VSMUT wrote:Even if they could, I don't think it is permitted by EASA and the UK CAA. The SFO thing is a US thing only.
quintol wrote:VSMUT wrote:Even if they could, I don't think it is permitted by EASA and the UK CAA. The SFO thing is a US thing only.
I think if Raytheon actually developed and proved the technology to FAA standards, EASA and the UK CAA would likely approve it. SYD currently uses SOIA, albeit with much greater runway separation than SFO.
VSMUT wrote:quintol wrote:VSMUT wrote:Even if they could, I don't think it is permitted by EASA and the UK CAA. The SFO thing is a US thing only.
I doubt they would. They were removed for a reason.
Such close parallel approaches are bonkers anyway. If Gatwick needs an extra runway, they are better served by building a new one.
Bhoy wrote:Nah, aside from the Runway and the taxiway cum runway being so close together, that’s such a congested Airspace, theres no space for near simultaneous realistic go around procedures, I just can’t see the CAA signing off on anything.
quintol wrote:Oops, I think this needs to be moved to Technical/Operations.
sassiciai wrote:The emerging view from the above posts is that Gatwick operates as a 2-runway airport. This is not the case, it is a single runway operation. However, to ensure continuity when the "only runway" is shut for whatever reason, the parallel taxiway has been equipped to serve as a replacement or backup runway.
Other than the necessary technology to make parallel ops a safe reality, I would imagine that there is some law/act/certificate/..... that expressly limits Gatwick to single-runway operations at any one time, and changing that might prove more difficult than getting the techno bits in place!
A quick search unearthed the Gatwick Master Plan 2018. Seems that the legal restriction of 2-runway use might expire this year (When, I don't know)
https://www.gatwickairport.com/globalas ... -final.pdf
A 40-year agreement struck by Gatwick and local councils ruling out a second runway expires in summer 2019.
2019 is a key year for the operator of Gatwick airport, as it's when a 40-year agreement not to run flights on its second runway at the same time as its main runway expires. And bosses have wasted no time in preparing a planning application asking to be allowed to do just that.
The agreement covered the airport's emergency/part-time runway on the north side, and was put in place to keep locals happy way back in the late 1970s when planning permission for the airport as a whole was granted. Now that it's expired, Gatwick's current bosses have handed in a preliminary scoping report outlining what it would like to do, telling the council that it would also like to expand both of its terminals at the same time as bringing its second runway into full time operation; a move that could massively increase annual passenger numbers from around 46 million now to 74 million by the year 2038.
At present, the second runway at Gatwick is currently only allowed to be used for emergencies or when the main runway is closed for maintenance. However, that 40-year restriction is set to expire at the end of 2019.
skipness1E wrote:Has anyone who thought this was a good idea ever operated regularly through Gatters?
There was a review as to where to build ONE additional runway for the South East which chose LHR. If you want a second LGW runway then that re-sets and we go round the hamster wheel again. The whold business case for a second runway at LGW hinges on LHR not having a third. If and when that opens, both Virgin and BA long haul will be off to LHR alongside China Airlines and Air China, if not also Cathay. The only long haul that would remain would be Emirates and Qatar with Norwegian likely to dip their toes at LHR as per the OAK-.SFO move.
VSMUT wrote:skipness1E wrote:Has anyone who thought this was a good idea ever operated regularly through Gatters?
How about the terminals? From what I've experienced, they are a chaotic mess. Could they even take an extra runways worth of passengers without a major rebuild? Look at the BA lounge for one. Stuck down a narrow corridor, up several flights of stairs and down another corridor!
skipness1E wrote:London will not have "two equally competitve airports", again you fundamentally misunderstand the role of Gatwick. It has been and remains a short haul point to point airport whereas LHR has been a world hub for decades.
No major long haul carrier ever chose LGW over LHR due to the vastly inferior connections. LHR has had a critical mass on this that LGW can never match. They cannot ever be equally competitve in a commercial environment. By all means expand LGW but to suggest that in doing so is "the death knell for Heathrow" is deranged nonsense. Unless you force-close LHR and all the jobs therein are lost, LHR will more often than not be chosen over LGW by the airlines, because they go where the market demands.
How about "Your London Airport, Gatwick-Mirabel" as the marketing slogan for this idea. I see you joined "One week ago." Perhaps read some of the many threads on this before closing Heathrow?
skipness1E wrote:VSMUT wrote:skipness1E wrote:Has anyone who thought this was a good idea ever operated regularly through Gatters?
Not without a step-change, a complete rebuild. The modern North Terminal home of BA's old hub is now an easyJet base and BA have retreated to the South where Pier 2 is a windowless 70s throwback. The new Pier 1 has just managed to sort a domestic arrivals route some years after they forgot to add it into the design after demolishing the old Pier 1, it's all very piecemeal as the ROI just isn't there. Even in summer whole swathes of the South Terminal stand empty as stand demand has massive peaks and troughs. At peak, certainly at first wave, it's a nightmare, but that's not unique to LGW. Not sure who exactly would *fill* a 2nd runway to be fair.
skipness1E wrote:You've literally never been to either Heathrow or Gatwick have you?
Have you any idea on the Delta in size between a full LHR today and LGW?
You would need to rebuild the totality of both North and South Terminals and still not approach today's levels of space needed at LHR.
Given LGW's current portfolio is BA's lowest cost operation, easyJet and Norwegian, who exactly is going to pick up the bill? It's daft mate, give it up. The locos won't pay up.
"Gatwick has a chance of reaching that critical mass"
You are conflating what I said. LHR's critical mass was gained in interlining and code sharing. Almost none of this happens at LGW, not even approaching LHR levels. Again, you are fundamentally ignoring the market dynamics at each airport, no alliance is asking to expand LGW so they can move there.
skipness1E wrote:Sorry but
1) Have you ever been to either LHR or LGW? Ever?
2) What's the point in building a LHR sized airport when LHR remains open?
You are fundamentally wrong on your market analysis. Any new owner has to raise charges to pay for significant investment and take on substantial levels of debt. HAL for example will be squeezing their current customers to pay for expansion, those customers could move to LGW tomorrow for cheaper fees, except they won't because yields are generally much stronger out of LHR.
So you advocate doubling the size of LGW to compete with LHR and getting any ROI how exactly? You are arguing for an airport planners wet dream, not a remotely likely outcome. Who is going to PAY for this? It's hard enough getting LHR built with the taxpayer having a part to play on motorway access and public transport costs, TFL loving this as they can argue for even more budget.
So name some airlines who support your view LGW should be expanded to LHR levels?
You ask why Vici can build a hub in Lisbon and not at LGW? Lisbon's new airport will have a based hub (flag-)carrier, LGW does not. BA does not hub at Gatters, it's a point to point low cost outbound leisure business model. LIS does not have an airport twice it's size in the same airspace, the analogy doesn't work IMHO
skipness1E wrote:And the ROI comes from where?
Who is asking for this?Which airlines has asked for LGW to replace LHR?
Their market cap didn't get so big by spending money with no business case.
I am not "jumping to conclusions", I have following this all my adult life. You have yet to suggest a compelling reason to spend money on a project no airline has asked for and that the market does not want. Again, let me press you.
What major airline has asked for this?
Will Lufthansa move to LGW? Why not?
Should British Airways abandon T5?
Perhaps American will do better at LGW?
DL/VS should leave LHR to Oneworld/STAR and build a new hub at LGW paying higher fees to pay for rebuilding the whole airport whilst leaving AA/BA to run up losses at LHR?
Utter nonsense. Just because you can do something doesn't mean you should. As for close parallel approaches, SFO is hated in poor weather as it's movement rate comes crashing down, it's unreliable in winter, much more so than LHR and SFO enjoys better weather than LGW.
skipness1E wrote:AirFrance and KLM aren’t moving to LGW.
Delta fought hard to leave.
Virgin have their smallest LGW operation in the 15 years I have been London based, LAS recently moved to LHR.
But yeah, a SkyTeam hub at LGW.
rabader wrote:Is it still on the plan to build a second runway in Gatwick?
I was looking at this plan and it looks pretty cool
https://www.gatwickairport.com/globalas ... _final.pdf
quintol wrote:skipness1E wrote:AirFrance and KLM aren’t moving to LGW.
There is precedent for a large airline to move from the major airport of a metropolitan area to a slightly smaller alternative. UA moved from JFK to EWR, the new hub airport with nearly the same number of annual passengers as LGW with both around 46 million passengers per year. However, LGW's current annual passenger numbers are only with its one operating runway. If LGW follows through with its plan to widen 08L/26R 12 meters/~39 feet to ensure it meets the international standard for the minimum 210 meters/~689 feet separation between simultaneously operating runways, it could potentially meet its 70 million passenger (annum) goal by 2032/33. (Pg 88 of the Gatwick Airport Draft Master Plan - October 2018: https://www.gatwickairport.com/globalas ... -final.pdf) With an enhanced SOIA that would only have to decrease its minimum runway separation by ~60 feet, Gatwick could most definitely increase its goals above 70 million passengers, and combining this with a lengthening of 08L/26R to 10,879 feet, 1.5 nautical mile staggers as used by SFO in .308 approaches in IFR (see slides 4 & 5 of SFO SOIA RNAV (GPS) PRM, starting with JO 7110.308 https://www.faa.gov/air_traffic/flight_ ... Status.pdf), and mixed mode runways, Gatwick could meet Heathrow's 80 million annual passenger load. Technology & procedures for closely spaced parallel runways is improving dramatically, especially due to SFO's runways, and they could likely be transferred to how LGW operates to allow it to approach LHR's current capacity. LHR's third runway will likely never come to fruition with the current political climate in Britain, so the increasing air traffic in the South East of England should be accommodated by LGW.rabader wrote:Is it still on the plan to build a second runway in Gatwick?
It's unlikely, since LGW is planning to bring the emergency/standby runway 08L/26R into daily operation. It will effectively become the second runway that was supposed to be built after 08L/26R is widened and possibly lengthened in the future.
Web500sjc wrote:quintol wrote:skipness1E wrote:AirFrance and KLM aren’t moving to LGW.
For UA, JFK was an outstation which they served with flights from their hubs at SFO and LAX. Instead of sending their premium transcons to an outstation, UA decided to fortify the massive hub they had 12 miles away and simplify the network. What you are proposing would be along the lines of UA moving their LGA operation to EWR, DL moving their DCA operation to IAD, or moving every domestic airline at DFW to DAL.
Gatwick can not replace Heathrow, at best, the Gatwick you propose would be a comprised Heathrow parody. It wold have 2 runways so close together, that operations on one runway would be dependent on what the other runway is doing, it would have the 75% potential capacity as Heathrow with more aircraft restrictions. The way Gatwick competes with Heathrow is having more airline access opportunities (they will do this with the airfield improvements bringing the second runway into normal use), similar or better access to the public transportation/city, and cheaper airport fees.
