Page 1 of 1
Advantages of a pullback vs a pushback?
Posted: Thu May 21, 2020 7:25 pm
by kabq737
Hey everybody
I recently came across this video of a Korean Air 747 being pulled back as opposed to pushed back.
https://www.instagram.com/tv/CAZcFofgQf ... b0bzbvxhdh
Is there an advantage to this sort of thing? How common is it?
Kabq737
Re: Advantages of a pullback vs a pushback?
Posted: Thu May 21, 2020 8:19 pm
by strfyr51
kabq737 wrote:
Hey everybody
Kabq737
It depends on what the need is. the 747 can be moved by towing from the front or pushing from the back. The tug driver? Had better know what they're doing though.
I've done it and seen it done both ways. Especially docking into a Hangar with access scaffolding all around it.
Posted: Fri May 22, 2020 12:29 am
by fr8mech
Really, just different technique. As noted, if towing from below, you can get into a tighter space.
I've found that towing from below is a little quicker, and you don't have very much counter steering to get the aircraft where you want it. You just need to be sure you keep the tug pointed between the wing gear, because you no longer have nose gear visibility, depending on how you set up the tug.
Posted: Fri May 22, 2020 2:29 am
by kabq737
That’s interesting thanks for the answers everyone.
Can all aircraft have a tow bar connected from the rear?
Posted: Fri May 22, 2020 3:15 am
by StereoTechque
Nope not all aircrafts have that luxury.
There is a provision on the A320 MLG so that it can be pulled back in case of NLG overrun.
Posted: Fri May 22, 2020 4:26 am
by vikkyvik
I've never seen this before....kinda crazy!
I'm obviously no expert, but I'd imagine being able to see the nose gear and the airplane, without turning your head back and forth, would be one advantage of a pushback.
Posted: Fri May 22, 2020 4:32 am
by fr8mech
That type of tug can be driven from either end. The way the guy on the video was is doing it was frowned upon by one of my employers. You hooked the aircraft up, then went to the other cab and faced the direction of travel during the actual push.
Posted: Fri May 22, 2020 4:34 am
by vikkyvik
But doesn't that mean you still have to turn around to see the nose gear?
Posted: Fri May 22, 2020 4:46 am
by fr8mech
Yes. But the spots we used this type of push on...in the hangar area...was a quick turn to a straight back push for a hundred yards or so, then stop and drop the aircraft. Spent almost the entire push looking at the main gear.
Posted: Fri May 22, 2020 2:36 pm
by vikkyvik
Gotcha, thanks.
Posted: Sun May 24, 2020 5:18 pm
by DFW17L
I remember when AA used TRs for “pullback” on the MD80s at DFW. The sequence would start with a momentary forward motion, then you’d hear the TRs engage before starting your pullback. Except for the slight forward motion, it was pretty cool.
Posted: Tue May 26, 2020 6:42 pm
by AirKevin
Kind of curious if there's a tug that's small enough to fit under some of these planes, like a 737.
Posted: Tue May 26, 2020 10:24 pm
by strfyr51
No, the belly has to be more than 6' above the ground to even do that, so not may Airliners have that clearance.
Posted: Tue May 26, 2020 10:34 pm
by strfyr51
the tug driver could have driven that TL from either end. while I do not agree with the way he did it? He didn't damage the airplane so? It was ok.
Posted: Wed May 27, 2020 12:33 am
by fr8mech
I don't disagree. Just saying the way he did it was frowned upon by one of my employers. Another employer didn't really address it one way or the other. I've done it both ways, depending on the situation. I just preferred to drive "forward".
If done right, it's perfectly safe.
Posted: Wed May 27, 2020 2:17 am
by StereoTechque
It was called Powerback. Saved a few minutes of time but it is expensive.
Posted: Wed May 27, 2020 3:41 am
by RetiredWeasel
Not really that expensive depending on the price of fuel. Many out stations during my 727 days had limited tugs if you could even get one and my company paid some of these contractors a bunch for pushbacks. Cheaper to do a powerback I was told. Still needed a marshaller and wing walker.
Posted: Wed May 27, 2020 3:54 am
by FGITD
One of the more fun marshalling signals though. Definitely required a little more skill and a quick talk with the pilots. You'd be hard pressed to find a team that would know how to do it these days.
