smithbs
DC-10 Weights Over Time
Wed May 27, 2020 4:08 pm
Greetings;
I've been researching DC-10-30 weights and was curious if anyone could please fill in some blanks. Note, I'm specifically looking at DC-10-30 (not -20, -40, etc).
Looking at the DC-10 ACAP, the usual MTOW listed is 555,000 lbs. However, on the payload-range graph, there is a second line for 572,000 lbs, and a note on the graph mentions that it is paired with the CF6-50C1 engine (whereas the 555 klbs line is paired with the CF6-50C engine). I can't find anywhere else in the manual where it talks about the 572 klbs rating.
I was trying to find the date when the 572 klbs rating would have been available. If I assume it coincided with the CF6-50C1 engine, I have some spotty data that shows that engine was delivered in 1978 (line # 248 is the earliest line number I could find with that engine). Of course, it could easily be the case that earlier line numbers had that engine and/or weight rating that I'm unaware of.
We also know that in 1977, the KC-10 contract was signed and would seek a MTOW of 590 klbs. But I don't know if MDD already had this heavy capability in 1977 when they signed the contract, or if it was developed sometime between 1977 and first KC-10 delivery in 1981 (I bet it's the latter). Then we also know that DC-10-30ER was available in the early 1980s with about the same weight rating, probably using the KC-10's technology.
Would someone be able to shed some light on when exactly DC-10s could have carried weights beyond 555 klbs, yet before the final weight of 590 klbs was achieved?
pnut
Re: DC-10 Weights Over Time
Thu May 28, 2020 12:04 pm
Great Post! I am also curious of these details. It sounds like you already know quite a bit about the old girl! Sorry for not contributing, but I hope that this post gets some good info!
"Illegitmi non carborundum"
smithbs
Thu May 28, 2020 5:23 pm
Thanks. It's an obscure topic to try to find out what was going on at Long Beach in the mid/late 1970s. Hopefully we'll get some info.
MO11
Mon Jun 01, 2020 8:00 pm
https://rgl.faa.gov/Regulatory_and_Guidance_Library/rgMakeModel.nsf/0/2cf3306625f6fd1586258281006f6d29/$FILE/A22WE_Rev_13.pdf
Go to page 12.
smithbs
Mon Jun 01, 2020 8:39 pm
Go to page 12.
Hooray, you won the prize! (As soon as I think of what it is...). Thank you very much. And it's also a reminder for me - should have checked the FAA cert. I did that before with 742s - should have remembered.
Thanks again!
Max Q
Tue Jun 02, 2020 9:46 am
Always wondered if the KC10 was / is authorized to a higher ‘ in flight weight only’
For example, taking off with a combination cargo and fuel load them receiving fuel from another tanker taking them over normal MGTOW
GGg
mmo
Tue Jun 02, 2020 10:01 am
If it is not on the data TCDS, it's not authorized. Very simple.
strfyr51
Sun Jun 07, 2020 9:05 pm
since refueling is done in the air? How then would you exceed the max gross takeoff weight? Especially since takeoff is from the ground? All you could exceed?
Is the wing loading weight which is pretty hard to exceed. During certification? I think the DC10-30 took off with close to 700K MGWT. . At United we had the 2 weight version -30's, One was the 555K mgwt and the reset were 572K MGWT. the 555K airplane came from Pan AM via National airlines. the 572K airplanes came from CPAir and a few former Laker airplanes as well, we did have to standardize the Engines as they were all CF6-50's but different versions so we brought them all up to the same standard the same way we brought he JT9D'd all up to -7A power from the -3.
Max Q
Mon Jun 08, 2020 12:14 pm
I believe the KC10 has a 590k MGTOW, my question was whether the AF ever deliberately exceeds this in flight by taking off with cargo, for example, then refueling in flight
Theoretically this would not be exceeding max take off weight, correct, just pondering if they may have a ‘Max in flight weight’
Was there a higher than 572k option available for civil aircraft ?
I thought I had seen a 580k option at one point
Best wishes
GGg
smithbs
Sat Jun 27, 2020 3:36 am
I think some pax DC-10s topped out at 590k in the early 1980s (or at best late 1970s), probably using the KC-10 technology once it was figured out.
B-HOP
Sat Jun 27, 2020 4:12 am
May I also tagged on this post and ask about the useful payload for DC10-30F, with range for about 8 hours, can it get up to 70,000kg?
Live life to max!!!
smithbs
Sun Jun 28, 2020 3:33 pm
If better materials aren't available, I used the airport planning characteristics document (ACAP). It includes a ton of info and payload-range graphs for representative models.
Boeing currently holds the DC-10 ACAP document, and is easily found and downloaded. You'll have to calculate how far a DC-10 flies in 8 hours yourself, and here you could account for headwinds or tailwinds if you are thinking about a specific routing. With your distance and desired payload, put those numbers into the payload range graph and see where it falls.
