DFW17L
Wheel retraction question
Fri Feb 07, 2020 9:41 pm
When the wheel's are retracted, and prior to storage, are the brakes applied automatically to stop rotation? Or are the wheels spinning after storage until their momentum ceases?
Dalmd88
Re: Wheel retraction question
Fri Feb 07, 2020 9:45 pm
Yes, the wheel is slowed to a stop by either an automatic hydraulic brake command using the gear retract sequence or by a wear surface in the gear well for nose gear.
Fri Feb 07, 2020 10:26 pm
Adding to this, you have to stop rotation on the mains or the gyroscopic effects can damage the gear mechanism. This is why if brakes are inop on an axle you have to delay gear retraction until the wheels have spun down.
For the nose gear, it doesn't matter, and it has no brakes anyway, so there's a snubber that stops the wheels as it comes in. You can often hear this as a little screech sound in the cockpit.
bradyj23
Sat Feb 08, 2020 3:00 pm
The CRJ 200 didn’t have snubbers. You could hear the nose wheel spinning away for quite awhile after retraction. Snubbers were added on the 700/900.
gregorygoodwin
Mon Feb 10, 2020 6:20 pm
Quite a bit of sequencing goes on with gear retraction and deployment. Although not related to the authors brake question, if the main gear has multiple axles on the bogie beam, such as a 757, 767, etc, the bogie must be centered upon gear retraction to go up into the gear well. This is done by a actuator on the bogie beam.We had one fail on one of our MD10s a few years back. The gear still retracted into the gear well and along the way tore up a lot of structure. Took about two days of around the clock work to get everything repaired and do a gear swing.
Gregory
CALTECH
Thu Feb 13, 2020 5:15 pm
Stopping the mains and all that energy inside the wheel well is a good thing. Gets rid of vibrations too.
You are here.
DH106
Thu Feb 13, 2020 11:18 pm
gregorygoodwin wrote:
.... if the main gear has multiple axles on the bogie beam, such as a 757, 767, etc, the bogie must be centered upon gear retraction to go up into the gear well. This is done by a actuator on the bogie beam.
Not necessarily actively 'centered', the 767 I believe for example has no active bogie positioning other than a passive jack that returns the bogie to it's 'default' nose-down postion when in the air. This came up in a thread a few years ago concerning the 767 retraction dynamics and the necessary 'little door' on the wing top surface that opens & closes during the retraction sequence. Apparently, on the 767 there is no active bogie positioning - the forward sweep of the retraction axis allows alignment of the nose-down bogie into the wheel well.
...I watched c-beams glitter in the dark by the Tanhauser Gate....
fr8mech
Fri Feb 14, 2020 12:08 am
The B767, along with the B747 and the B757, has a gear positioning actuator on each gear. The bogie is not “centered”, it positioned so that it can enter the wheel well without interference. These cylinders are hydraulically actuated.
The little door on above the gear, on the wing, is the result of Boeing having to widen the footprint of the gear, without having to do a major wing and/or redesign. The B767-100 had too high a runway loading for some airports, LGA & SFO, come to mind. By widening the distance between the mains, the runway loading was spread out.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
DH106
Fri Feb 14, 2020 8:14 am
Okay - I stand corrected, the 767 bogie is actively positioned during retraction?
In the previous thread I mentioned one poster stated that the gear retracts with the bogie in it's default nose-down position, with no active positioning for retraction.
fr8mech
Fri Feb 14, 2020 12:10 pm
I guess it depends what “active positioning” means. Once the gear is off the ground, the bogie is automatically positioned at the correct angle to enter the wheel well. If the bogie is not in the proper position, the gear handle will not move from the down position.
DH106
Fri Feb 14, 2020 2:34 pm
I think we mean the same thing here - the bogie is retracted in it's normal 'in the air' position - there is no repositioning specifically for retraction as in some aircraft. The strut used to position the bogie is 'passive' in that it's not sequenced and active part of the retraction process.
kalvado
Sun Feb 16, 2020 1:27 pm
If I remember correctly, A-380-800 doesn't have a full set of brakes on mains. How they handle the free axle?
DH106
Sun Feb 16, 2020 10:42 pm
The brakeless wheel axles are on the body gears which don't change orientation/direction on retraction, so those gyroscopic forces don't come into play.
Users browsing this forum: EssentialPowr, GSOtoIND, Starlionblue and 28 guests
