Revo1059
777X wing questions
Thu Feb 06, 2020 7:52 pm
If this has been discussed at some point my apologies for a re-post............
So with the folding wings, how does it work procedure wise? Do they unfold the wing tips as soon as they push back or do they have to wait until they get to the runway? If the latter is the case could that cause small delays as they line up and wait for the wings to unfold? Conversely what if they won't fold after landing, are they stuck going to remote parking and using buses because it won't fit in the gate?
BravoOne
Re: 777X wing questions
Thu Feb 06, 2020 9:28 pm
I think there is an "auto-fold" section that retracts the wing tips as you exit the runway. Probably based on ground speed. Obviously if they won't you might not into the original gate assignment. These things work fairly quickly so as they approach the active runway, they are positioned for flight. Don't think the folding wing tips are that big of a deal when looking at the flow needed for before and after flight issues.
zuckie13
Thu Feb 06, 2020 10:16 pm
From what I've read, it takes about 20 seconds for the wing fold down for flight, and would be done when approaching the runway once clear of any obstacles where the extra width is a problem. Probably takes at least 20 seconds from "cleared to takeoff" until the plane is actually on the runway ready to go anyway, so no big deal. The pilots have an indicator to show what position they are in, or if they are in transit, and if they are not down and locked, it will trigger the same takeoff warning alarm they'd get if say flaps weren't out. On landing, they will fold automatically once the speed drops under 50 knots.
If they get stuck, they can go use the A380 gates that will be vacant soon...
DocLightning
Fri Feb 07, 2020 1:08 am
And I'd like to point out that the folding/locking mechanism on the wingtips is much less complicated than the actuation system for the flaps. And yet, we rarely worry about "what if the flaps won't extend/retract?" There have been very few incidents or accidents (yes a few) caused by a failed flap mechanism (typically when that happens it's secondary to another cause such as an uncontained engine failure ejecting debris into the mechanism or a hydraulic failure). It's also much less complicated than the landing gear and while gear retraction/extension failures exist, they are still uncommon.
-Doc Lightning-
-Carl Sagan
Stitch
Fri Feb 07, 2020 1:26 am
Details of how they operate are available in Appendix B at the end of the 777-9 ACAP: http://www.boeing.com/resources/boeingd ... 9_RevA.pdf
With the 777-9 test flights, we have seen the wingtips extend as the plane approaches the active threshold and flip-up on the runway as the airframe decelerates after landing and prepares to vacate the active. The process takes under 30 seconds in each case.
Fri Feb 07, 2020 1:41 am
Prior to the hold short line makes sense. You would normally want to be fully configured for take-off, with the checklist done, before you pass the hold short line. Same as any other airliner.
The ACAP does mention that this is not always possible, so there is an alternate procedure for extension on the runway. You'd have to ask for a short delay in these cases.
crimsonchin
Sun Feb 09, 2020 6:51 pm
Define soon? 10 years? Or do airlines immediately throw away planes once the OEM stops making them.
zuckie13
Sun Feb 09, 2020 7:12 pm
For the love of god, do not interpret my sarcasm literally. If a pinch, they could park at an A380 sized gate - that'll have the clearance needed if the wings don't com up.
Yes, I agree there will be A380s flying for a while, there are already signs that the number is going to begin slowly decreasing - the basic fact that there seems to be no secondary market developing and we're reaching the point where they will be coming off their first leases, is the biggest one.
Users browsing this forum: No registered users and 45 guests
