timh4000
TCAS/ATC
Mon Dec 02, 2019 10:56 pm
Let's say you are on approach at 5000ft, zero visibility TCAS Announces TRAFFIC, CLIMB at the same time ATC warns of the same and says descend. Which action do you take?
GalaxyFlyer
Re: TCAS/ATC
Mon Dec 02, 2019 11:11 pm
Re: TCAS/ATC
Mon Dec 02, 2019 11:52 pm
Always, always, always follow a TCAS RA. And while we tell ATC that we have an RA. we are encouraged not to transmit what TCAS is telling us to do, in order to avoid confusion. Once TCAS says "Clear of Conflict", we tell ATC our position.
TCAS knows best.
Re: TCAS/ATC
Tue Dec 03, 2019 12:19 am
You mean you don’t keep flying the approach and ask ATC what to do ?
Re: TCAS/ATC
Tue Dec 03, 2019 12:42 am
Yes, well, that was an interesting story. Typically asking ATC instead of following an RA leads to yelling on the flight deck or in the sim. I'm not fond of that.
BTW I should qualify my earlier statement. Always follow a TCAS RA unless you also get a stall warning, EGPWS warning, or windshear warning.
Yikes!
Re: TCAS/ATC
Tue Dec 03, 2019 2:06 am
This says it all:
https://www.skybrary.aero/index.php/T15 ... many,_2002
Eurocontrol prohibits air traffic controllers from overriding TCAS alerts. Possibly the same here in North America.
N737ER
Re: TCAS/ATC
Tue Dec 03, 2019 4:29 am
In the US, ATC is not allowed to override the TCAS RA. Simply, all ATC can do is call traffic, and make sure no other aircraft may be affected by the RA. Some airlines have policies where if the crew has the offending aircraft in sight (hopefully ATC has called traffic before the RA happens) they can disregard the RA if ATC has applied appropriate separation. The aircrew will notify ATC when the RA is resolved.
IAHFLYR
Re: TCAS/ATC
Tue Dec 03, 2019 2:54 pm
As a former TRACON controller it is very difficult to not respond when the crew informs you of an RA.
But from the order 7110.65Y here is the rule:
2−1−28. TCAS RESOLUTION ADVISORIES
a. When an aircraft under your control jurisdiction
informs you that it is responding to a TCAS
Resolution Advisory (RA), do not issue control
instructions that are contrary to the RA procedure that
a crew member has advised you that they are
executing. Provide safety alerts regarding terrain or
obstructions and traffic advisories for the aircraft
responding to the RA and all other aircraft under your
control jurisdiction, as appropriate.
b. Unless advised by other aircraft that they are
also responding to a TCAS RA, do not assume that
other aircraft in the proximity of the responding
aircraft are involved in the RA maneuver or are aware
of the responding aircraft’s intended maneuvers.
Continue to provide control instructions, safety
alerts, and traffic advisories as appropriate to such
aircraft.
c. Once the responding aircraft has begun a
maneuver in response to an RA, the controller is not
responsible for providing approved separation
between the aircraft that is responding to an RA and
any other aircraft, airspace, terrain or obstructions.
Responsibility for approved separation resumes
when one of the following conditions are met:
1. The responding aircraft has returned to its
assigned altitude, or
2. A crew member informs you that the TCAS
maneuver is completed and you observe that
approved separation has been reestablished, or
3. The responding aircraft has executed an
alternate clearance and you observe that approved
separation has been reestablished.
hitower3
Re: TCAS/ATC
Wed Dec 04, 2019 6:36 pm
Interesting topic, which lets me ask one more question:
Is there any automated way for the ATC controller to be made aware of an ongoing TCAS RA? Or do they depend on a radio call by the pilots flying the RA procedure?
Hendric
hitower3
Re: TCAS/ATC
Wed Dec 04, 2019 6:39 pm
Hendric
sccutler
Re: TCAS/ATC
Wed Dec 04, 2019 6:42 pm
Hendric
TCAS is an autonomous system, and it works from its own interrogation of other aircraft. There is no data link to controllers' scopes or systems.
...three miles from BRONS, clear for the ILS one five approach...
hitower3
Re: TCAS/ATC
Wed Dec 04, 2019 6:53 pm
Dear Sccutler,
Thank you for your quick answer.
Indeed, one of the main reasons for the Überlingen disaster was a conflicting instruction from ATC. Even though priorization rules exist (as explained here above), it would be sensible to include ATC in the TCAS resolution process, IMHO.
Hendric
GalaxyFlyer
Re: TCAS/ATC
Wed Dec 04, 2019 10:28 pm
They are included, Pilot transmits, “TCAS RA”; ATCO waits for Pilot to say something like, “clear of conflict”. Remember on many RAs, one of the targets isn’t communication with ATC or is likely not on an IFR flight plan.
AirKevin
Re: TCAS/ATC
Wed Dec 04, 2019 10:42 pm
Except that actually didn't help in this particular instance. The DHL crew tried to let the controller know that, but as he was working two separate radars at that point, he missed this. It also didn't help that the main radar was undergoing maintenance, so there was no functioning collision alerter as a result of this.
Captain Kevin
rendezvous
Re: TCAS/ATC
Thu Dec 05, 2019 8:40 pm
a TCAS/RA is an emergency warning, a last line of defence. You do not ignore warnings. Just like you don't ignore a "terrain pull up" alert.
The newer A320s I fly have autopilot TCAS - it will fly the RA for you.
HTCone
Re: TCAS/ATC
Sat Dec 07, 2019 1:03 pm
Pilots follow TCAS RAs, not us. Period. It may have been our error which caused the issue.
I’ve had 2 RA situations in my sector over the years, thankfully neither my fault. A 767 1 mile behind and 2,000 feet below a 777 needed a 1,000 foot climb for his Oceanic entry, he got an RA after climbing about 800 feet and descended again, the 777 only got a TA. The other was a GLF5 departing an aerodrome who I cleared up to FL350, 1,000 feet below an opposite direction B744. I warned to GLF to reduce ROC 3 times as he got through the high 20s and gave traffic info to both him and the 747, still he set off RAs.
Interestingly there was an issue a couple of years ago I’m aware of where a conflict was developing, controller gave avoiding action but the crew he gave it to ignored the turn because they had a TA, mistakenly believing TAs override ATC avoiding action. RA soon followed.
71Zulu
Re: TCAS/ATC
Sat Dec 07, 2019 4:09 pm
Incident and close call with JAL in 2001.
[MEDIA=youtube]1V-NURlZ0Jc[/MEDIA]
Sent from my SM-N960U using Tapatalk
Users browsing this forum: blink182, spompert and 15 guests
