BWIAirport
Do any airlines use aft-wing exit on the 739?
Fri Mar 06, 2020 3:24 am
Title hopefully self-explanatory. It’s pretty clear from an exterior view that there’s an option for an exit door just behind the wing on the 737-900, but I don’t think I’ve ever seen a door there. It’s usuall just a plug.
Next flight: 6/4 LH401 JFK-FRA A388
6/5 LH260 FRA-GOA CRJ9
*Virus-permitting*
SWA, UAL, DAL, AWE, ASA, TRS, DLH, CLH, AFR, BAW, EIN, AAL | E190 DC94 CRJ2 B712 B733 B737 B738 B739 B744 B752 B753 B762 B77W A319 A320 A20N A321 A333 A343 A388 MD88
AirKevin
Re: Do any airlines use aft-wing exit on the 739?
Fri Mar 06, 2020 5:11 am
I assume you mean the 737-900ER since the 737-900 doesn't even have the cutout for the door and is limited to 189 passengers. As far as the 737-900ER is concerned, any airline that's sticking more than 189 passengers in the plane would have to have that door, so if anyone's using a single-class configuration, they would need it. Think Lion Air.
Captain Kevin
SXDFC
Sat Mar 21, 2020 10:17 pm
Hypothetically if UA or any other airline purchased an ex Lionair -900ER, would they be able to remove that aft exit door and install the plug?
AAMDanny
Sun Apr 05, 2020 9:41 pm
Yeah a maintenance procedure exists to plugging and de-plugging.
For further fun reading, IIRC the door 900ER aft wing exit operates in a very similar fashion of that of a B757/767 variants that have the small aft-wing doors.
Users browsing this forum: BawliBooch, rfields5421 and 39 guests
