Max Q
Maintaining a bare metal / polished aluminum finish
Mon Jun 01, 2020 10:20 am
If this was done properly the result was very attractive and distinctive
AA must have been the industry experts, their ‘Silver fleet’ nearly always looked outstanding
Other operators took delivery of aircraft in bare metal, they looked great at first, NW cargo would be a good example then dulled over the years as I’m guessing they didn’t want to take the time and expense to do the required polishing
Curious as to how this polishing was actually done, how often and what was used in this process ?
Particularly interested in AA and their regimen to maintain this distinctive look across a large fleet
GGg
BravoOne
Re: Maintaining a bare metal / polished aluminum finish
Mon Jun 01, 2020 8:08 pm
When FTL was still around and their aircraft were mostly bare metal they would use a group down in Guam as I recall to polish & buff the airplanes while on a layover.
Even today there are several groups here in the US that will polish leading edge and cowl inlets on corporate aircraft and that is their sole sole business. There is more to this than meets the eye as you can over do it and compromise the metal itself.
i seem to recall that AA used a chemical etch for their aircraft?
Dalmd88
Mon Jun 01, 2020 9:15 pm
A long time ago I worked an ANG contract for Metros. The wings on these were bare and every six months per the contract we had to buff the wings. We had a twin handheld orbital buffer, driven by compressed air. Very similar to the electric ones car detailers use on paint. We used Meguiar's Mirror Glaze compound.
Buffing the underside of the wing really sucked. That buffer got heavy over your head.
GalaxyFlyer
Mon Jun 01, 2020 9:37 pm
I think it was customer option to have matching aluminum panels to have bare metal. Even before all the carbon fiber, different grades/alloys would look different and OEM would charge to have it all.
BravoOne
Mon Jun 01, 2020 11:34 pm
I think that was an old wives tale?
JayinKitsap
Tue Jun 02, 2020 6:14 am
GF I believe is correct. I have not compared polished Aluminum but I have in Silver assembly, had to be very careful to use the highest temperature silver soldiers as the lower ones would shade a bit brown. Even annealed silver and tempered (work hardening at bends) are different. Ornamental metal polished stainless is a bitch because the pipe and plate had different colors even after comparing mil certs to ensure similar nickel and chromium contents. The brushed and satin finishes it usually doesn't show up.
Max Q
Tue Jun 02, 2020 9:22 am
Just to be clear, the polishing is generally done using hand held, orbital buffers ?
The mind boggles at the extent of human labor required to accomplish this on a large airline transport
GGg
strfyr51
Tue Jun 02, 2020 7:46 pm
It's called Matched skins and it was 12% of the build to have them. Last I remember , Later? It might have been much more. Airbus didn't even attempt it.
BravoOne
Tue Jun 02, 2020 8:46 pm
So what are you saying? 12% of all say 707s, 727s, or just AA airframes? I realize that Boeing did a lot customer customization many years ago, but that sounds over the top. Was there an extra charge for this, and how would a casual observer recognize one of these airframes? II can think of several operators that may have been candidates for this, but I'm not sure I would recognize the enhanced skining unless someone actually pointed it out preferably a sise by side comparison.
Max Q
Wed Jun 03, 2020 9:57 am
What about AA’s A300-600R aircraft ?
Originally delivered painted in gray but later those airframes were stripped of their paint and polished
Later deliveries had the matched skins you mentioned I believe, AB found a way of doing this
Looked outstanding on that aircraft as well
GGg
BravoOne
Wed Jun 03, 2020 2:57 pm
I ahve seen the corporate avaition departments use corn starch to maintain the mirror like finish on the cowls and leadings of their ac.There was a SB out many years ago that cautioned against overdoing this polishing as it could lead to structural damage.
Users browsing this forum: Baidu [Spider] and 29 guests
