mxaxai
Why no more multi-slot flaps?
Thu Sep 10, 2020 12:45 pm
Old airliners usually had multi-slot flaps. I think one of the first large aircraft with just single-slot flaps was the A320. Even some new models introduced in the 90s had multi-slot flaps, e. g. the 737NG and the 777. Airbus only added multi-slot flaps to the A321 later (which is reverting to single-slot for the XLR) and has used single-slot for everything else.
Nowadays, almost all new aircraft feature single-slot flaps. Even the 777-9 got some, and the 747-8 went from triple-slot to double-slot.
What has changed that makes multi-slot flaps obsolete? New airfoils? Better knowledge of flap design? Longer runways?
Could Boeing switch the 737 wing to a single-slot design (like Airbus is doing for the A321)?
tommy1808
Re: Why no more multi-slot flaps?
Thu Sep 10, 2020 1:24 pm
i guess guestimate a combination of those with better manufacturing tolerances and surface quality.
best regards
Thomas
Thu Sep 10, 2020 2:07 pm
Vastly more powerful computational fluid dynamics have enabled much better modelling of airflow. This has led to the ability to design much more optimised airfoils.
Drooping ailerons have taken over some of the high lift workload.
New flap design features like the Airbus Adaptive Drooped Hinge Flap have been introduced. The spoilers deflect down to close the gap to the flap leading edge.
Longer runways are not really a factor. Runway performance is better now than 50 years ago, though some of that is due to more powerful engines.
Okcflyer
Thu Sep 10, 2020 3:39 pm
Single slot designs are lighter (less pieces, less material), cheaper, and less maintenance long term. They are the strong preference if the performance required can be achieved.
mxaxai
Fri Sep 11, 2020 11:39 am
Interesting. I did not know that the effect of adaptive spoilers was this large. Would it be correct to assume that this requires FBW (at least for the spoilers) since traditional methods have separate controls for spoilers and flaps? The 737MAX has FBW spoilers (viewtopic.php?t=773287), so I suppose they could use it to improve runway performance.
Does this imply that the original 777 wing was a conservative design? It's the only modern widebody with double-slot flaps, and also the only one to receive wingtip modifications within a few years after EIS. I guess this also made it worthwhile for Boeing to develop an all-new wing for the 777-9.
Interesting to note, the E-170/175 and E-190/195 both have partially double-slot flaps. However, the E-170 has the double-slot on the outer segment, wheras the E-190 has the double-slot on the inner segment. The E2 - much like the 777-9 - got a new wing and single-slot flaps.
unimproved
Fri Sep 11, 2020 12:19 pm
The 777 is still an 80s design, computing power massively increased in the decade after it was designed.
OldAeroGuy
Fri Sep 11, 2020 2:43 pm
The 777 Classic has double slot inboard flaps. The outboard flap is single slot.
It has a design heritage related to the 767.
Reduction of flap slots helps approach noise by reduced landing flap drag (less thrust required) and less airframe noise (slots whistle).
As Starlionblue describes, using the spoilers to control flap slot geometry and drooping the ailerons greatly improves flap performance for later FBW airplanes such as the A350, A380, 787 and 777X.
Horstroad
Sat Sep 12, 2020 2:36 pm
FBW is not required. The MD11 lifts the spoilers slightly when the flaps are extended to prevent the upper surface of the flaps from rubbing on the spoiler trailing edges. The spoiler bias is linked to the aileron lockout system and purely mechanical with cables, pushrods, linkages and some black magic in the spoiler mixers.
AirKevin
Sat Sep 12, 2020 8:42 pm
Just to clarify, the 747-8 has double-slotted inboard flaps. The outboard flaps are single-slotted. Same with the 767 and the 777.
Captain Kevin
crimsonchin
Sat Sep 12, 2020 9:42 pm
Seems like with the exception of the A321, Airbus has preferred the single slotted flaps from the start for all their planes?
texl1649
Tue Sep 15, 2020 12:20 am
Their first designs/widebodies (A300/A310) weren’t really heavy for the time; light twins, for relatively shorter routes. The next generation were essentially a half generation after the 777.
It’s amazing how well they did with the A320 wing design, which imho ranks up there with the 787 one as among the greatest of the past 40 years.
WIederling
Tue Sep 15, 2020 9:25 am
A progression of improved supercritical designs starting with the first A300 wing progressing quite a bit with the A310 wing.
Then A320, A340/330, A380 lastly A350.
and a drive towards clean wings with closed flaplines. ( no thrust gate or similar discontinuities.)
The A340/A330 wing predates the 777 by a couple of years ( mid 80ties to early 90ties.).
Going by a NASA report neither the 777 wing nor the 737NG wing reach the aerodynamic achievements of the airbus products.
The 787 seems to be the earliest comparably capable design.
supercritical design property:
traditional profiles show a lift concentration in the first third of the wing area.
evening out the lift distribution over much more of the wing area to avoid going transsonic in the airflow
should allow higher wingloading for the same wing real estate.
Murphy is an optimist
Wacker1000
Tue Sep 15, 2020 9:30 am
It isn't a case of single vs multi. They had to get more flap into an existing area and adding the tab was a way to do it.
LH707330
Wed Sep 16, 2020 1:45 am
Do you have a link to that NASA report?
TTailedTiger
Wed Sep 16, 2020 7:11 am
I thought the wing of the 737NG being newer than the A320 was one reason why the 738 outperformed the A320 on transcontinental flights? I'm not sure how you can claim the A320 wing is superior. It all depends on which details you are looking at.
tommy1808
Wed Sep 16, 2020 10:23 am
Nope, the reason why the NG outperformed the A320 on that mission is ~3000L more fuel volume.
I'm not sure how you can claim the A320 wing is superior. .
because it is supercritical vs. only being partially supercritical on the NG (and 757/767). Iirc the wing root still got a conventional airfoil.
best regards
Thomas.
WIederling
Wed Sep 16, 2020 4:24 pm
one ref:
https://www.nasa.gov/pdf/89232main_TF-2004-13-DFRC.pdf
89232main_TF-2004-13-DFRC p3 wrote:
Boeing's 757 and 767 jetliners, and the new
generation of 737 aircraft, also have wings designed
with some form of applied supercritical technology
In a way semantics what is tagged as "supercritical wing".
Only full hog acceptable or just steps in the right direction?
Beginning with the first research from Göttingen during WWII
continued in Britain long before that NASA guy invented it anew
this feature has been developed in a long progression.
This is a bit like the laminar flow nacelle for the 787:
Extending laminar flow from ~~25% along the nacelle
to slightly beyond 30..% created a
"(fully?) laminar flow nacelle, a global first on Dreamliner" in PR parlance.
LH707330
Thu Sep 17, 2020 12:04 am
Thanks, I'll take a gander at it!
tomcat
Thu Sep 17, 2020 3:15 pm
The A300 and A310 wings also had less sweep (28°) than their closest Boeing equivalent, ie the 767, which had a 31.5° sweep. Less sweep is beneficial for the low speed characteristics and that helps to keep a simpler flap design (other things being equal).
N1120A
Thu Sep 17, 2020 7:29 pm
The 738 is a larger airplane that holds more fuel, but has similar costs and burn. That is why it outperforms the A320.
LH707330
Thu Sep 17, 2020 10:42 pm
I checked out the report you linked, but could not find a passage about the respective comparisons on these designs. You recall where else you may have seen it?
744SPX
Fri Sep 18, 2020 1:23 pm
The 747SP has single slotted flaps
ElroyJetson
Fri Sep 18, 2020 3:04 pm
As I recall triple slotted flaps on the 727 were mostly about field performance as the 727 was replacing many turboprops (Electra as an example) that did not use long runways. I know Eastern told Boeing in order for them to purchase the 727 it must be able to take off from LGA with a full load. Those Krueger flaps were complex but worked beautifully.
Today engines are more powerful, runways are often longer, and wing performance has greatly improved. Why add the complexity and weight of it is unnecessary.
707 717 727 72S 737 733 737-700 747 757 753 767-300 764 A319 A320 DC-9-10 DC-9-30 DC-9-50, MD-82 MD-88 MD-90 DC-10-10 DC-10-40 F-100
GalaxyFlyer
Fri Sep 18, 2020 3:10 pm
The only reason for triple-slotted flaps is field performance. KLGA didn’t have the runway pier extensions then, either.
DH106
Fri Sep 18, 2020 3:13 pm
The Krueger flaps are actually quite simple, on the inner leading edges. Are you referring to the triple slotted trailing edge flaps perhaps?
...I watched c-beams glitter in the dark by the Tanhauser Gate....
ElroyJetson
Fri Sep 18, 2020 3:26 pm
Yes, I mentioned the triple slotted feature and that is what I was referencing. Some dubbed it the canoe for how it folded out at full extension. And the poster above is correct, initially the triple slotted wing feature was all about field performance.
A standard runway length for many airports in the 1960's was around 5500 ft. With existing engine tech of the era a single slot design on a 727 would not have worked to get it in the air with a full load. The Krueger flaps were an ingenious solution. Now most intermediate airports have a 9000 ft runway so field performance, along with improved wing and engine tech is not so much an issue.
ElroyJetson
Fri Sep 18, 2020 3:33 pm
I have never heard this. I do not disbelieve you but I would love to see the data. I know the 707 had a more efficient wing than the DC-8 which is why it ultimately sold better. But that was not fully known and understood until quite a few years after EIS.
If the A320 family has a more efficient wing it is not reflected in fuel burn as both the 737 NG and A320 are extremely close depending on mission. Anyway, I would love to see the data.
Regards.
WIederling
Sat Sep 19, 2020 10:06 am
NO comparison.
Statement about Boeing details only. ( elements of but not fully.... )
mxaxai
Sat Sep 19, 2020 11:20 am
That's a good point. The original 777 had a sweep of 31.6°, which is reduced to 28° for the 777X. The A380 also has less than the 747 (33.5° vs. 37.5°), and the A350 has slightly less than the 787 (31.9° vs 32.2°). So one could argue that modern supercritical airfoils allow for less sweep at the same cruise speed, which improves low speed characteristics and flap design. On the other hand, both the A350 and 787 went up compared to their predecessors (the A330 has 29.7° and the A340NG got pushed to 31.1°).
However, the 737 and A320 both feature a sweep of 25°. The 737 prior to the NG had triple-slot flaps whereas the A320 had single-slot flaps already in 1988. That's less than the 727 at 32° - which was built for high cruise speed and short runways - but it still doesn't explain why the 737NG retains a relatively complex flap design.
WIederling
Sat Sep 19, 2020 4:01 pm
ref: https://forums.x-plane.org/uploads/mont ... db4340.jpg
not in every case. :-)
( on the 747 this seems to have been a rather complex design.)
tomcat
Sat Sep 19, 2020 5:48 pm
Besides the wing aerodynamics optimisation comprising the airfoil selection, the slats and flaps kinematics and the quality of its surface finish, I would list the following factors driving the flaps design:
- the wing loading
- the wing sweep
- the aircraft thrust to weight ratio
- the targeted takeoff and landing performances
- the available angle of attack upon takeoff and landing
These factors are all interdependent and are the results of tradeoffs carried out during the early design phases.
I don't have an table available to compare all these factors for all the aircraft you mentioned but on top of my head I would say that the 737 starting from the -400 and longer is penalized by its low landing gear which limits the angle of attack during takeoff and landing. This is probably one of the reasons, if not the main one, explaining why the NG retains this fairly complex flap design.
GalaxyFlyer
Sat Sep 19, 2020 8:57 pm
Another comparison in high-end Bizjets. The G650 uses a rather simpler wing generous wing area and single slotted flaps, no slats. The Global 7500 uses more sweep,slats and double-slotted flaps that extend aligned with the flow rather than normal to the sweep angle to achieve somewhat field and cruise performance at 10,000 pounds heavier gross and a heavier wing loading. It is all about trade-offs.
WIederling
Sun Sep 20, 2020 8:09 am
A comparative look at high lift devices and arrangements, unfortunately ending in 1996:
https://ntrs.nasa.gov/citations/19960052267 ( go for the pdf download link at the bottom. )
Users browsing this forum: No registered users and 37 guests
