frostymod
N705CK Evacuation
Wed Jan 29, 2020 3:06 pm
Hello all,
Just curious, how did Kalitta Air manage to evacuate 200 Americans in N705CK, a freighter? Did they have to fit seats in the plane? Are freighters capable of this type of conversion?
Thank you.
Re: N705CK Evacuation
Wed Jan 29, 2020 3:23 pm
frostymod wrote:
Hello all,
Thank you.
I don’t know what they did in this case, however I have seen seats on pallets before that lock into the normal cargo floor.
Used to be QC - quick change aircraft that took seats out regularly to convert between pax, Combi, and freight.
rfields5421
Wed Jan 29, 2020 3:31 pm
I've also seen toilets on pallets, and a small galley unit. Saw those on C-141s - 40 years ago. Dang I'm old.
Not all who wander are lost.
Okie
Wed Jan 29, 2020 4:18 pm
Conrad holds a 747 load of STD's for the 747.
Kit in relation to the 47's load system is one of his major money makers.
Okie
Wed Jan 29, 2020 5:04 pm
Might need to take something for them before something falls off.
Okie
Wed Jan 29, 2020 7:53 pm
Thanks Zeke make that STC instead of something that won't wash off with soap and water. :shock:
Okie
WIederling
Wed Jan 29, 2020 10:10 pm
Murphy is an optimist
BravoOne
Wed Jan 29, 2020 10:51 pm
Wonder how the pax oxygen might work? I have never seen this in the 747 much less any other ac. I suppose you could just keep the cruise alt below FL250 and perhaps that was another reason for the PANC technical stop??
rfields5421
Wed Jan 29, 2020 11:12 pm
Flightaware shows a cruise altitude a bit below FL300. Maybe 270. For both legs WHU-ANC and ANC-RIV.
Aircraft is at FL380 just south of Lake Tahoe headed to SEA right now.
SAAFNAV
Thu Jan 30, 2020 2:45 pm
We carry pax on our L-382's. Seats are on pallets, and underneath each seat there is a portable O2 generator. I'd guess they have the same set-up there. 10min to go from combi to full freighter.
CFI/Gr. III, L-382 Loadmaster, ex C-130B Navigator
BravoOne
Thu Jan 30, 2020 3:17 pm
Thanks, I guess that would make some sense.
FARmd90
Thu Jan 30, 2020 6:00 pm
Would I be right in saying that those seats look/are some old NWA seats?!
BravoOne
Thu Jan 30, 2020 6:41 pm
You are kidding....right?
tb727
Fri Jan 31, 2020 1:20 am
They are very likely old NWA seats. Connie bought 2 pax classics when he bought the freighter fleet so there are probably ~700 seats in Oscoda.
Francoflier
Fri Jan 31, 2020 2:07 am
Interesting setup.
Though I'm curious as to why a passenger aircraft couldn't be chartered for 200 pax.
unimproved
Fri Jan 31, 2020 7:04 am
Francoflier wrote:
Interesting setup.
Likely a case of airlines not wanting to have the responsibility and deal with the aftermath if it does spread inflight.
Kalitta will do anything for money.
rfields5421
Fri Jan 31, 2020 1:34 pm
Kalitta has long had a good reputation for being able to get an aircraft available for very short notice requirements.
Another thought is the isolation point, including separate cooling, heating and ventilation systems.
The cockpit crew was isolated from the pax the entire trip.
Some freighters had been built or converted that way. Mainly to ensure the cockpit crew is not incapicated from smoke and fumes from a cargo deck fire.
I'm not sure the big twin engine jets have that capability.
Wasn't Kalitta the company that figured out how to move an Ebola patient and keep the medical area isolated from the flight crew area?
basspaul
Fri Jan 31, 2020 6:29 pm
unimproved wrote:
Francoflier wrote:
Interesting setup.
Probably alot easier to clean and disinfect as well.
tb727
Fri Jan 31, 2020 7:23 pm
rfields5421 wrote:
No that was Phoenix Air in a Gulfstream.
Cadet985
Sun Feb 02, 2020 6:53 am
Even though definitely an unusual flight, how was it legal to carry that many passengers with no cabin crew?
Sun Feb 02, 2020 6:54 am
Cabin crew can operate on cargo aircraft...
shamrock137
Sun Feb 02, 2020 1:29 pm
Wonder if this was even operating as a Part 121 flight? Might have been exempt depending on how the flight was being flown.
Time to spare? Go by air!
BravoOne
Sun Feb 02, 2020 3:08 pm
That's good question. Suspect you are on to something.
Cadet985
Sun Feb 02, 2020 5:09 pm
You’re right. Some cargo airlines fly with a loadmaster...but the article says that passengers and crew were kept separate.
tb727
Sun Feb 02, 2020 6:50 pm
3 more of his -400's are getting seats for more flights. N713CK just left Oscoda today for ICN.
Cadet985
Sun Feb 02, 2020 8:18 pm
N706CK is also enroute, according to Flightradar24.
dtw2hyd
Tue Feb 04, 2020 12:12 am
Lot of good information here. US ordered four means they are expecting lot more rescue flights.
Are the evacuation procedures same as passenger plane? Number of exits, slides, rafts ...
All posts are just opinions.
aemoreira1981
Tue Feb 04, 2020 2:39 am
There are also old passenger 744s used for parts to maintain the current K4 fleet. K4 is likely the major supplier for 747 parts in the USA. But key here is that these frames were built as freighters from the get-go, meaning the flight deck is likely isolated. The only other real option here is 5X or 5Y 747-400 and 747-8 freighters, but their aircraft are likely already accounted for elsewhere in the workd.
K4 also has previously transported Ebola equipment (via nose-loading); this might be why the US government chartered K4 planes for these missions---prior successful experience in association with Phoenix Air and the CDC,: https://www.popularmechanics.com/flight ... -patients/
Users browsing this forum: No registered users and 31 guests
