timh4000
Flight plans
Sat Jan 04, 2020 11:54 pm
Pretty much questions for pilots, or at people who really know it...
For an example UA has daily transcon flights using 777's this I know for sure Ive been on one a year ago.
Regardless of the airline but being a daily flight and that is today's flight assignment, is the flight plan completely drawn up or does the captain and F/O help draw it up. Or. Do, can they make requests for deviations before they fly? I know there's an amount of fuel assigned to the flight, and at least sometimes the captain will make a request for more. Watching a doc the flight crew was going over it and the captain requested a few more tons of fuel which was allowed. How often does that happen and how often are pilots refused for more fuel? Anything else I'm missing about the process please feel free to add it on.
sdf880
Re: Flight plans
Sun Jan 05, 2020 12:35 am
The aircraft dispatcher plans the flight hours before the flight. The dispatcher will analyze weather, winds, route, if an alternate is required, maintenance status of the aircraft,
and any air traffic advisories. Other factors come into play as well such as runway is wet/dry/icy/snow covered, landing weight, landing weight at alternate, etc! The captain
will review the flight plan prior to the flight and if he or she likes it they will sign it and away they go. The dispatcher will follow the progress of the flight and monitor fuel and route.
The dispatcher has the ability to communicate with the flight via radio and electronic means most airlines have ACARS electronic communication. Back to pre-flight if my captain
wants more fuel we'll discuss it and more often than not more fuel is uplifted. Kinda of a broadstroke answer there are a ton of variables daily!
Re: Flight plans
Sun Jan 05, 2020 1:01 am
I can only speak for our operation, but typically for the same flight number going from A to B every day it'll be the same route, or one of 2-3 depending on weather/wind. The actual path is calculated with planning software. The planned runway at each end (and thus planned SID and STAR) is based on seasonal patterns. On the day, of course, winds change, so the flight plan might say we are using 07L and its STAR but in the FM we put in 25R and its STAR. The published flight plan is not changed with the actual STAR, but the flight folder software tracks which runways and STARs are used and we can see what is likely based on past flights. And of course, once we get closer to the destination the runway and STAR might be different from what we expect, and the runway could change multiple times during the descent. But that's all tactical.
We don't make our own flight plans and only very rarely would we ask for a change in the actual route. There might be a volcanic eruption or serious weather that the planners have not been conservative enough about in our opinion. But again, very rare. In almost all cases any deviations for weather or other things are decided on tactically while in flight.
The one big number we decide on is fuel, and the captain can indeed request more fuel, typically if we expect extended holding. The company does not really have a mechanism to refuse such a request. We tell the fueler how much we want. The fueler does not then check with planning or dispatch if this is ok. He just loads it on. That being said, fuel requests are tracked, and if a captain frequently takes on a few extra tons "just because" he might find himself having a conversation with the chief pilot. Carrying more fuel costs money, so the fuel figures are rather "optimised" and the company accepts that there is a certain risk of diversion with the planned fuel.
Proceeding to give you way more detail than you probably wanted, chronologically the process is something like this:
- Several hours before departure, a preliminary plan is drawn up by the planners using software tools. This contains an estimated zero fuel weight and estimated trip and total fuel.
- 2-3 hours before departure, the flight plan is published to the flight folder app, along with all the ancillary documentation (NOTAMs, METARs, RAIM predictions, weather charts etc...). We can now review it.
- A new flight plan version is published if the zero fuel weight changes beyond certain thresholds. A ZFW change will always involve a fuel number change, but could also involve a planned flight level change. An aircraft change would also result in a new version.
- 60-70 minutes before departure, the crew reports to dispatch (at home port) or the aircraft (at an outport) and we do a dispatch briefing. (If on a turn, you simply download the flight plan while sitting in your seat.)
- We make a preliminary fuel decision based on the estimated zero fuel weight, typically accepting flight plan fuel but sometimes taking more, and give the fueler a standby fuel figure. This standby figure is somewhat under what we expect the final to be, so that if our zero fuel weight decreases, we can decrease the final fuel figure.
- We enter the estimated zero fuel weight and preliminary fuel figure in the FM so that it calculates performance correctly. We also use the preliminary takeoff weight for a preliminary takeoff performance calculation.
- 35-ish minutes before departure, the flight is closed, and the cockpit printer chugs out the final zero fuel weight, received via ACARS.
- We make a final fuel decision, allowing for changes from the estimated to the final zero fuel weight, and give the fueler the final figure.
- We send the final fuel figures off via ACARS. The loadsheet is produced using these numbers.
- Once the fuel is onboard, we check that we got what we asked for within a certain tolerance, and that the distribution is correct.
- The cockpit printer chugs out the preliminary loadsheet. We check it and enter the final weight/fuel/CG numbers in the FM. We also revise the takeoff calculation with the final takeoff weight and enter the resulting performance numbers in the FM.
- Once all the pax are on, the traffic guy comes in and tells us that the final loadsheet is on the way. He confirms the final pax number, which may have changed if someone was offloaded. He leaves the plane and the door is closed.
- At some point before takeoff, we receive the final loadsheet. We check it and make any changes in the FM. We accept the loadsheet via ACARS. This must be done before the "before takeoff" checklist.
timh4000
Re: Flight plans
Sun Jan 05, 2020 2:57 am
Starlionblue, that is exactly what I was looking for, thx.
WPvsMW
Re: Flight plans
Sun Jan 05, 2020 4:44 am
Sb, do you think the June 2016 ICAO published Amendment 7-A to PANS-ATM has reduced misunderstandings (variant phraseology) in SID/STAR exchanges (air/ground)?
Re: Flight plans
Sun Jan 05, 2020 7:25 am
The whole "descend via STAR" and "descend unrestricted" thing? Caveat: I am by no means an expert, but I'd say yes. But not completely.
"Descend via STAR" works well. It specifically tells you that the STAR restrictions are in place. So even if you were assigned 230 knots you shall now use the STAR speeds. However, "descend/climb unrestricted" is sometimes be used unambiguously. Some controllers might tell you unrestricted but they only mean the speed restrictions, not the altitude restrictions.
I like the UK phraseology, where an unrestricted climb/descent comes with the phrase "climb now"/"descend now", meaning you can ignore the altitude restrictions but not the speed ones.
WPvsMW
Re: Flight plans
Sun Jan 05, 2020 9:44 am
Yes, both with STAR and SID, but in practice it seems most of the confusion was on STAR exchanges.
https://www.icao.int/airnavigation/sids ... sions.aspx
Re: Flight plans
Sun Jan 05, 2020 11:01 am
Probably because STARs involve a lot more than SIDs when it comes to profile management and timing. It is much easier to take traffic from terminal to enroute airspace, than to try to time all those planes to arrive neatly spaced to one or two runways.
CosmicCruiser
Re: Flight plans
Sun Jan 05, 2020 3:17 pm
Starlion jogged my memory. UK controllers would often give you "no speed restriction" on departure meaning you could ignore the 250 below ten or whatever their limits were. 320 out of 5,000 was a real hoot!
gloom
Re: Flight plans
Sun Jan 05, 2020 7:17 pm
Yeah, London area... I think it's actually initial climb at 6000 now, don't know what it used to be. All inbound traffic crawls 1000ft above, and there's no way to separate incoming from outbound. That's why they give high speed so easily - to speed up departures so they can climb as early as possible.
Adam
CosmicCruiser
Re: Flight plans
Sun Jan 05, 2020 9:36 pm
yep! We were always departing STN.
Users browsing this forum: sportzbar and 54 guests
