Do they use the same jetway as the passengers for boarding?
In what state do they receive the aircraft?(ie completely powered off, "cold and dark", or electrified?)
If another gate was assigned for an aircraft for the next departure than the one it landed and docked, who taxies it to there? Follow-up:How often are airliners sent to parking areas(that aren't on terminals) because the next flight is too many hours away and they want to keep the gate unoccupied? In that case who taxies?
Does the flight crew and cabin crew board at the same time?
If engines are too cool(aircraft not used for 24h or more), and need to idle for a while before takeoff thrust and the taxi time isn't long enough for that, do they do a preflight idle run up? Is it done at the gate?
Thanks in advance for this interrogation
