crownvic
WN 737 at gate...Tail Stand
Sun Mar 22, 2020 5:09 pm
Never saw this before, taxied to gate last night and the WN 737 next to us at MCO had a tail stand supporting it. Is this normal??
JustAnFO
Re: WN 737 at gate...Tail Stand
Sun Mar 22, 2020 5:29 pm
Only on the -800s.
Dalmd88
Sun Mar 22, 2020 8:37 pm
Yes,very normal. I know DL uses a tail stand on the -800 also and likely the -900. As the cabin empties the rear cargo holds still have almost full loads. It gets a little tail heavy with the nose strut usually fully extended without the tail stand.
N1120A
Sun Mar 22, 2020 11:07 pm
The 900 is worse for this than the 800, but I'd imagine the light loads aren't helping their W&B, so they are being extra cautious. The aft CG of the airplane actually benefits it.
JustAnFO
Sun Mar 22, 2020 11:09 pm
If you are referring to SWA, use of the tail stand is not optional based on loads. Its use is mandatory on all through stops on the -800.
crownvic
Sun Mar 22, 2020 11:31 pm
amazing the dozens of times I fly a year and never ever noticed their use before. Thank you for the explanation everyone.
jetmatt777
Mon Mar 23, 2020 12:18 am
We us tailstands on all 900's at UA. Only for download. For loading it is not required as after fueling the CG shifts far enough forward there is no tipping danger.
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
shamrock137
Mon Mar 23, 2020 10:48 am
Here's what happens if its not used and the aircraft isn't loaded correctly.
https://youtu.be/JLWxD0gY__A
Time to spare? Go by air!
unimproved
Mon Mar 23, 2020 12:59 pm
It's also used on the 747F because of the aft main cargo door.
exFWAOONW
Wed Mar 25, 2020 4:57 pm
Not exactly new. Anyone ever see a 727 parked without the tail-stairs down? You could only do that if there was enough "ballast fuel" in the tank. IINM, strectch DC8s needed a tail stand, too.
Is just me, or is flying not as much fun anymore?
Users browsing this forum: bar1, BravoOne, Caryjack, Dmoney, glen and 18 guests
