Trimeresurus
Question about autopilot/autothrottle disengagement
Sun Sep 06, 2020 9:55 pm
Why does moving the thrust levers while autothrottle is engaged doesn't disengage it but moving the yoke(beyond a certain tiny point) while autopilot is engaged disengages it?(737NG, but I assume other Boeing and McDonnell/Douglas planes have the same philosophy)
GalaxyFlyer
Re: Question about autopilot/autothrottle disengagement
Mon Sep 07, 2020 1:01 am
I don’t have an explanation, but it’s bad technique in any case.
Mon Sep 07, 2020 3:18 am
At a guess, being able to rapidly disengage the autopilot when pulling can be useful in a situation where stress leads the brain forgetting stuff. Say the autopilot is about to fly you into a mountain.
For the thrust levers, the same level of urgency may not be required. Also, and correct me if I am wrong, on Boeing if you move the thrust levers this overrides the autothrottle setting anyway until you let go again.
TonyClifton
Mon Sep 07, 2020 3:36 am
Same on the ERJ-170/190. The A/T system is very sluggish, so you’ll end up overriding on approach on any day without calm winds. I called it “student pilot mode” when it would be bouncing between +/- 10 REF.
Max Q
Mon Sep 07, 2020 5:05 pm
Correct
It’s not good technique to make manual inputs to the AP or AT when they’re engaged anyway, instead of attempting to override them they should be disconnected if one or both is not doing what you want it to do
The 757 AT could be ‘lazy’ at high altitude when you were close to your weight limits
and would occasionally reduce thrust too much resulting in speed getting too slow, by the time it would correct itself even full power would not recover the lost airspeed
In that case you might override the AT if it attempted to reduce power excessively, it also didn’t always cope well with mountain wave activity, not reacting quickly enough to airspeed changes, once again you might override them in that case but carefully
You need to understand why they are making those inputs and not override one that’s necessary!
GGg
fr8mech
Mon Sep 07, 2020 8:26 pm
Some time ago I was jumpseating on an MD11 and while descending, all the way through the approach, the captain would continue to bring the throttles to idle, or near enough. While on final, he mentioned to the FO that “he hates when it does that”.
Being in maintenance, after the flight I asked him if it was a problem with the aircraft. His reply was “nope, I just don’t like the way the airplane flies the throttle.”
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
Max Q
Mon Sep 07, 2020 9:23 pm
Not familiar with the MD11 auto flight system but in certain descent modes the 757/ 67 AT will not reduce thrust all the way to idle
VS is rarely used but it will not go all the way to idle and FLCH may not if the altitude change is minimal (forget the exact numbers)
So pulling them back to idle manually from slightly above is not uncommon
GGg
CosmicCruiser
Tue Sep 08, 2020 12:10 am
I never saw a problem with the MD-11. The MD-10 sucked on landing and the flair. I always disconnect the A/T on landing. I would always disconnected the throttles on gusty x-winds on both.
Users browsing this forum: No registered users and 25 guests
