seagulls2020
Widebody supersonic airliners
Mon May 25, 2020 10:36 am
To make supersonic air travel more economical, would it be possible to make future SST's widebodies with at least 7 economy seats abreast along with modern efficiency cruise technology to lower operating costs comparable to a conventional airliner such as a Boeing 78
Which airlines would operate such aircrafts?
Airliner1973
Re: Widebody supersonic airliners
Mon May 25, 2020 11:03 am
As far as I have understood the issue has more to do with the sonic boom which prohibits SST's to fly faster than the speed of sound in the vicinity of land (or populated area's). So, as long as that is not 'fixed' I don't see any SST flying any time soon . . .
Mon May 25, 2020 11:50 am
There are plenty of routes that are almost entirely over water.
mxaxai
Mon May 25, 2020 12:51 pm
There's two key problems with large SST's IMHO:
1) Wave drag (aerodynamic drag generated by supersonic flow) increases with the thickness of an object. So the optimum diameter-to-length ratio increases; most supersonic aircraft feature this needle-like appearance.
2) Reducing costs is great, but does it get cheap enough to attract enough passengers? That's one of the problems of the A380, it had the lowest cost per seat of any long haul aircraft (except the 777X) but selling enough tickets requires even lower prices.
There's also the general problem of SST's that supersonic wings don't work well for subsonic flight, and subsonic wings are unusable for supersonic flight. Which means that flying long segments subsonic is inefficient compared to regular aircraft, but more importantly requires high takeoff/landing speeds and long runways. You can get around this - partially - by adding thrust, or using variable geometry wings, but a subsonic SST will never match the performance of a regular subsonic aircraft.
seagulls2020
Mon May 25, 2020 7:45 pm
To get over this the plane should have a flatter design and variable wing sweep for better performance is sub/supersonic flight, like in the Boeing 2707 but is 10 economy seats abreast. Imagine even putting a 747-style hump on this futuristic skyship.
Fuel efficiency is important in operating costs. The SST's should possibly be twinjet or trijet as 4 engine planes are failing these days.
Noise can be managed by 21st century aerodynamics along with more streamlined skin of aircraft, possibly inspired of shark skin, like in some car concepts.
744SPX
Mon May 25, 2020 9:54 pm
The 2707 was twin aisle 7 abreast and seated 300 in its swing-wing guise...
TonyClifton
Thu May 28, 2020 7:20 pm
Variable sweep does have aerodynamic advantages, but it massively massively increases weight, complexity, and cost. See how the 2707 morphed from the -200 to the -300 due to those exact issues. Certainly modern technology would better solve some of the associated issues, but it would still be a huge expense on an airline expensive frame.
rlwynn
Fri May 29, 2020 4:34 am
Flatter does mean thinner. People still need to stand up and things still need to go in the bottom. The whole thing just gets larger.
I can drive faster than you
Stitch
Fri May 29, 2020 8:40 pm
In general, the configuration was 2+2 in First and 3+3 in Tourist, but Boeing did also study an "Alternate Body Configuration" for the 2707-100 which became, I believe, standard on the 2707-200 which increased the diameter of the fuselage 12 inches at the maximum cross section area which allowed eight rows of 2+2+2 in Tourist forward of Door 2 and 10 rows of 2+3+2 aft of Door 2 which then became 2+2+2 until the aft fuselage where it was again 3+3.
Users browsing this forum: airtechy, ROSSIGNOL, tnair1974 and 13 guests
