tu144d wrote:I'm failing to see how the Stick Force Gradient would be reduced and forces would be lighter unless the article is referring to the fact that the control authority is lost at these high than normal AOAs and thus deflection of the elevators results in very little change in pitching moment and airspeed. This doesn't make sense though because then MCAS which moves the tabs would also not produce any noticeable aerodynamic pitching moment if authority was lost. All explanations appreciated.
I'm not 100% sure I follow you, but I'll take a couple stabs that might help. There are scenarios when a horizontal stabilizer becomes completely ineffective at influencing the airplane's pitch, in particular T-tail airplanes "deep stalled" at very high angles of attack. But I don't think that's what is happening on the MAX.
If you're using "tabs" referring to pitch trim, I'm thinking you might be imagining a Cessna 172 stalling. Swept wings don't behave the same way. Swept wings stall at the tips first, and as the stall develops, the center of lift moves forward continuously, which results in a pitch-up moment. see video:
http://www.youtube.com/watch?v=T2y3DX8hZAY&t=2m20sIf I'm correctly reading the Boeing e-mails in that article, they're saying to each other that as you pulled on the column to stall the MAX, you would notice you were pulling less and less hard until at the point the airplane stalled, you were hardly pulling at all. That's an undesirable (and uncertifiable) characteristic. They didn't say they lost control authority or the ability to control the pitch of the airplane. But the force on the control column to take the airplane through the stall was very light, because of all the other aerodynamic factors contributing to pitch-up (center of lift moving forward, and the engine pylons also contribute to pitch-up at high angles of attack, as they become big aero surfaces in front of the CG).
