FriscoHeavy
UA 1123: CPT-EWR Technical Aspects (Paging JayUnited)
Thu Feb 13, 2020 4:03 am
Paging JayUnited! :D
You are very informative on this forum and thought you could provide some insight.
I was hoping you could share some of the technical data for the United 1123 (CPT-EWR) flight as you have for the SFO-SIN, IAH-SYD, etc flights.
Things such as:
-Take off weight (and how close it is to MTOW)
-Fuel load (and how close it is to max fuel load)
-Is it able to take a full passenger load?
-Is it able to carry any cargo?
-Alternate/Diversions airports while out over the Atlantic.
-Any other technical data you wish to add.
I know these are a little different every day, but either an average or the most recent 1-2 flights.
Whatever
N1120A
Re: UA 1123: CPT-EWR Technical Aspects (Paging JayUnited)
Fri Feb 14, 2020 7:05 am
EWR-CPT is nearly 600NM shorter than SFO-SIN, so range likely isn't the issue.
FriscoHeavy
Wed Feb 19, 2020 7:48 pm
Right, which is why I asked about CPT-EWR (westbound against the wind), which can see flight times over 16 hours.
I’m curious about the numbers.
JayUnited - I’ll be on flight 1123 tomorrow (Feb 20th departure). I’d love to know the numbers on the fight once you have access to them.
Whatever
