BWIAirport
757 Incremental Takeoff Flaps Extension?
Thu Oct 31, 2019 9:48 pm
Whenever I fly on a 757, or watch a video of a 757 takeoff, I notice the flaps always seem to be extended to what appears to be Flaps 1 position, then extended to takeoff configuration 5-10 seconds later. See 15:28 in this video: https://www.youtube.com/watch?v=hA_JohxUFt4
This seems to happen without fail on every 757 flight, yet I have never seen it on another model. Is it related to airline/aircraft procedures, or is it a technical feature of the 757 for whatever reason?
Next flight: 3/1 DL2834 BWI-ATL B739
3/1 DL661 ATL-STT B752
SWA, UAL, DAL, AWE, ASA, TRS, DLH, CLH, AFR, BAW, EIN, AAL | E190 DC94 CRJ2 B712 B733 B737 B738 B739 B744 B752 B753 B762 B77W A319 A320 A20N A321 A333 A343 A388 MD88
GalaxyFlyer
Re: 757 Incremental Takeoff Flaps Extension?
Thu Oct 31, 2019 10:16 pm
The slats need to be “in place” before the trailing edge flaps. The 727 had a gate at Flaps 2 which stopped movement until the LEDs and the small extension of TEDs were positioned.
Max Q
Fri Nov 01, 2019 7:39 am
The gate at Flaps 2 on the 727 limited extension of the LED’s to only # 2,3,6 and 7
Guns are a malignant cancer that are destroying our society
fr8mech
Fri Nov 01, 2019 8:00 am
The trailing edge do move when the handle is moved to the FLAPS 1. You can see them move in the video you posted. In fact, the AMM tells us that at FLAPS 1 the flaps move to the 1 deg position and accomplish a little more than 10% of their total travel.
The gates on the B757 (FLAPS 1 & FLAPS 20) are to prevent inadvertent movement past those positions. The gates on the B727 are at 2 & 25. They don't limit the movement, they just slow you down. I was once told that those gates also provided an aural indication for the CVR. Not sure how true that is.
GalaxyFlyer
Fri Nov 01, 2019 1:00 pm
True and they unlocked the outboard ailerons.
GF
BWIAirport
Fri Nov 01, 2019 4:54 pm
What exactly is the gate protecting, and why does it apparently only affect the 727 and 757?
BravoOne
Fri Nov 01, 2019 5:03 pm
Hinders inadvertent flap/slat retraction.
DualQual
Fri Nov 01, 2019 7:15 pm
All Boeing aircraft have it. The gates are at the positions for normal go around and engine out go around.
There's no known cure for stupid
tb727
Sun Nov 03, 2019 2:04 am
At Flaps 2, there was also something to do....
GalaxyFlyer
Sun Nov 03, 2019 2:59 am
Check Pack Fans ON
Max Q
Sun Nov 03, 2019 7:25 am
Also, with flaps 2 the FE should check for symmetrical deployment of those four slats on his auxiliary panel
ClarkeKent
Mon Nov 11, 2019 2:01 am
That’s not completely correct. The gates are at positions for:
1. Normal go around.
2. Inadvertently retracting slat or led. This isn’t necessarily engine out go around flap setting.
:old:
Mon Nov 11, 2019 2:51 am
:old:
Out of curiosity, are the gates a regulatory requirement? The same balks/gates seem to exist on aircraft from other manufacturers as well.
fr8mech
Mon Nov 11, 2019 4:57 pm
A quick look at 14CFR25.145(d) says “If gated high-lift device control positions are provide”. The “if” suggests that they are not mandatory. But, a deeper look into the design and certification regulations may reveal some requirement.
https://www.law.cornell.edu/cfr/text/14/25.145
Whiteguy
Tue Nov 12, 2019 3:34 pm
[twoid][/twoid]
Just the system, flap 1 will go out immediately but past that it won’t deploy until the slats are fully extended. Just the way the flap system works.
Users browsing this forum: catdaddy63, Florianopolis, N353SK, OB1504 and 18 guests
