rbretas wrote:First hydrogen must be made cheaper. It costs around 6US$ per KG (electrolysis sourced), while jet fuel is more than 10x cheaper for the same weight (and more than 5X cheaper for energy capacity).
Taxi645 wrote:rbretas wrote:First hydrogen must be made cheaper. It costs around 6US$ per KG (electrolysis sourced), while jet fuel is more than 10x cheaper for the same weight (and more than 5X cheaper for energy capacity).
That's also a chicken and egg thing. Furtermore there's no tax on kerosine.
Electrolyses sourced hydrogen will likely take a huge leap as it is a way to use the future overcapacity of off-shore windfarms and cost of scale effects kick in.
stratclub wrote:IDK the storage pressure for nitrogen, but it would require a really heavy wing to contain it.
Phosphorus wrote:What about jet engines themselves? Is an engine, built for Jet A, capable of running on hydrogen as a "drop-in"?
kalvado wrote:stratclub wrote:IDK the storage pressure for nitrogen, but it would require a really heavy wing to contain it.
Thing is, hydrogen has pretty low per-volume energy density; and both cryogenic ang high pressure (250+ atm to make it practical) require spheric tanks.
So wing storage in a tube+ wing pretty much out of question anyway. BWB _may_ offer more room, but good luck doing TWO significantly new technologies in a single project.
Armadillo1 wrote:wish you be at desk 2 in case of accident
LH707330 wrote:If green hydrogen is 6-10x the price of Jet-A, then you're better off using any surplus wind power to synthesize hydrocarbon fuels or convert biomass into some drop-in fuels.
Sokes wrote:LH707330 wrote:If green hydrogen is 6-10x the price of Jet-A, then you're better off using any surplus wind power to synthesize hydrocarbon fuels or convert biomass into some drop-in fuels.
Once enough money is thrown at it, price will come down. Solar electricity, batteries, mobiles, planes and everything else has/ had a learning curve.
LH707330 wrote:If you had a billion to spend on green hydrogen or SAF, which would get you further? My guess is SAF, based on the fact that you're using existing infrastructure already and the properties of it are nicer than hydrogen.
kalvado wrote:Taxi645 wrote:rbretas wrote:First hydrogen must be made cheaper. It costs around 6US$ per KG (electrolysis sourced), while jet fuel is more than 10x cheaper for the same weight (and more than 5X cheaper for energy capacity).
This is a super-optimistic approach.
As for hydrogen as aviation fuel - it has some very nasty characteristics. Especially in case of emergency, where tank rupture can lead to massive destruction, nothing close to heavier Jet-A. ANd even for just compromized tank - hydrogen flame is almost invisible, and people can run into it. Safe way of walking around hydrogen installations is either checking the path with heat vision, or - on a cheap - wave a wooden stick in front of you as you walk. Stop if wood suddenly catches fire, you got a problem.
If anything, methane is a more feasible thing in forceeable future, and even then net benefit may be low, if not zero, due to tank weignt
Sokes wrote:LH707330 wrote:If you had a billion to spend on green hydrogen or SAF, which would get you further? My guess is SAF, based on the fact that you're using existing infrastructure already and the properties of it are nicer than hydrogen.
Personally I believe that fuels based on sugarcane might be the future for aviation. Either alcohol processed further or synthetic fuel from CO2 from burning the cane after juice is extracted.
I doubt electric and I doubt hydrogen.
But I also doubted solar, so quite likely I will be wrong again.
With one billion one doesn't reach anywhere.
Tens or hundreds of billions have to be spent along the value chain.
But then what else to do with all the wealth capitalism generates?
What is SAF? Natural gas?
lightsaber wrote:Hydrogen and a flying wing is a lot of new technology. You will not see both together until both prove themselves.
Lightsaber
Sokes wrote:Now hydrogen is missing.
Armadillo1 wrote:Sokes wrote:Now hydrogen is missing.
and there a reason for this
Taxi645 wrote:Here is a rough sketch of what the lay-out could look like (span is a bit on the low side).
New hydrogen-powered race series to launch in 2023
Armadillo1 wrote:i dont want to disсuss any topic about current "green energy" prices, because too many interlocutors become liars
better lets return to hydrogenNew hydrogen-powered race series to launch in 2023
https://www.autosport.com/other/news/15 ... ch-in-2023
