Trimeresurus
Are cargo doors of passenger aircraft operated from the outside?
Wed Oct 28, 2020 10:29 pm
Do they have a switch that the ground crew use to open them? Can it be overridden from the cockpit? What are the conditions necessary for the cargo doors to be available to open?
Horstroad
Re: Are cargo doors of passenger aircraft operated from the outside?
Wed Oct 28, 2020 11:36 pm
No doors (except for the APU inlet and exhaust doors, if installed) are controlled (or overridden) from the flight deck. Cargo doors are always operated by the ground crew from the outside. An exception would be main deck cargo doors on freighter aircraft, which have the controls usually in the main entry door area and/or next to the main deck cargo door. Cargo doors usually use ground handling or ground service power. The cabin needs to be unpressurized, otherwise it is impossible to open the vent door which is usually connected to the door locks, which would prevent the door from being opened.
Cargo doors usually have a vent door that has to be opened mechanically with a lever directly on the door. This also unlocks the door. Then there is a small access panel next to the door with an open/close switch and the interior and exterior light switches. Cargo doors are driven electrically or with hydraulic power.
Thu Oct 29, 2020 2:01 am
Adding to this. Some cargo doors can also be hand-cranked in a pinch if you don't have hydraulic power. For example on the A330, the yellow hydraulic system powers the forward and aft cargo doors. If the yellow system electric pump is inop, there is a hand pump to generate the necessary pressure.
Some smaller cargo doors are operated with muscle power. E.g. bulk cargo doors.
fr8mech
Thu Oct 29, 2020 1:30 pm
As in just about everything in aviation, it depends. On the B747, you can open both the forward and aft doors from the inside. There is a master latch lock release inside and outside. There is an open/close switch both inside and outside. You can close the doors from the inside, but you can’t lock the latches.
The B757 lower doors can also be unlocked and opened from the inside and outside.
But, no, there is no cockpit override. The closest thing I can think of would be on the B747 freighters. If you put both APU generators, or both external plugs on the bus at the same time, the ground service (or is it the ground handling) bus is disabled. The doors will not work, nor will the cargo handling system.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
unimproved
Thu Oct 29, 2020 1:39 pm
And on Boeing it's a mechanical receptacle. Takes about 10 minutes to open with a power drill but if you follow the sticker it's only by hand.
fr8mech
Thu Oct 29, 2020 2:42 pm
Again, that’ll be aircraft specific. The B757 limits you to 500 rpm and 225 inch-pounds if a power tool is used.
Max Q
Thu Oct 29, 2020 9:49 pm
IIRC the 747F nose door can be opened manually with much cranking ?
GGg
Thu Oct 29, 2020 11:06 pm
Generally speaking hydraulically operated cargo doors on passenger aircraft do have controls near the door on the outside under an access panel that enables the operator to ensure the area around the door is clear when operating the door.
Normal operation of the A320 cargo door
https://youtu.be/xCleoApdA7A
Manual operation of an A320 cargo door
https://youtu.be/luqz412AZDo
On all Airbus aircraft the opening and closing of cargo doors using the control panel can be overridden by turning the associated electric hydraulic pump off. By default these pumps are in auto mode, when exercising the switch from the outside it will energize the electric hydraulic pump to enable the door to open and close. When this automatic mode is activated an memo appears for flight crew awareness.
Flight crew cannot override the backup manual controls.
On Airbus aircraft the aircraft would ideally need to be electrically powered by the APU or ground power so the electric hydraulic pumps can operate, the area around the door is clear, aircraft depressurized, and wind within the environmental limits specific for the operation of the door and also having the door open.
“Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.” E. Hamilton Lee, 1949
Tristarsteve
Fri Oct 30, 2020 4:34 pm
Zeke
I don't think that is true. I don't have access to the manuals any more but, the yellow hyd pump on the A320 series can be supplied from the ground service bus on the ground to operate the cargo doors. This will work with the cockpit unpowered. Turning on ground service from the L1 door panel will allow the loaders to operate the cargo doors using the yellow pump. The flight deck switch has no effect in this operation.
I have never tried this (turning off the pump in the flight deck) but the electrical supply route is different.
Sat Oct 31, 2020 2:22 am
Tristarsteve wrote:
Zeke
They way I understand it the maintenance switch powers the bus, however I think the off switch removes the pump from the bus.
milhaus
Tue Nov 03, 2020 6:29 am
On A320, yellow electric hyd pump is usually off, so when someone downstairs starts to operate door, it starts even when PB is off. Only way to switch it off is to pull C/B. Also note when its activated, by cargo door switches just door is powered, nothing else.
Fri Nov 06, 2020 4:45 pm
As far as concerned MOST Cargo Doors of Passenger Aircraft are ALWAYS Unlocked from the Outside & can be Open/Closed from Outside & can be opened from Inside.
On the Freighters the MDCD [Main deck cargo door] is having the Normal Operating controls from the Inside, the panel is so located that a visual view of the MDCD is available.
