altimeters to zero? Not so much......
Southeast Of Disorder
Max Q
Sun Sep 15, 2019 4:27 am
Good point Barney
That was a uniquely AA practice, setting QFE, I think they only did that on the standby altimeter though ?
It may have been a useful technique in pre
radar altimeter days but sticking with it after entering the Jet age was dubious at best
Along with training their pilots to use rudder in wake vortex encounters..
BravoOne
Sun Sep 15, 2019 1:38 pm
Good point Barney
The QFE altilmeter was used at EAL as well but they wisely abandoned the procedure a long time before AA did, and this was way prior to any standby altimeters being around.
longhauler
Sun Sep 15, 2019 3:31 pm
Yes, I recall reading the accident report of an EAL DC-9 at CLT, lost during a non precision approach.
The use of QFE was cited as a minor contributing factor. But even still, I was left wondering what possible use such a practise could be.
I was not aware AAL was still doing this!
BravoOne
Sun Sep 15, 2019 3:56 pm
To be clear, I think AA stopped doing this QFE non sense at least 20+ years ago.
barney captain
Sun Sep 15, 2019 3:57 pm
AA abandoned the practice many moons ago - sorry for the confusion (and thread creep!). And yes, it was all the altimeters set this way.
DmelloMarfi
Mon Sep 16, 2019 3:43 pm
I haven’t seen them in AAs Airbus aircraft, probably because AA didn’t acquire Airbus until recently and basically using US Airways Airbus operating procedures for their Airbus procedures and Airbus have their ECAM memo checklists.driving distance calculator
tu204
Mon Sep 16, 2019 5:40 pm
Tu-154 had it on the FE panel. I think Tu-144 as well. Didn't light up. Just flipped the item over by sliding.
I do not dream about movie stars, they must dream about me for I am real and they are not. - Alexander Popov
Mon Sep 16, 2019 11:01 pm
Maybe semantics, but the ECAM memo is not really a checklist. It is a set of sensed parameters that are displayed, and as part of a checklist they are verified as a group.
Users browsing this forum: downforsam, IFlyVeryLittle, rckstr316, Ruddman, stackelberg, Weatherwatcher1, YYZYYT and 18 guests
