WPvsMW
Safety stand for wheel change?
Thu Jan 09, 2020 7:42 pm
What's missing from this picture? (no... not underwear coverage)
https://en.wikipedia.org/wiki/Aircraft_ ... 000301.jpg
fr8mech
Re: Safety stand for wheel change?
Thu Jan 09, 2020 8:54 pm
Nothing is missing. We don’t use stands while replacing tires*. Now, I will make a note, that I’ve never, nor would I condone having both nose tires off at the same time, unless we’re in the barn. Though, I don’t think there is a prohibition against it in the AMM. I’ll look tonight.
*as always, I will add the disclaimer that there is almost nothing that is absolute in aircraft maintenance. There may be a requirement somewhere, on some aircraft, that a stand be used. I just haven’t seen it in 30+ years.
strfyr51
Thu Jan 09, 2020 10:15 pm
there isn't anything missing. I used the same type of Jack in replacing 737 200 nose tires, though it must have been on a short turn as It certainly doesn't take 2 guys to change Nose tires. For that matter? Main Tires. I'd bet they have the mains chocked and the Parking Brakes set. I would not have both Nose Tires off with a jetway up or the possibility of a catering or cleaning truck up to the side of the airplane as that could really ruin your day.
fr8mech
Fri Jan 10, 2020 12:57 am
All of our Boeing aircraft have this or some variation of this warning:
WARNING: IT IS RECOMMENDED THAT YOU REMOVE ONLY ONE WHEEL/TIRE ASSEMBLY FROM THE NOSE GEAR AT A TIME. IF YOU REMOVE THE TWO WHEEL/TIRE ASSEMBLIES FROM THE NOSE GEAR AT THE SAME TIME, STRUCTURAL DAMAGE AND/OR INJURY TO PERSONS CAN OCCUR IF THE AIRPLANE FALLS.
The McBoeing and the Airbus do not have a warning, caution or note.
WPvsMW
Fri Jan 10, 2020 1:55 am
Good points... what is missing is one wheel still on the nose gear strut.
fr8mech
Fri Jan 10, 2020 5:10 am
Only if the AMM says one should be there.
Lpbri
I don't see a streamer for the nose gear down knock pin.
Lpbri
Fri Jan 10, 2020 5:16 am
There doesn't appear to be a thread protector on the r/h axle
Fri Jan 10, 2020 8:58 am
The downlock pin could be mounted inside the well, and maybe the streamer is not visible.
basspaul
Fri Jan 10, 2020 3:05 pm
what's missing: a longer shirt or suspenders for the guy on the left! (I too need these at times).
WPvsMW
Fri Jan 10, 2020 6:28 pm
That's called "the plumber look", but was technically excluded from consideration in post #1.
WPvsMW
Fri Jan 10, 2020 6:38 pm
The downlock pin and streamer on all BDs (including the CR700 in the pix) are in a visible location ... but the streamer could be short, damaged, or missing (bad, but not as bad as no pin, and no pin hasn't been ruled out, but staggers the imagination for an AMT working on a commercial a/c).
pdf page 20 (numbered page 1-15) of the TTM for the CR700:
https://www.antndigicast.com/_viddocs/c ... sample.pdf
Here's a BD-700 pix.
https://www.flickr.com/photos/a380spotter/7569281438
Very visible even with the same, high, port-side insertion as the CR700
WPvsMW
Fri Jan 10, 2020 8:21 pm
Is the "flange" in the tire outboard sidewall in that BD-700 pix designed to keep water away from the axle, or does it have a different function? No flange on the inboard sidewall.
Lpbri
Fri Jan 10, 2020 8:35 pm
Just to nitpick further, it looks like they used the torque wrench to loosen the axle nut instead of a breaker bar. The Feds have tagged people for this by watching from the terminal.
fr8mech
Fri Jan 10, 2020 8:59 pm
On the B727 the chines on the tires were designed to keep water spray from the nose out of the engines.
I would images they serve the same function here.
WPvsMW
Sat Jan 11, 2020 9:32 am
The chines are more effective for engines on wing pylons, I would think, than on fuselage-mounted podded engines.
The chines could also keep water off the wings, as in not diluting de-icing fluid on the wings.
fr8mech
Sat Jan 11, 2020 10:02 am
The chines are there to minimize engine water ingestion. Unfortunately, I don't have access to the maintenance manuals or flight manuals anymore. Else, I would post the reference.
You can kind of see it here.
http://www.youtube.com/watch?v=neb1ls2YVzI
Unfortunately, I can't find the videos I saw during training.
Edit: Here you go:
Look at 14:25
http://www.youtube.com/watch?v=uni6HVfthKs
WPvsMW
Sat Jan 11, 2020 6:40 pm
Thanks for that link. Chined tires make quite a difference on the B727 ... but it appears the chines are specific to fuselage mounted podded engines since they displace water away from the pods and toward the wing pylon areas.
Is that a full double-decker model of the B747 in the wind tunnel at 33:43?
A hybrid B-52/747 at 35:35 ... on a leased B-52.
Users browsing this forum: bradyj23, sportzbar and 14 guests
