Trimeresurus
How are regional airliners delivered to the other side of Atlantic?
Tue Sep 08, 2020 9:23 am
Like MD80s, Embraers. Do they have removable fuel tanks just for the delivery flight?
pythoniels
Re: How are regional airliners delivered to the other side of Atlantic?
Tue Sep 08, 2020 9:31 am
I know for the KLM Cityhopper fleet that got delivered, they took of and refueled at BSB and then flew directly to the Canary Islands for another refuel and then Straight to AMS.
Otherwise Canada/Greenland//KEF/Dub stops seem to make sense.
VSMUT
Tue Sep 08, 2020 9:38 am
The Atlantic is small. Most regional airliners can get across with just one fuel stop in Greenland or Iceland.
konrad
Tue Sep 08, 2020 10:11 am
Embraer routing to Europe: SJK-REC-SID-AGP-WAW
http://www.gcmap.com/mapui?P=SJK-REC-SID-AGP-WAW
dergay
Tue Sep 08, 2020 10:53 am
KLM delivery through FAO on 15th March, 2018.
https://www.flickr.com/photos/[email protected] ... 278918033/
BawliBooch
Tue Sep 08, 2020 11:26 am
I guess extra bladder type tanks should get the plane across.
In any case, Atlantic is still bridgeable with many stops available on a northerly route.
I wonder how airlines in the Pacific ocean like Tahiti Airlines/ Aloha etc get their short range aircraft to and fro from the mainland.
dergay
Tue Sep 08, 2020 11:31 am
To answer your question, this is a J-Air (J.A.L.) EM-170 on delivery from Brasil via LCA - yes Larnaca, Cyprus.
https://www.flickr.com/photos/[email protected] ... 4ZL-fppKum
How far East is West?
BawliBooch
Tue Sep 08, 2020 11:34 am
How would an airline like Aloha get their 737-200 to the mainland for a major maintenance check? Hawai, Tahiti etc are a long way both from Asia and US mainland?
tommy1808
Tue Sep 08, 2020 11:35 am
since their ATR have ETOPS 120 min they should be able to fly them there.
best regards
Thomas
djb77
Tue Sep 08, 2020 11:46 am
Widerøe's Embraer E190-E2 were delivered direct from Brazil to Norway with a single stop in Las Palmas, Gran Canaria. A second, provisional refueling stop in Aberdeen, Scotland, was scheduled but not required. Although the aircraft were void of passengers, baggage and cargo, this is still pretty good-going.
PlymSpotter
Tue Sep 08, 2020 11:49 am
I recall reading an article about Hawaiian's B717s - they were fitted with a pair of large tanks in the passenger cabin for the ferry flight.
MIflyer12
Tue Sep 08, 2020 11:51 am
Absent passenger and bag weight, RJs have meaningful range. They don't need typical passenger routes, as the citation of SJK-REC-SID-AGP-WAW demonstrates.
airbazar
Tue Sep 08, 2020 12:49 pm
Tahiti is not that challenging. There are lots of island hopping options to get there:
http://www.gcmap.com/mapui?P=pom-hir-hi ... =wls&DU=nm
tommy1808
Tue Sep 08, 2020 12:53 pm
NightStar wrote:
The Atlantic is "small!!??" Are you serious??
It is the world's second largest ocean in area. The Pacific is not even close to doubling it at only roughly 50% larger. The Pacific is wider but there is nothing small about the Atlantic.
east <-> west the shortest hop across the Atlantic is less than 3000 km. Compared to the pacific it is kinda narrow, but of course not small in surface area.
best regards
Thomas
B777LRF
Tue Sep 08, 2020 1:14 pm
ATR delivers their by air; you might be surprised how far a -600 will go when there's no payload at all on board, the crew is only 2-4 people, and a routing that's quite often off the beaten tracks allowing for optimum speed; 8-9 hours, easy. According to this story, it'll do 5,5 hours / 1400 nm with a football team onboard! viewtopic.php?t=593431
VSMUT is absolutely correct; most regional airliners (built either side of the pond) can make the crossing with one fuel stop. Can't say the same for the Pacific.
In aviation terms, precisely because it's relatively narrow, an Atlantic crossing is considerably smaller than a Pacific ditto.
There is a reason the Pacific wasn't crossed until 1931, when the Atlantic had been won in 1919.
GalaxyFlyer
Tue Sep 08, 2020 2:19 pm
I saw a mere “slip of a lass” pickup a new Cessna 152 and fly it to Iceland. Ferry tank and survival equipment added at KBGR. Fly the Pacific for awhile and the North Atlantic seems like a wide river. They ferry DHC-6-400 all over the world, mostly without ferry tanks. Lots of tech stops across Canada, Greenland, Iceland and Scotland for short range planes.
VSMUT
Tue Sep 08, 2020 2:53 pm
best regards
Thomas
Do ETOPS rules apply to delivery flights? Isn't it commercial operations only?
GalaxyFlyer
Tue Sep 08, 2020 3:38 pm
Just commercial flights, delivery is private ops.
nicode
Tue Sep 08, 2020 4:18 pm
ATRs for Air Tahiti are routed through Asia, not America.
Most of ATR are delivered this way : Toulouse (France) - Alexandria (Egypt) - Al Ain (UAE) - Chennai or Nagpur (India) - Kuala Lampur (Malaysia) - Kupang (Timor Oriental) - Cairns (Australia) - Nadi (Fidji) and then Papeete (French Polynesia).
https://www.facebook.com/AVgeeksTahiti/ ... =3&theater
clipperlondon
Tue Sep 08, 2020 4:33 pm
Surely its just a matter of scale?
I don't know the exact mileage but island/mainland hopping is common.
Interesting route details, thank you very much!
enplaned
Tue Sep 08, 2020 4:46 pm
best regards
Thomas
MD-80s across the Pacific could go one of two ways - in the summer time via ANC - e.g. Japan-ANC-lower 48. With no load (other than ballast up front), they had considerably more range than with loaded.
In the winter, you can go via Midway Island and Hawaii. Again, an unloaded MD-80 (other than nose ballast) could easily do the Hawaii-Mainland leg (though bear in mind, I think that's in the direction of the prevailing winds).
I don't recall them needing an aux tank to do this.
clipperlondon
Tue Sep 08, 2020 4:53 pm
best regards
Thomas
Thats what I meant, thank you . Plenty of islands and hugging the coast is also a consideration too
N1120A
Tue Sep 08, 2020 8:00 pm
With favorable winds, 737s have been delivered non-stop from Seattle to Europe. Something like a CRJ shouldn't have an issue getting across from Montreal, either with a stop in the Maritimes or in Iceland or maybe non-stop. Going West, something like an ATR will probably have to stop somewhere, but still not really an issue.
hongkongflyer
Wed Sep 09, 2020 2:56 am
I remember some E170/190 were delivered to China via Europe and Mid-East
VSMUT
Wed Sep 09, 2020 9:49 am
An ATR should be able to go non-stop from Ireland to Canada. It has fuel for 9 hours. In zero wind conditions, it will "only" take 5:30. Even with todays headwinds, it would take 7 hours.
bhill
Thu Sep 10, 2020 6:11 pm
They are stuffed in GalaxyFlyer's ride and shuttled over....pretty sure they use aux tanks in the cabin to haul the fuel needed for the trip, some seats will need to be removed....
GalaxyFlyer
Thu Sep 10, 2020 7:54 pm
The only planes I ever moved was a wrecked Strike Eagle out of EGUL, but there was a “sled” like device to deliver T-38/F-5s. Lots of helicopters, dammed every one leaked fuel, too. Boats leaked salt water, but that was corrosive, not explosive.
Oh, I forgot, I brought the US Aerobatic from KDOV to ETAR (Ramstein) during the 90s for the WAC. 8 planes filled up the cargo with a weight of about 12,000#. Then, there was the NatGeo sponsored Vickers Vimy brought from Travis to Mildenhall for its flight to Asia.
Trimeresurus
Thu Sep 10, 2020 9:28 pm
I thought Jet A-1/kerosene wasn't very explosive, being in similar texture and molecular structure to diesel and all. It's hard to accidentally light it on fire, you have to try.
GalaxyFlyer
Thu Sep 10, 2020 10:00 pm
It’s not explosive, intended as a hyperbolic comment opposing salt water.it. Both create clean up problems and fuel does give off some nasty fumes in an enclosed environment.
tnair1974
Sun Sep 20, 2020 10:39 pm
Yes. Decades ago, Aloha and Hawaiian were doing this with their 732s and D95s respectively. Not only for delivery, but ferry flights back to the mainland for heavy maintenance.
An interesting side note is that when Hawaiian replaced their D95s with 717s, something along the lines of one less portable tank was needed due to the 717's improved fuel efficiency.
rmoore7734
Mon Oct 05, 2020 3:22 pm
BawliBooch wrote:
http://www.gcmap.com/mapui?P=hnl-mdy-adk-anc-pae&DU=nm
Max Q
Mon Oct 05, 2020 9:14 pm
Impressive stuff, it’s one thing to ferry twin engine airliners but a single engine piston stuffed with fuel in every nook and cranny with very low cruise speed, limited altitude capability and little if any anti-ice protection is another, entirely different prospect
Very long flight times, cramped cabins and little chance of rescue if that one engine fails require a whole different, somewhat fatalistic attitude for the job
GalaxyFlyer
Mon Oct 05, 2020 9:21 pm
Then talk to the Kenn Borak pilots out of Calgary and their flights to Antarctica in a Twin Otter. I interviewed one for a job with our department. The old TMAAT question, “we’d landed on an island off Antarctica in blinding snow and ice coming from Chile. For three days, the weather continued as we camped in the plane. Finally, the captain decided we’d try to leave even though the weather hadn’t changed much. I refused to fly, the next day it cleared.” My boss looked at me and simply said, “well, he certainly won’t be pushed into a bad decision staying in Paris, if he’ll stay on a frozen island.”
sjones1975
Wed Oct 07, 2020 3:47 pm
Are there any particularly remote places where aircraft are delivered by ship, either by necessity or for economic convenience (e.g. to avoid the cost of adding temporary fuel bladders)? If so, what's the largest type of aircraft that has been delivered by ship? Would ship delivery only be for very small stuff like GA kits, or do aircraft as large as a turboprop commuter aircraft ever get delivered by ship?
GalaxyFlyer
Wed Oct 07, 2020 6:13 pm
Only for very small GA planes and not even a lot then. There’s a pretty good business of ferrying even small-ish single-engine planes around the world. DHC-6-400 are delivered by air everywhere. Single-engine Mooneys, Cessnas and Pipers have been ferried from US to Australia and NZ.
VSMUT
Wed Oct 07, 2020 7:21 pm
I've seen a break bulk carrier full of MiG-29s. The entire fleet of the country was simply lifted into the cargo hold and strapped to the deck, then shipped off to be upgraded in another country.
Helicopters often (mostly?) go by ship. Smaller types fit in a container.
SoCalPilot
Thu Oct 08, 2020 1:26 am
Don't know if they still do but Mokulele use to ferry their Cessna 208's from Hawaii to California. 10+ hours in a small Caravan over water the whole time. No thanks.
GalaxyFlyer
Thu Oct 08, 2020 3:05 am
Certain diplomatic complications ferrying MiGs around, so yes, shipped. Helicopters just aren’t possible to ferry overwater legs, ferry tanks or not.
CRJ900
Thu Oct 08, 2020 10:09 pm
I think I read here on a.net that the Dash 8-400 (formerly known as Q400) can fly about six hours non-stop on ferry flights, which sounds about right with 5,500 kg of fuel in standard wing tanks and burning about 850-900 kg pr hour.
paperwastage
Thu Oct 08, 2020 11:09 pm
https://www.staradvertiser.com/2018/02/ ... -to-china/
https://onemileatatime.com/united-regional-jet-china/
this happened too (Colorado-Seattle-Anchorage-Anadyr(Russia)-Magadan(Russia)-Vladivostok(Russia)-Hohhot(China)
Web500sjc
Fri Oct 09, 2020 4:29 pm
https://thepointsguy.com/news/air-green ... op-flight/
Air Greenland flew a DHC-8-200 7 hours and 52 minutes from CPH- Nuuk Greenland on a revenue flight in April 2020. 2 pilots, 1 FA, and a doctor, who was the only passenger, were all that the airplane carried in addition to fuel. Granted the flight was originally planned with a fuel stop in KEF, but they were able to make it nonstop.
FlyHossD
Fri Oct 09, 2020 4:55 pm
IIRC, when we ferried new ATR-42s to the U.S. bases, it was TLS, SNN, REK, BGR then on to the appropriate hub. The only additional equipment was a single HF radio and a life raft in the forward cargo area. Once in the U.S., the HF radio and raft were removed and sent back to TLS for the next ferry.
So as not to get another post deleted as not on topic, I won't tell a story or two about such ferry flights.
sjones1975
Fri Oct 09, 2020 6:18 pm
Oh come on, that kind of stuff from pilots and industry insiders is what makes this site interesting!
FlyHossD
Fri Oct 09, 2020 7:35 pm
But's it's also apparently what offends at least a few...
SAAFNAV
Sat Oct 10, 2020 6:58 am
Contrary to popular believe, one has no obligation to prevent others from their perceived offensive 'triggers'.
They are welcome to skip over it, the rest of us would love to read it.
Nicoeddf
Sun Oct 11, 2020 12:10 pm
That’s true until the trigger (delete-) happy mods come to call you to order. ;-)
That said, FlyHossD, I think some stories about those ferry flights would certainly fit into the topic on hand without risk of deletion, even on this site.
AirBoat
Mon Oct 12, 2020 11:23 am
The SAAF Gripens were put on a RoRo ship in Sweden and offloaded in Cape Town, and then towed along the city streets to afb Ysterplaat, with a mechanic sitting on each wingtip to look out for lamp poles.
Ferrying military planes is very difficult.
AirBoat
Mon Oct 12, 2020 11:27 am
there is a foto at article below:
The SAAF receives Gripens 17-19
Written by Dean Wingrin & defenceWeb -11th Apr 2011
SAAFNAV
Tue Oct 13, 2020 6:46 am
I was stationed at AFB Ysterplaat when the last of the order was delivered. It wasn't a RO-RO ship, but a normal bulk carrier with the trestles welded to the floor.
Some photos:
(note: photos was from the PR section of the base)
flyingturtle
Tue Oct 13, 2020 9:15 am
Some C-47 were delivered to the Soviet Union in WW2. I don't know their route, though. Later, the Soviets built lots of copies (Lisunov-2) under license.
Users browsing this forum: Duderocks5539 and 15 guests
