Embajador3
Taxiing with 1 engine
Tue Nov 26, 2019 9:09 am
I remember seeing how many US airlines were using only one engine when taxing. Is this something most airlines do? I don´t recall seeing that in Europe, and most certaintly, the airline where I work does not allow such a thing.
Flying Together
Armodeen
Re: Taxiing with 1 engine
Tue Nov 26, 2019 9:10 am
Very very common practice in the UK.
paullam
Tue Nov 26, 2019 9:11 am
EasyJet and SAS do it in Europe. I’ve seen Pegasus and KLM do it as well.
Qatar even use single engine taxi on their 777.
712 733 734 735 737 738 739 744 748 752 763 77E 77L 77W 788 789 | A20N A21N 318 319 320 321 332 333 343 346 359 388 | ASK21 | AT75 AT76 | BCS3 | C152 C172 C182 C210 | CR2 CR7 | DH8C DH8D | E190 | F70 F100 | LJ24 | PA31 | RJ85 RJ1H | SF34 | SU9 | YK2
Embajador3
Tue Nov 26, 2019 9:17 am
Do UK airlines whom operate turboprop aircraft use one engine for taxiing too?
Flying Together
Armodeen
Tue Nov 26, 2019 9:24 am
Flybe certainly does, it’s obviously very easy to see on a prop.
anrec80
Tue Nov 26, 2019 9:28 am
Yes, this is common among U.S. majors. I am also wondering - are economic advantages of this even noticeable? It seems to put more wear on one engine vs the other.
KFTG
Tue Nov 26, 2019 9:31 am
Please let the pilot fly the airplane.
CHRISBA35X
Tue Nov 26, 2019 10:10 am
Its SOP at KLM fleet wide, certainly at AMS, not sure about other airports but every KLM flight I've taken has been this way.
I've been on FlyBe Embraers that do it as well.
Its an odd sound to hear the plane land on the Polderbaan and be tootling along toward the terminals and to hear them shut down the number one engine.
sevenair
Tue Nov 26, 2019 10:17 am
Qantas link do it on the Dash.
Eikie
Tue Nov 26, 2019 10:19 am
The wear on the other engine is minimal at best.
Taxiing is most often done with both engines on idle (minimum thrust) and even then there is breaking needed not to exceed the maximum taxi speed. Of course higher weights and accelarations required slightly more power.
Shutting down 1 engine might ask more of the other when accelerating, but on long streches the remaining engine, in that idle position, is most of the time enough to keep taxiing.
So it asks a little bit more of the remaining engine, but saves on breaking and fuel.
Ronaldo747
Tue Nov 26, 2019 10:23 am
Vueling in BCN did it as well at my flight three years ago, quite short taxi to 25L but long queue for departure though.
brianK73
Tue Nov 26, 2019 10:41 am
It's a standard operating procedure in my C152.
cedarjet
Tue Nov 26, 2019 10:56 am
On some planes you have to because the engines generate so much residual thrust (what comes out when the throttles are shut, aka flight idle) that you’re riding the brakes to stop it accelerating otherwise, which wears the brake pads and can overheat the brakes. P&W powered 747s especially.
Ha we must fly for the same airline, SOP on the PA-28 too!
KFTG
Tue Nov 26, 2019 10:57 am
Sounds dangerous.
GBNWB
Tue Nov 26, 2019 11:00 am
BA do it with the Airbus. Only risk is not starting it early enough to get heat in the engine. No more of a risk than getting to the runway without the numbers having arived yet though :-D
AirKevin
Tue Nov 26, 2019 12:08 pm
I guess if the taxi is long enough, it would make a significant difference. I was on a Delta 757 back in 2007 that did a single engine taxi. Taxi time to runway 31L was 58 minutes, and the second engine was started when we were on 22L.
Captain Kevin
pdp
Tue Nov 26, 2019 12:09 pm
I'm assuming this is more of a risk than for say EZY because of how long it takes the IAEs to fire up?
GBNWB
Tue Nov 26, 2019 12:12 pm
Indeed, I think EZY start theirs passing Q when headed for 08R at LGW.
BA777FO
Tue Nov 26, 2019 2:59 pm
The A320 can single-engine taxi out, starting the other engine closer to the runway. Boeing do not have a procedure for this.
Boeing and Airbus can shut engines down on the taxi in. The 747 can taxi in on 2 engines, I believe the A380 can too.
After landing, at weights below 190 tonnes, the 777-200 will quite happily gain speed at idle on a single engine. The GE90s require a 3 minute cool down after landing, the RR Trents only need 1 minute.
DiamondFlyer
Tue Nov 26, 2019 3:18 pm
Just because Boeing doesn't have a procedure for it, doesn't mean that an airline can't do it on a Boeing airplane..
From my cold, dead hands
Tue Nov 26, 2019 3:40 pm
According to our beancounters, even a minute or two of single engine taxi means noticeable savings.
BA777FO
Tue Nov 26, 2019 8:56 pm
Good luck getting your FCOM approved by the regulator in that case.
Can you point me towards any airline that uses a single-engine taxi out procedure on a Boeing aircraft?
BA777FO
Tue Nov 26, 2019 9:02 pm
30 minutes taxi fuel for a 777-200 is just under 800kg of fuel. So 1.6 tonnes per hour - 26kg of fuel per minute or 13kgs per engine per minute.
What's the price of 16 litres of Jet A1? ~$15? With an engine shut down for 5 minutes that's $75. Across an airline with 50 777s that's $3,750 per sector or $7,500 per day. ~$2,500,000 over the course of the year accounting for downtime for maintenance for a fleet that size. Not huge in the context of revenues of billions but the accountants will love it nonetheless.
GalaxyFlyer
Tue Nov 26, 2019 9:03 pm
We did single and two engine taxing in the mighty Boeing Tri-motor.
DiamondFlyer
Tue Nov 26, 2019 9:14 pm
Numerous US airlines...
BA777FO
Tue Nov 26, 2019 10:44 pm
On their Airbus aircraft, yes. So do European airlines. If Boeing has introduced a single engine taxi out procedure for the 737 it must have been within the past few years. They certainly don't have one for the 777 or 787.
Tue Nov 26, 2019 11:01 pm
AFAIK our Boeings do single-engine taxi in. Same as we do on the 'bus.
LH707330
Tue Nov 26, 2019 11:33 pm
Do most airlines specify which engine needs to be shut down for the single-engine taxi? On quads, do they shut down 1 and 4 and leave 2 and 3 running?
I met a guy who said his carrier always specified that one engine on a 320 should be shut down, so the other got more wear, and their spool-up would be a bit different.
AirKevin
Wed Nov 27, 2019 12:05 am
I know Delta has done it, I've been on two 757 flights where this happened.
On the 747, engine 3 is the one that gets shut down when taxiing in. You don't want to shut down 1 or 4 because the hydraulics for those engines are tied to the brakes and steering. Not sure about other planes
Captain Kevin
Wed Nov 27, 2019 1:27 am
Not an engineer, but methinks the difference in wear is probably minimal if one engine is shut down earlier than the other every flight. As mentioned above the engines are at idle or just above idle while taxiing. Besides, engines are "mixed" all the time, as in one might have been hanging on the wing for years and the other one might have just been replaced. They're going to be different, but FADEC makes it transparent to the user, so to speak.
Which engine you shut down is somewhat dictated by the systems architecture. On the A350, the hydraulic systems are symmetrical (both systems have one pump in each engine) so it doesn't make a difference which engine is shut down. Take your pick on the day, perhaps considering the direction of any tight turns.
On the A330, on the other hand, shutting down engine 2 is recommended because alternate braking and the brake accumulator are on the blue hydraulic system, which is powered by engine 1 only. Pretty unlikely you'll lose normal braking, and you'd still have the accumulator. But just in case.
RetiredWeasel
Wed Nov 27, 2019 3:14 am
AirKevin wrote:
At NW on the 744 taxing out for takeoff with #3 shutdown was often done if the aircraft wasn't real heavy. It was referred to as "Delayed Engine Start". And right out of manual, the company/Boeing said that one minute of engine out taxi is worth 3.7 gallons of fuel. Multiply that by the number of 744 flights per year and it added up I reckon.
Chemist
Fri Nov 29, 2019 6:46 am
WN taxis out their 737s on single engine all the time. I often hear the second engine spooling up as we near the end of the taxiway before the turn onto the runway.
Fri Nov 29, 2019 10:35 pm
Crazy if true, engines need a few minutes after start to become thermally stable for maximum thrust to be applied.
“Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.” E. Hamilton Lee, 1949
Chemist
Sat Nov 30, 2019 6:06 am
I could always be mistaken but have clearly heard what sounds like second engine spool up through the octaves on late taxi to the runway. What I haven't done is measured the time between engine start and takeoff. While sometimes at my local airport we turn right onto the runway and go, there are other times we hold at threshold, or line up and wait. So perhaps there is a correlation with waiting after engine#2 start and takeoff. Just don't know, I'll try to pay some attention on my next few flights. I have an upcoming flight next week, and then in late December and another in early January. All on WN.
Francoflier
Sat Nov 30, 2019 6:50 am
I was flying on a major European A320 operator recently and we definitely taxied out on a single engine. The other one was noticeably started on the taxi out later (spool up sound, lights flickered from power transient, oh, and the bloody dog finally stopped barking..). It was started well in time to allow proper warm up before takeoff (long taxi). From the expeditiousness and flow of the whole thing, it very much seems like standard ops at this particular airline.
longhauler
Sat Nov 30, 2019 7:15 am
Also consider that the remaining items on the After Start Checklist must be completed, as well as the Before Takeoff Checklist. None of which can be done until the second engine is started. This can take around 5 minutes or so. A bit risky that close to the runway.
Not to mention, ATC (rightfully) gets more than a little miffed if you’re not ready when it’s your turn.
longhauler
Sat Nov 30, 2019 7:21 am
When done per Airbus SOPs, a single engine taxi should not result in the PTU running, other than the test during engine start. However, the Yellow Electric (hydraulic) Pump can get a little irritating, as it will be running. It is a high pitched “whine” heard around the middle of the cabin.
Chemist
Sat Nov 30, 2019 8:20 am
This is all out of BUR. I have flown about 150 segments out of this airport over the past 5 years mostly due to work. I would not say that second engine start on taxi is a majority of the time, but it's not rare, either. Any WN crew online to verify this? I'll pay attention to the timing on my next few flights should they taxi on one engine.
Tristarsteve
Sat Nov 30, 2019 11:03 am
When I worked in engine development at BEA at LHR in 1970, the airline had started shutting down the nbr three engine on the Trident after landing. I was involved in some check of the turbine blades by boroscope, in the days when there were no boroscope ports or hand turn drive on the Spey engines. (We removed the starter motor and an ignitor plug!)
Soon after it was noticed that the Nbr 3 engines were failing much more often than the others, and the experiment was abandonded. Bit ahead of our time!
