Starlionblue wrote:The PRIMs calculate stall warning speed using data from the AoA vanes only, plus the CG, gross weight and slat/flap position.
It cannot be like that in high Mach numbers. The early shockwave would necessarily make the stalling AOA lower. The plane needs to have the Mach number in order to predict the stalling AOA:
In high-altitude stabilised flight, shock waves can be seen at certain locations by looking at the upper surface through the cabin windows.
This sonic phenomenon around the wings leads to a degradation of their aerodynamic properties. This, in turn, leads mainly to a reduction in the maximum lift angle of attack as the Mach number increases, which significantly reduces the stall margin.
Source:
https://safetyfirst.airbus.com/high-alt ... al-flying/ (page 3 when the document is downloaded in PDF)
But I'm still puzzled as to why there were two short stall warnings right after the AP disconnected since the three tubes were clogged. As for when the stall warning started to sound continuously at 02:10:52, the pitots 1 and 2 were already back according to this animation:
https://www.youtube.com/watch?v=c6c-MbrVzs0, so I don't see anything strange in the stall warning working from that point onwards.
Disclaimer: I don't know if the video I posted is indeed an official BEA animation of the accident.
