BlueberryWheats wrote:I think they try and avoid having both/all engines being the same 'age' in hours on an aircraft. So a new aircraft might have one of it's brand new engines replaced with a slightly older one, so you have a brand new and a used engine on the aircraft.
Something to do with trying to avoid the risk of both engines running into problems at the same time.
Wacker1000 wrote:BlueberryWheats wrote:I think they try and avoid having both/all engines being the same 'age' in hours on an aircraft. So a new aircraft might have one of it's brand new engines replaced with a slightly older one, so you have a brand new and a used engine on the aircraft.
Not at any civilized airline and those that do probably also ban a fleet type from their country after one is involved in an accident. An airline is free to do whatever they please after delivery but modern engines are so reliable and the quality control is good enough that there is no reason to do this.
B757Forever wrote:Wacker1000 wrote:BlueberryWheats wrote:I think they try and avoid having both/all engines being the same 'age' in hours on an aircraft. So a new aircraft might have one of it's brand new engines replaced with a slightly older one, so you have a brand new and a used engine on the aircraft.
Staggering of engines is a common practice worldwide at reputable carriers who have excellent safety records. Often times, a stagger is done to better manage the remaining hours or cycles on a particular engine and is a part of the overall engine management program.
Tristarsteve wrote:Up yo a year ago, British Airways operated B767-300 and B747-400, both fitted with the same RB211-524G/H. Engines could be swapped between fleets with a one hour mod to a couple of sensors that were fitted to the ETOPS B767 but not the B744. Engines were planned so that the ETIOPS B767 generally had the better engines, and the older engines ended up on the B744, which could withstand an engine failure with much less consequence.
Dalmd88 wrote:Aircraft engines are the classic "George Washington Axe". That axe he used to chop down the cherry tree. The handle broke so it was replaced. Years later the blade broke so it was replaced, but is still the same axe. So goes the modern jet engine. The only part of the engine that can not be replaced is the Data plate. Technically that can be replaced, but the old damaged one must be surrendered to the engine manufacturer to get a replacement.
In essence a jet engine can live as long as you can keep replacing worn out parts with serviceable ones. In theory you can do the same for the entire aircraft, but It only usually happens in rare warbirds or when the military 'rebuilds' a old fleet like the P3.
Dalmd88 wrote:Aircraft engines are the classic "George Washington Axe". That axe he used to chop down the cherry tree. The handle broke so it was replaced. Years later the blade broke so it was replaced, but is still the same axe. ..
Phoenix757767 wrote:At US Airways we had a CF6 that had five years on wing time on a 767 which is unusual.
Phosphorus wrote:Dalmd88 wrote:Aircraft engines are the classic "George Washington Axe". That axe he used to chop down the cherry tree. The handle broke so it was replaced. Years later the blade broke so it was replaced, but is still the same axe. ..
Well, a couple of thousand years before Washington and his axe, the classic thought experiment https://en.wikipedia.org/wiki/Ship_of_Theseus was debated. That's probably a much more "classic" way to describe the paradox of continuously updated complex object.
Sokes wrote:Phosphorus wrote:Dalmd88 wrote:Aircraft engines are the classic "George Washington Axe". That axe he used to chop down the cherry tree. The handle broke so it was replaced. Years later the blade broke so it was replaced, but is still the same axe. ..
I'm 44 years old now. Have I been the same person with 20 years?
Phosphorus wrote:Well, if we are into philosophy, your question corresponds to the maxim "You could not step twice into the same river." Debates since time of Heraclitus.
Ship of Theseus is more specific and actually more fun. Because besides a gradual full repair of an existing ship with full new set of planks -- so that ship contains no original elements; it also includes warehousing all the original material, inventing a technology to fix them, and assembling a second ship out of original elements.
Obviously, there's no set of spare parts of "you", to build a second set of "you" to run a comparison, is there?
Weatherwatcher1 wrote:The newer engines don’t last as long between overhaul. Higher core temperatures and pressure help with efficiency but can increase wear. There have been CFM56 engines make it to 40,000 hours (10 or more years of service) although that is an anomaly. I doubt we will ever get another engine last as long on wing between overhaul as CFM56 since there is increasing demand on efficiency.
patrickjp93 wrote:Weatherwatcher1 wrote:The newer engines don’t last as long between overhaul. Higher core temperatures and pressure help with efficiency but can increase wear. There have been CFM56 engines make it to 40,000 hours (10 or more years of service) although that is an anomaly. I doubt we will ever get another engine last as long on wing between overhaul as CFM56 since there is increasing demand on efficiency.
Source? I know RR has its particular issues with the Trent 1000, but as far as I can tell, the GEnx lasts just as long as the GE90 despite burning hotter, and the GE9X will last longer, though that is thanks to integration of CMCs in the hot section
lightsaber wrote:patrickjp93 wrote:Weatherwatcher1 wrote:The newer engines don’t last as long between overhaul. Higher core temperatures and pressure help with efficiency but can increase wear. There have been CFM56 engines make it to 40,000 hours (10 or more years of service) although that is an anomaly. I doubt we will ever get another engine last as long on wing between overhaul as CFM56 since there is increasing demand on efficiency.
The LEAP-1A is designed for longer life than the CFM-56.
Following the unprecedented times on wing recorded by current-generation CFM56 and V2500 engines, many expect their successors—the Leap and PW1000—to perform as well or better, with fewer but heavier shop visits predicted.
https://www.mro-network.com/engines-eng ... igital-age
I couldn't re-find the link, But I read a CFM-56 will see 5 shop visits during the life of an A320 (yes, first visit is a third of the aircraft life), while the LEAP is expected, after initial teething issues, to see one less.
Does anyone remember the compressor surge issue in the CFM-56-5 and -7? I didn't think so:
https://www.flightglobal.com/news/artic ... es-345359/
Older engines had time to solve issues. There is a reason for launch customer pricing. Also why BA/IAG and JetBlue now refuse to be launch customers. The CF-34-10/E-190 did not have a smooth EIS nor great maintenance:
https://www.bloomberg.com/news/articles ... st-problem
Lightsaber
PS,
I'm not discussing RR or Pratt issues as they have been discussed enough.
strfyr51 wrote:Engines can basically be overhauled as long as the Parts can be repaired or manufactured. I would invite any of you to try and book a tour of the United Airlines Turbine shop at San Francisco to see what the repair capabilities are in Jet engine repair and overhaul. I can assure you? You'd be amazed and impressed as I am whenever I go there. I used to come to work early just to walk through there as they had so much neat stuff going on there. In my 33 years working the Line at United that was the one place I regretted not ever having worked, Those guys are craftsmen at their finest, Though My specialty was working Live Airplanes and I have put my name on enough releases to estimate that could have a Billion revenue passenger miles flown on my signature alone with all the Maintenance releases I've put my name on without ever a mishap. I joked before that I was never afraid to take an airplane out of service as I was FAR more afraid of the FAA than I was of anybody at United.
