Max Q
L1011, so many versions ?
Sat Jun 06, 2020 12:29 pm
L1011-1
L1011-50
L1011-100
L1011-150
L1011-200
L1011-250
L1011-500
If I have it right, always found it a bit puzzling there were so many different versions of the Tristar, the DC-10 had the -10 -15 -30 and 40 series, four sub types whereas the L1011 had seven.
GGg
atlamt
Re: L1011, so many versions ?
Sat Jun 06, 2020 1:19 pm
The -1 is the original design.
I’m going off memory so I hope I still remember this stuff.
-100 was an increased gross weight model.
-200 had more powerful engines
-250 had more “upgrades” I can’t remember specifics.
-500 was a shorter fuselage long range model.
Those were all factory built variants.
-50 and -150 were -1 airframes modded after delivery. I know they both increased gross weight but I don’t remember details.
Fwd to MEL and Placard
747classic
Sat Jun 06, 2020 1:41 pm
Because Lockheed indicates most operating weight upgrades by a different version (subtype)
Only the dash 1, 100, 200 and 500 were factory built.
The L1011-50, L1011-150 and L1011-250 are not factory built but only weight upgrades.(with sometimes more powerfull engines to obtain that weight increase)
Both Boeing and McDonnell Douglas are not indicating each weight increase with a new sub-model, the actual operating weights are mentioned in the relevant AFM.
Note : In the Lockheed L1011 Type Certificate A23WE only 4 sub types are mentioned :
L-1011-385-1
L-1011-385-1-14
L-1011-385-1-15
L-1011-385-3
See : https://rgl.faa.gov/Regulatory_and_Guid ... /a23we.pdf
Operating a twin over the ocean, you're always one engine failure from a total emergency.
citationjet
Sat Jun 06, 2020 1:50 pm
The various versions were because heavier, longer range versions were not initially offered. Model changes were required to compete with the DC-10.
A good article that describes the L-1011 variants:
https://aircraft.fandom.com/wiki/Lockheed_L-1011_TriStar
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,73G,738,739;741,742,743,744,747SP;752,753;762,763;772,773,788.
Sun Jun 07, 2020 12:53 am
Another L-1011 version breakdown.
http://aviation.rosboch.net/?p=29
DL_Mech
Sun Jun 07, 2020 3:24 am
IIRC the -50 was a heavier weight landing gear on a late build -1 airplane. The -100 has increased center tank capacity. The -200 is a -100 with -524 engines. The -250 was a Lockheed designed structural mod for late -1 airplanes with Increased tankage over the -100/-200 and -524 engines. The -500 is the short body with -524s only.
This plane is built to withstand anything... except a bad pilot.
Former AMT on A220,A310,A319/20/21,A330,A350,B707,B717,B727,B737,B747,B757,B767,B777,DC-9,DC-10,L-1011,
MD-80/90,MD-11
SheikhDjibouti
Sun Jun 07, 2020 9:47 am
Max Q wrote:
L1011-1
L1011-50
L1011-100
L1011-150
L1011-200
L1011-250
L1011-500
Four? I'm puzzled by that myself.
From another perspective, I see the DC-10 with EIGHT sub-types (one more than the L1011 !)
Here are the missing four;
DC-10-10CF
DC-10-30CF
DC-10-30ER
DC-10-30AF
In truth, in both cases many of the differences between models were hard to identify, and barely justified a new description.
In reality, the L1011 came in two fuselage lengths (hence the L1011-500), whilst the DC-10 came with different wingspans.
The rest is all down to the respective Marketing Depts. :duck:
Then again, what else would us avgeeks have to talk about, eh?
BravoOne
Sun Jun 07, 2020 4:21 pm
As I recall CAL had a couple of DC10-10CFs. Who else has this model?
MO11
Mon Jun 15, 2020 8:29 pm
SheikhDjibouti wrote:
Max Q wrote:
...the DC-10 had the -10 -15 -30 and 40 series, four sub types....
DC-10-10CF
DC-10-30CF
DC-10-30ER
DC-10-30AF
DC-10-10
DC-10-15
DC-10-30
DC-10-40
DC-10-10F
DC-10-30F
DC-10-40F
Any other nomenclature you could scribble on the side of the airplane, but wouldn't be on the Airworthiness Certificate.
vikkyvik
Tue Jun 16, 2020 4:59 pm
Don't forget the center landing gear, which I think was only on the -30 and -40.
Max Q
Tue Jun 16, 2020 5:20 pm
I think there was a difference in fuselage length between the DC10-10 and -30 versions ?
GGg
novarupta
Tue Jun 16, 2020 5:50 pm
All DC-10s have the same wingspan as far as I’m aware, the main differences were powerplant options and weights (with the associated landing gear changes).
L1011-500s did have a slight wingspan increase though.
Polot
Tue Jun 16, 2020 6:13 pm
All DC-10s had the same fuselage length. The variants had differing overall lengths depending on the engines installed though (since the center engine juts out past the the end of the fuselage).
The DC-10-30/40 has a larger wingspan than the -10, by about 10’/3m. As you mention the L-1011-500 also had a larger wingspan than its siblings, by just under 10’/3m.
novarupta
Tue Jun 16, 2020 7:28 pm
Thanks much, I stand corrected
Users browsing this forum: Angelovo, bar11, HowardDGA, jjairbus and 17 guests
