ES64U2
Duration for gear retraction and flaps retraction
Wed Oct 16, 2019 9:42 am
Hello,
I'm a student writing my master thesis about aircraft performance during the take-off and initial climb phase. I would like to know the duration of gear retraction after the take-off (how long does it take when the pilot presses the lever until the gear is fully retracted) and the duration of the flap retraction. I already read the A320 FCOM but didn't find any information. Maybe there are some pilots or other engineers here who can help me. A320 specific data would be great but every information is appreciated. TIA!
gloom
Re: Duration for gear retraction and flaps retraction
Wed Oct 16, 2019 12:53 pm
Depends on plane and/or flap change (changing from flaps 0 to flaps 1+F is different than flaps 3 to flaps F). And probably on few other things as well (speed indicated, weather conditions/phenomena etc.). If you don't need scientific numbers (like 2.6 secs), I think easiest and fastest way to get some numbers is inside cockpit videos on youtube. You could check the time between start and done.
GalaxyFlyer
Wed Oct 16, 2019 1:47 pm
Longest in my experience, 25 seconds on the C-5, lots of motion. Shortest witnessed Space Shuttle, 3-5 seconds, I’d guess looks instantaneous. Most planes are probably around 10-13 seconds. Flaps vary all over the place with the first one or two settings taking the longest.
timh4000
Wed Oct 16, 2019 11:51 pm
The X-15 came down real quick too. Not sure which was faster but both needed the high speed since they deployed at like 200ft.
Thu Oct 17, 2019 1:10 am
Pass 1000 feet doing around 300 knots with v/s minus oh-my-god. Start flaring at 800-900 feet with very poor forward visibility. No wheel brakes because, well, no main gear wheels. As the saying goes, it seems impossible those guys could fit their enormous brass balls inside that tiny cockpit.
But I digress.
71Zulu
Thu Oct 17, 2019 1:53 am
Several videos on YouTube of gear swings in the hangar.
Sent from my SM-N960U using Tapatalk
Francoflier
Thu Oct 17, 2019 4:06 am
Hangar extensions/retractions tend to take longer than during normal operations as the hydraulics are usually pressurized with secondary or external systems with less pressure and/or flow than when all engine pumps are running.
GalaxyFlyer
Thu Oct 17, 2019 7:56 pm
Here’s an in-flight extension
https://m.youtube.com/watch?v=hZ1nfKQZ408
Users browsing this forum: AABusDrvr, Starlionblue and 7 guests
