Captainjc9
Boeing 737-800NG Flaptrack circle
Wed Sep 02, 2020 10:14 pm
Hi All,
Does anyone know what this is on a Boeing 737-800NG flaptrack? It's a circle that looks like a hatch on the side of the flaptrack. (See picture) Apologies for the bad lighting.
Captainjc9
Re: Boeing 737-800NG Flaptrack circle
Wed Sep 02, 2020 11:40 pm
Captainjc9 wrote:
Hi All,
Captainjc9
I suggest you upload the picture to a free service like Imgur, https://imgur.com/, and then use the embed image function.
Captainjc9
Thu Sep 03, 2020 12:34 am
Starlionblue wrote:
Captainjc9 wrote:
Hi All,
Captainjc9
Apologies! Let me know if the link doesn't work: https://imgur.com/a/PWlNqvQ
Or this link: https://imgur.com/o7sXLwE
DL_Mech
Thu Sep 03, 2020 12:51 am
Captainjc9 wrote:
I believe it is an access panel used to remove bolts that hold the aft part of the fairing on the flap track.
From: http://i.pinimg.com/originals/c9/42/f0/c942f08f46b9a152e4d48360b53f1bba.jpg
This plane is built to withstand anything... except a bad pilot.
Captainjc9
Thu Sep 03, 2020 12:56 am
Thank you so much!! Very helpful information :D
Dalmd88
Thu Sep 03, 2020 10:35 am
If I recall there is also a lube point at the bolts. So it gets removed at every wing lube visit. Same with the little diamond panel in DL_Mech's pic.
slcguy
Thu Sep 03, 2020 12:38 pm
Do access panels for maintenance or inspection really require a thread? All aircraft from basic GA up to top of the line commercial/military have them in one form or another. The location, size and shape are determined by function. In this case would you really want to remove the whole flap fairing just to inspect, adjust or lube a small component?
Max Q
Thu Sep 03, 2020 1:44 pm
A perfectly reasonable question answered
accurately and with great detail and explanation
I don’t understand the objection
GGg
GalaxyFlyer
Thu Sep 03, 2020 7:16 pm
I’m trying to figure what’s so helpful. If it is helpful, he’s a mechanic who should be familiar with the access panels. If he’s not a B737 mechanic, what possible help is knowing it is a access panel. Not like a passenger next to him expects him or her to go out and open it to save everybody’s life.
Reminded of friend who once related he ferried an F-4 back from Thailand and counted something like a dozen switches in the cockpit he had no idea what their function was. “I knew what it took to drop the munitions I used, couldn’t care about about things I had no reason to screw around with.”
Max Q
Thu Sep 03, 2020 8:09 pm
I think you’re overthinking this
It’s helpful that the poster got their question answered, thats pretty much it
GGg
Captainjc9
Thu Sep 03, 2020 10:22 pm
Yes! Thank you Max Q, totally correct. I was purely interested in what the hatch or panel was on the flap track of the 737. Thank you everyone who helped answer my query :)
Captainjc9
Thu Sep 03, 2020 10:31 pm
If you were to ask a question about something on a B737 flap track or wing panel, would I ask why you wanted to know? No. I was purely interested in what that was on the flaptrack, thankyou :)
Max Q
Fri Sep 04, 2020 1:35 pm
You’re welcome and I hope you keep asking questions, don’t be put off by some negative responses
GGg
nonfirm
Fri Nov 27, 2020 8:06 am
I believe the two panels in question are used to remove the middle section of the flap faring when the flaps are not extended to 40.
Checked and Released
