1337Delta764
Airline de-icing standards
Fri Sep 20, 2019 12:54 am
It does seem like different airlines tend to have varying standards for de-icing their aircraft. With U.S. carriers, the airline that seems to the most generous about de-icing is WN, being the only airline with de-icing equipment in MCO and TPA. AA is somewhere in the middle as far as U.S. carriers. DL and UA seem to be more strict; at PHX while DL has deicing equipment it is rarely used even in cold snaps, with DL preferring to sun-thaw their aircraft while WN and AA are de-icing. UA does not have any de-icing equipment at PHX.
Has anyone noticed the differences in de-icing standards between airlines?
Re: Airline de-icing standards
Fri Sep 20, 2019 1:56 am
While there are some detail exceptions, the basic rule is that the aircraft shall be clear of snow and ice. So the "standard" is the same for everyone.
However, operations differ. For example, route structure can play a part. The longer the flight, the more the fuel is cold soaked. Then you land in a humid location and get ice on the wings, even in the tropics. In other words, it can make a difference if most of the flights are 2 hours or 6 hours.
BTW while the application operation looks the same, de-icing is not the same as anti-icing.
GalaxyFlyer
Fri Sep 20, 2019 3:23 am
Presence of de-icing trucks says little or nothing about the standards of their operations. EAL had two de-icing trucks in SJU. It’s the quality of training for crews, flight and ground, and cultural discipline to adhere to standards that matter. It’s been a very long time since a US carrier had an accident due to improper de-icing / anti-icing.
GF
BravoOne
Fri Sep 20, 2019 3:07 pm
Regarding standards, every year about his time as fall approaches, the FAA publishes a deicing standards guidance manual that describes various makes and application standards for operators use. The operator inturn uses this to compile and publish their own deicing guidance for both flight crews and ground applicator use. This is submtted to the FAA for approval and thus become the standards for following winter season.
Some operators deice at the gates while others have a dedicated deice ramp with special drains etc to enahnce the process. SLC is a case in point. You hold at the gate until your number is called, taxi to the deicing ramp and the process begins. It is a time critical event that is adhered to by both crews and ground applicators.
As others have said there is little tolerance for any contamination prior to take off and I'm confident that Delta and SWA are using the same standards. At the completion of the deicing/antiicing the ground crew will report the times taken for the application and usually the gallons and type of fluid used as this helps the crew determine the extent of the procedure. The sun works just fine, assuming time is not a factor and build up is minimal.
FWIW deicing/antiicing is very expensive. The cost to do a wide body and easily exceed $,1000 per application and if your going to have your corporate jet deiced it can be well in excess of that number. I was blown away when we had a privately owned 757 done at SLC and it cost 1,500. Ouch!
Its not uncommon to see every first morning flight out of SLC get deiced during the winter even with clear, no pricip sky conditions simply due to frost buildup.
GalaxyFlyer
Fri Sep 20, 2019 3:29 pm
I did a C-5 in STR, IIRC, well into 5 digits, $25,000 sounds familiar.
GF
BravoOne
Fri Sep 20, 2019 3:57 pm
GF
Thanks, as I also realized my numbers were missing that extra 0. Make that $15,000, not $1,500:) Nohing is that cheap in the aviation world!
Delta had a "special" for non DL wide body aircraft that was around $16,000. A real steel at the time.
Nicoeddf
Fri Sep 20, 2019 4:34 pm
Not sure about the five digit. All numbers I have seen are around the range of 500 - 2500 USD, depending on A/C size. And that, quite frankly, sounds more reasonable for a single application than 25.000.
Enslave yourself to the divine disguised as salvation
that your bought with your sacrifice
Deception justified for your holy design
High on our platform spewing out your crimes
from the altar of god
BravoOne
Fri Sep 20, 2019 5:50 pm
How many gallons of deicing fluid do you think it takes for a C5 or a 747? I signed the FBO bill so I'm going to go by the facts regarding the 757 charges. Can't imagine what you would get for $500?
BravoOne
Fri Sep 20, 2019 6:08 pm
This is a copy of the reference handbook I spoke of in my earlier post.
https://www.faa.gov/other_visit/aviatio ... Tables.pdf
As you can see there is a lot more to this process than meets the eye.
DiamondFlyer
Fri Sep 20, 2019 10:11 pm
Exactly, I used to fly a PA-31, and it was generally more than $1000 USD to de-ice a piston twin.
From my cold, dead hands
jetblueguy22
Sat Sep 21, 2019 12:01 am
I’d love to know where you’ve seen those numbers. We spray our aircraft in house and the fluid costs I’ve seen would knock your socks off.
Look at sweatpants guy. This is a 90 million dollar aircraft, not a Tallahassee strip club
GalaxyFlyer
Sat Sep 21, 2019 12:04 am
Try de-icing a C-5 covered in 24 hours of freezing fog and drizzle.
GF
Nicoeddf
Sat Sep 21, 2019 2:27 am
GF
Hmm,...maybe my numbers are off. I check again.
But to be fair, your scenario isn't the standard de-icing. Standard would be wings and stabilizer plus snow removal on the airframe prior first flight in the morning.
Edit: Hmm, the result of a random google search
" De-Icing Summary: Actual de-icing costs vary depending on the amount of fluid required. The average de-icing cost for a small jet is 1,000 EUR per application. De-icing larger aircraft can cost over 10,000 EUR."
https://www.privatefly.com/privatejet-s ... -jets.html
BravoOne
Sat Sep 21, 2019 1:28 pm
You have to chuckle when you repsond to a poster with a known fact based on experience and then he goes to the trouble of trying to disprove what have just told them. I give up but as a least resort suggest he call the likes of UAL at say PDX and ask him how much to deice his BBJ.
FGITD
Sun Sep 22, 2019 4:16 pm
Such is the downside to an open forum. The 75% who have never piloted /worked an airplane will tell the 25% who have that they have no idea what they're talking about.
I've been on both sides of the deicing equation, the one spraying the plane and the one collecting the invoices from the deicing provider. (Thankfully never been the one opening the checkbook)
Get a nice deicing during active precipitation, and it really racks up very quickly.
To answer the op, it's a matter of airline operational preferences. Some will take the hit, and put a couple deicing trucks in a traditionally non-deicing station just in case. Others will accept the risk of possibly having to delay or cancel flights due to being unable to deice.
This is also why ground handling companies tend to be the biggest deicing providers. When you're the only one with a truck and everyone needs it, you can make a fortune in very little time.
(Though reality tells me that in that event, the one truck would be out of service, as they always are)
BravoOne
Sun Sep 22, 2019 4:31 pm
I have been in PDX on two occasions where they ran out of fluid on the airport with freezing rain either active or in the immediate forecast. Utter chaos!
exFWAOONW
Mon Sep 23, 2019 2:24 am
What is the wholesale rate for aviation quality glycol these days? I have vague memories of a buck a gallon when I was manning the nozzle.
Is just me, or is flying not as much fun anymore?
tb727
Tue Sep 24, 2019 1:07 am
Dropped about $29,000 on a 727 one night in RFD circa 2013. My credit card had a $30,000 limit and got declined because I had spent $6,000 a couple days prior on de-ice. We had nearly 10" of snow on the plane. Most I recall spending on a bizjet was about $2700 on a Falcon 20 we couldn't get hangar space for in MCI. It was coated in ice from an ice storm. FBO's typically charge a bit more, I'm sure at big airline operations it's a lot less. It's still an expensive but necessary ordeal.
71Zulu
Tue Sep 24, 2019 1:17 am
Or do like they do in Russia.
[MEDIA=youtube]5GIU94dg1ek[/MEDIA]
Sent from my SM-N960U using Tapatalk
Tristarsteve
Tue Sep 24, 2019 6:24 pm
With 10in of snow our deicing provider here has a couple of Elephant Betas that have air blowers on them. So they will start by blowing the snow off, then they will spray with hot water, and then with type 1 fluid diluted according to OAT. Finally if it is snowing they will spray with type 11 for some holdover time.
We have six departures a day, and deice at least one a day for six months, and have signed a deal with the agent where we pay a fixed sum per departure, so they pay for the fluid, so they use less!!
But after 30 years on cold weather stations I find that there are so many ways to get the same result.
tb727
Wed Sep 25, 2019 12:52 am
I agree that's a better way, they didn't have the blowers though. Company just wanted the snow off, Ford was paying for it so it didn't matter and wanted us out of there to pick up their tailgates in MCI. If it was up to me, I would have at least broomed as much of it off as I could!
Users browsing this forum: n92r03 and 27 guests
