Trimeresurus
What's the procedure for runway incursion after the touchdown?
Fri Nov 06, 2020 7:10 pm
What is the pilot expected to do if after he touches down and slows down to a speed that's below what'd allow a safe re-rotation and go around(maybe 120 kts or less) and another aircraft/ground vehicle/person/animal whatever enters the runway and is on the aircraft's path? Do you just accept your fate and brace for impact?
VSMUT
Re: What's the procedure for runway incursion after the touchdown?
Fri Nov 06, 2020 7:21 pm
It is unlikely to happen, but assuming the worst case scenario, he can apply extra braking force on the wheels and apply full reverse power. They could also swerve slightly off to one side of the runway to avoid whatever is there. Obviously not something you would do in a full 777, but smaller types could do that. Absolutely worst case if you somehow out of the blue find a plane blocking your path and stopping or going around is not an option, turning into the grass would probably be preferable.
Really, the protection against this scenario lies with ATC.
Flow2706
Fri Nov 06, 2020 7:46 pm
There was an incident in Munich a couple of years ago where a departing crew misunderstood a conditional lineup clearance and taxied onto the runway while an other flight was on short final. The landing crew (IIRC the landing aircraft was a 737 classic) had to use the tiller at high speed to avoid the collision.
There is no real procedure for this event (which shouldn't happen at all in first place), but the reaction would probably depend on the exact circumstances. On most aircraft types a go around can not be initiated after the reversers are deployed (there is a chance that one reverser may not re-stow which could lead to loss of control), so that would definitely be a consideration but as I said it depends.
Woodreau
Fri Nov 06, 2020 11:27 pm
In this incident, the FO recognized the aircraft was on the runway after touching down, and applied maximum braking, but obviously the plane couldn’t stop in time so the two aircraft collided
https://en.wikipedia.org/wiki/Los_Angel ... y_disaster
USAir 1493 in 1991 if the link doesn’t work
The accident caused a change in verbology. Now when you’re cleared onto the runway the controller tells you aircraft on xx mile final. And when you’re told cleared to land, the controller tells you aircraft departing prior to arrival or holding on runway... etc...
71Zulu
Fri Nov 06, 2020 11:59 pm
Here's a great story written by one of our pilot posters about his near miss..
viewtopic.php?p=12849555#p12849555
Sent from my SM-N960U using Tapatalk
IAHFLYR
Sat Nov 07, 2020 3:41 pm
Correct, though there are times where a ground vehicle will for some unknown reason get confused and crosses an active runway without any ATC clearance which is one reason we'd constantly scan the runway visually and also with the use of ASDE-X (ground RADAR) for intruders when an aircraft is approaching the runway for departure or landing. Happens on taxiways as well, but not quite as bad a possible outcome.
Sun Nov 08, 2020 12:42 am
As one of my first flight instructors told me, "Never, ever, give up." Forum member Slamclick famously expressed it thus: "If I die in the cockpit, I expect to die very busy".
If you're fast enough, the intrusion is a fair way down the runway, and you haven't cracked the reversers, you can attempt a "rejected landing". This is a go-around initiated after touchdown and is slightly different from a normal go around. (Not to be confused with a go-around initiated before touchdown but so low that there is with ground contact.)
Another option is to brake as hard as you can, then veer off to the side and try to at least take the impact on a wing instead of head on.
DualQual
Sun Nov 08, 2020 6:47 am
I believe it was an old British aviation adage “Should a crash be inevitable, endeavor to hit the softest, cheapest thing you can as slowly as possible.”
There's no known cure for stupid
Sun Nov 08, 2020 8:52 am
I love it.
Another expression is that it is better to go off the end of the runway at 30 knots on landing than to crash into the ground at 130 knots.
GalaxyFlyer
Sun Nov 08, 2020 4:02 pm
I’ve done thousands of heavy jet touch and goes on runways from 7,000’ to 13,000’ long; I’d stop unless i was in the flare or just touched down and the intrusion was way down the runway. Otherwise, max effort to stop and go off the side, if collision was inevitable.
rjsampson
Mon Nov 09, 2020 6:48 pm
I'm guessing it would vary by aircraft type (or perhaps I misunderstood something from a "steering" thread, and this isn't a thing at all):
Don't some types lock out tiller functionality above a certain speed?
"..your eyes will be forever turned skyward, for there.." yeah we know the DaVinci quote. Unfortunately, we're grounded :(
Flow2706
Mon Nov 09, 2020 7:12 pm
Not sure about the 737, but on A320s tillers are not locked out at any speed from the systems point of view. However it is not allowed to use them above taxi speed as they are way too sensitive, but in an emergency situation like this it may safe your life.
Mon Nov 09, 2020 11:44 pm
Yes they do. The A330 and A350 nosewheel steering decreases in sensitivity at higher speed. The tiller is completely locked out above 100 knots, while the pedals are locked out above 100 on landing and 150 on takeoff. You still have the rudder of course, and if you're doing over 100 knots it has more than enough authority.
AFAIK the A320 steering logic is much like the A330 and A350. Both pedals and tillers have a decreasing effect on steering at higher speed, and are locked out above a certain threshold. You can still move the actual controls above said speeds, but the nose gear won't move.
This isn't an "operational" A320 FCOM, but should do for the purpose. See page 25. http://www.smartcockpit.com/docs/A320-Landing_Gear.pdf
Users browsing this forum: acmx, Bing [Bot] and 14 guests
