Pawel951
A fighter providing support for a commercial aircraft?
Sat May 30, 2020 11:21 pm
Hello, I am a newbie here, so I may say something st*pid – for which I apologize in advance.
I’ve been wondering if it's possible for a fighter jet to be a “backup” for a commercial airplane in emergencies. I do not mean an escort caused by entering wrong airspace, but rather an assistance. For example, would it be possible for a military jet to check if the landing gear was lowered in a situation when the control unit had failed, and the belly of the airplane couldn’t be seen from the ground level due to bad weather?
The story here is that I’m a beginning filmmaker and I was asked to do a little research about movielike events that could have happened in real life, so I’d really appreciate your opinions. Thanks!
Pawel951
Re: A fighter providing support for a commercial aircraft?
Sun May 31, 2020 12:13 am
EDIT: Just to be 100% clear, I meant the landing gear control unit failure with the indicator lights not working.
BravoOne
Sun May 31, 2020 12:14 am
You have been watching To many Bollywood movies. Don't make things worse than they already are regarding aviation and movies or TV.
Sun May 31, 2020 1:22 am
If the visibility is so bad the landing gear can't be seen by the tower, I'd suggest an aircraft in distress should land at a different airport. ;)
To answer your question directly, it seems unlikely that a military jet could provide assistance. I can't recall any specific incidents where this has happened.
Action movie-like events like that are uncommon at best because they are so unrealistic. Commercial aviation is, by and large, rather staid. Hollywood aviation movies tend to be rather far fetched. One of the few exceptions is "Sully", but that incident was one in a billion.
RetiredWeasel
Sun May 31, 2020 2:01 am
While unlikely, it's certainly a possibility if a fighter happened to be airborne in the vicinity of the airliner. Doubt any fighters would be scrambled to investigate.
Weird things do happen. I picked up a T-38 after heavy maintenance in San Antonio to fly back to Reese AFB, TX and lost all my pitot static instruments due to tube separations. It was a Sunday and the only other aircraft airborne in the vicinity was a T-39 with a General aboard. Since I had no airspeed indicator, I joined up on him and he led me down to the overrun for landing with the speed I gave him. He had to do it with his gear up, since my approach speed was higher than his gear down speed.
F-16s were actually scrambled to inspect Payne Stewart's Lear jet after nobody was responding and it's route was off flight plan. Pilots were passed out or dead due to decompression.
To say that a fighter has never ever joined on an airliner to inspect it for damage or gear problems might be a mistake, regardless if I or no others have heard of it.
RetiredWeasel
Sun May 31, 2020 3:57 am
Not quite your scenario with the WX, but you could adapt.
There's no doubt that the F-18 communicated with the airliner regarding what he observed regarding the landing gear.
https://www.dailymail.co.uk/news/article-7961831/Air-Canada-jet-preparing-emergency-landing-Madrid-airport.html
VSMUT
Sun May 31, 2020 7:24 am
That is definitely possible.
Original article: https://check-in.dk/anden-gang-at-jet-t ... problemer/
Translated: https://translate.google.com/translate? ... oblemer%2F
The Air Force sent two F-16 fighters on the wings to perform a visual inspection of the Jet Time aircraft. This inspection revealed that the aircraft had lost parts of the tread on one wheel.
It goes on to mention that the Air Force also assisted with a pair of F-16s during a similar incident in 2008.
In 2011, a pair of Polish AF F-16s also visually inspected the LOT 767 that made a belly landing after the pilots failed to find a popped circuit breaker.
That's less likely. I can't speak for all aircraft types, but the one I fly has 2 indication systems that work independently of each other. Only one set needs to give a correct indication to verify that the gear is down. I would imagine that other types have similar backups. If you absolutely must go through with a technical issue, please take your time to research the details of the type you want to portray and make it realistic.
889091
Sun May 31, 2020 4:05 pm
Helios as well.
http://www.b737.org.uk/helios.htm
Pawel951
Sun May 31, 2020 10:01 pm
Thanks for your time, guys. I appreciate your advices and thoughts!
BravoOne
Sun May 31, 2020 10:11 pm
I'm sure you will find this one interesting :)
https://www.youtube.com/watch?v=AWI3JZvvbI4
MO11
Mon Jun 01, 2020 7:51 pm
Of course you know that movie was the inspiration for the movie, "Airplane!"
BravoOne
Mon Jun 01, 2020 8:00 pm
Yes, but "inspiration" maybe, but pulling it off is a whole different story.
rjsampson
Tue Jun 02, 2020 5:39 am
There's a YouTube video using LiveATC in which an airliner with severe controlability issues in which it was escorted by scrambled F-16 fighters throughout its (ultimately successful) landing. It's late where I am, so I'll get to it tomorrow.
"..your eyes will be forever turned skyward, for there.." yeah we know the DaVinci quote. Unfortunately, we're grounded :(
WYLTK
Tue Jun 02, 2020 8:02 pm
While many replies may lead you to believe this is "unlikely," it's actually quite common.
Infact the very situation you described happened to AC837 in February.
Here you see POKER-81 inspecting the landing gear of said commercial 787-9 the pilot lives in my pueblo ;-)
It's not terribly convenient news material so you don't hear about it often, but it happens.
Pawel951
Tue Jun 02, 2020 8:26 pm
That's enough for us, the filmmakers :D Thanks for your input!
VSMUT
Thu Jun 04, 2020 10:08 am
That's not a 787.
889091
Thu Jun 04, 2020 10:37 am
VSMUT wrote:
That's not a 787.
Probably this incident:
https://nationalpost.com/news/toronto-b ... -in-madrid
The markings on the F18 are a little difficult to make out but the vortex generators on that wing indicates that it is a 767 and I believe AC's fleet of 767 do not have winglets.
Users browsing this forum: No registered users and 17 guests
