dr1980 wrote:Hello, I’m wondering how incoming aircraft are assigned to an arrival runway when there are parallel runways active for arrivals? Is it based more on what direction they are arriving from, or where they need to go when they get on the ground. Two examples:
- at YYZ, Westjet is generally closer to 05/23 than Air Canada, so would Westjet arrivals be prioritized on 05/23 while Air Canada is prioritized on 06R/24L?
- At MIA, many cargo facilities are located next to 09/27, so would those cargo arrivals be prioritized for that runway?
Or in both cases is it based more on direction of arrival? I guess I’m trying to figure out where the balance of benefit lies between airborne flows and ground flows.
Or perhaps this is very airport dependant and variable?
Thanks for any information.
dr1980 wrote:Or perhaps this is very airport dependant and variable?
MLIAA wrote:DFW works similarly, as does ATL, so I’d assume YYZ would be about the same.
gloom wrote:A few famous examples from Europe:
Munich - similar config with 08/26. They are using the runways depending on departure, to separate flows north/south. Basically traffic south (eg Italy) will get the southern rwy while northbound (say nordic countries) will use northern ones.
hitower3 wrote:In Munich, the runways are specifically assigned for landings (08R and 26R) and departures (08L and 26L).
The reason is that the runways are longitudinally displaced in such a way that taxi times for both incoming and departing traffic are minimized.
e38 wrote:dr1980, I think all the responses above are very good.
With regard to your question, "perhaps this is very airport dependent and variable?" YES.
I am not an air traffic controller, but based on my experience in flight operations at airports throughout the U.S., with reference to your statement, "I’m trying to figure out where the balance of benefit lies between airborne flows and ground flows." In general, under normal conditions, the priority seems to favor airborne sequencing of aircraft, and once the aircraft are on the ground, it becomes up to the ground controller to determine how to get the aircraft from the runway to the parking spot.
Finally, you asked, " At MIA, many cargo facilities are located next to 09/27, so would those cargo arrivals be prioritized for that runway?"
Not necessarily. From my experience operating at Miami, Runway 09/27 seems to be used less often than 12 or 08R, so ATC doesn't specifically sequence cargo aircraft for Runway 09/27; however, if an aircraft requests that runway, it normally is approved. However, if a cargo aircraft lands on Runway 12, it really is not a very long taxi if they are going to Cargo City or the Western Cargo Base.
e38
gloom wrote:dr1980 wrote:Or perhaps this is very airport dependant and variable?
This.
Heathrow - two independent, parallel 09/27. One is arrival, other departure. Both more-or-less equal in terms of runway length, so I think it's workload reduce config that's most usual, 27R arr, 27L dep, or 09L dep 09R arr (IIRC).
dr1980 wrote:Thanks for the information everyone! When I’m flight simming I normally assign myself the runways that selfishly results in the least taxi time, but armed with this knowledge I can try to assign myself runways more realistically.
gloom wrote:hitower3 wrote:In Munich, the runways are specifically assigned for landings (08R and 26R) and departures (08L and 26L).
Thanks for the info. I remember going with my cousin north of 08L (on Besucherhuegel nord) and I believe I've seen both 08L and 08R arrivals (more 08L), and definitely a number of 08L departures. That's what I based my info on. Could it be a preferred setup rather?
Adam
leader1 wrote:All the answers above are all excellent. I am familiar with YYZ ops, so I can comment on those. YYZ often has periods where it's accepting 45+ arrivals in an hour, so you need two arrival runways. Because of the volume, arrivals need to be sequenced accordingly. Those coming from the North and West will use 5/23, and those from the South and East will land on 6R/24L (or 6L/24R, if the outer runway isn't available). So, even though WN's terminal is closer to 5/23, if it is coming in from the South, it needs to be sequenced to land on the runway that's accepting arrivals from there.
During light arrival periods, ATC may accept runway requests since it won't mess up the sequencing. WN will request 5/23 arrivals if they're coming in from the East to shorten the taxi time to their terminal.
YYZ also has noise abatement procedures, which can factor into runway usage decisions, especially at night. So, I notice that they'll land on 24R/L during west flow and depart off 23 and arrive on 5 and depart from 6L during east flow. And because arrival traffic is much lighter at night, they can sequence everything to one runway where it won't cause delays.
When YYZ is running 15L/R or 33L/R ops, it's a different ballgame. Most arrivals land on 15R/33L, but you might have some overflow arrivals on 15L/33R.
