nopper
Type Certificate from 767-300 to 767-300ER
Tue Dec 15, 2020 8:35 am
Hi Guys,
Anyone knows that when Boeing develop 767-300 to 767-300ER, what kind of type certificate did it have to obtain? A new TC, or STC?
VMCA787
Re: Type Certificate from 767-300 to 767-300ER
Tue Dec 15, 2020 11:05 am
IIRC, amended Type Certificate.
Fly fast, live slow!
Polot
Tue Dec 15, 2020 11:38 am
The 763ER is on the same type certificate as the 763A (and all the other factory 767 variants). As mentioned the TC was just amended.
cedarjet
Tue Dec 15, 2020 12:14 pm
What are the physical differences? I flew on a Delta 767-300A PDX ATL a few years ago which was exciting for my inner spotter as they’re rarer than the ER but the passenger experience and aircraft appearance was indistinguishable from an ER. It’s more than a paperwork difference or a tank fitted but not plumbed in, right?
Polot
Tue Dec 15, 2020 1:05 pm
Much larger fuel capacity and greater MTOW with structural alterations to a support it. Visually though no exterior or interior difference.
Weatherwatcher1
Tue Dec 15, 2020 1:46 pm
It’s way more than a paperwork change. The airplane was re-engined. The 767-300ER used the PW4000 & CF6-80C2 versus the JT9D & CF6-80A as well as RB211s. The thrust increase was around 20% that increased range significantly.
Marketing worked a lot differently in the 1980s. The re-engine and payload increases made the 767-300 to 767-300ER upgrade much more significant than the A320neo or 737MAX re-engines. The 767-300ER did not receive significant interior changes.
ArcticSEA
More of a customer option, but smaller cargo door in the case of Delta's 763A vs. the ERs.
Asiana, for example, had 763As with the larger cargo door. Air Algerie had the smaller one on their 763As.
PNW-based private pilot and engineer. #fatpnw
DarkSnowyNight
Tue Dec 15, 2020 1:53 pm
And conversely, almost all 763ERs have the larger FWD Cargo doors, with only some of HAL's earlier models being an exception.
Well, you know what they say. Whatever doesn't kill you...
... Must not be an MD-11.
MO11
Tue Dec 15, 2020 4:54 pm
nopper wrote:
Hi Guys,
There is NO type certificate for the 767-300 (ER). It is a marketing designation for a 767-300 with increased fuel capacities and weights to give it longer legs. All Boeing would have to do is certify the 767-300 to operate at these higher weights.
N965UW
Tue Dec 15, 2020 8:03 pm
I also think that the winglet STC is only good for the -300ER, and the -300 was never certified for them. Plus the -300ER has a higher optional MLW of 320,000 lbs.
You can always go around
747classic
Tue Dec 15, 2020 9:18 pm
MO11 wrote:
nopper wrote:
Hi Guys,
That's correct :checkmark:
In both the 767-200ER and the 767-300ER, the Extended Range (ER) marking only indicates a high grossweight variant of the 767-200 and -300.
In the FAA Type Certificate no seperate "ER" sub type is mentioned.
The 767-400ER is mentioned as a 767 subtype, because no 767-400 has ever been certified.
See : https://rgl.faa.gov/Regulatory_and_Guid ... Rev_37.pdf
Note : the same is valid for the 747-400ER and the 747-400ERF, both are only high grossweight variants of the 747-400 and the 747-400F for the FAA.
Operating a twin over the ocean, you're always one engine failure from a total emergency.
DL_Mech
Wed Dec 16, 2020 2:11 am
I believe the Hawaiian planes were originally ordered by LTU.
This plane is built to withstand anything... except a bad pilot.
Former AMT on A220,A310,A319/20/21,A330,A350,B707,B717,B727,B737,B747,B757,B767,B777,DC-9,DC-10,L-1011,
MD-80/90,MD-11
DarkSnowyNight
Wed Dec 16, 2020 9:18 am
Thanks. I knew they were not HAL new builds as a good deal of theirs were not. In fact, I think out of the 24 they operated, only 10 were new from factory. The rest came either from LTU or, for the Bogo models, DL.
That does not surprise me. We used to do a lot of work on their planes and it did seem that there was more or less every Exit, Service and Cargo door configuration to be found on 767s therein...
unimproved
Wed Dec 16, 2020 11:46 am
It's probably more of a real world problem with the different wing than a paper certification thing.
nopper
Thu Dec 17, 2020 9:30 am
nopper wrote:
Hi Guys,
Thanks to ALL!
johnclipper
Sat Dec 19, 2020 11:17 am
Same with the B777 - there is no B777-200ER, just a 777-200, -200LR, -300, -300ER and F. If you look at the plates inside the door of a -200 "ER", it says "777-2XX (Boeing Airline Code)"
"Flown every aircraft since the Wright Flyer" (guys, if you take this literally, then you need to get a life...)
N1120A
Sun Dec 20, 2020 8:05 pm
That's not uncommon. STCs frequently are issued only as to certain configurations, even if they would work just fine on other configurations. The cowling on one of my planes is only certified with a certain, upgrade exhaust system. That the winglet STC is only on the -300ER isn't surprising. I wouldn't be surprised if it also only applied to certain engines as well.
richcam427
Mon Dec 21, 2020 2:06 pm
Your last statement is correct, I believe. I don't believe the winglet STC was ever certified on the RR-powered 767s.
Users browsing this forum: Baidu [Spider] and 17 guests
