tax1k wrote:I’ve noticed that almost invariably planes start their takeoff after ATC says line up and wait but before getting the “cleared for takeoff” message. I would have thought that “line up and wait” meant something stationary. Just curious what I’m missing.
Starlionblue wrote:If you expect to be cleared in short order, you might keep rolling slowly for a short distance instead of coming to a complete stop. (Of course, you need to know you can "waste" some runway). But you certainly won't set takeoff thrust before "cleared for takeoff". That would be a rather serious violation.
IAHFLYR wrote:"taking into position and hold, don't plan on stopping"
BWIAirport wrote:but that was changed to "line up and wait" in the last decade or so. I believe that was because "position and hold" sounded too similar to "hold short" or "hold position," which is practically the opposite instruction.
Starlionblue wrote:tax1k wrote:I’ve noticed that almost invariably planes start their takeoff after ATC says line up and wait but before getting the “cleared for takeoff” message. I would have thought that “line up and wait” meant something stationary. Just curious what I’m missing.
phatfarmlines wrote:What benefit does an aircraft get by rolling slowly instead of stopping while awaiting takeoff clearance?
phatfarmlines wrote:Starlionblue wrote:tax1k wrote:I’ve noticed that almost invariably planes start their takeoff after ATC says line up and wait but before getting the “cleared for takeoff” message. I would have thought that “line up and wait” meant something stationary. Just curious what I’m missing.
I see this often at an airport like ATL. What benefit does an aircraft get by rolling slowly instead of stopping while awaiting takeoff clearance?
Max Q wrote:In the UK it’s quite common to get a clearance from the tower when you’re number one for the runway ‘behind the landing aircraft line up and wait’
I’ve only been given this clearance when the landing aircraft is on short final but it’s not one you’ll receive in the US
GalaxyFlyer wrote:Max Q wrote:In the UK it’s quite common to get a clearance from the tower when you’re number one for the runway ‘behind the landing aircraft line up and wait’
Fairly common across Europe. One day in Lisbon, hazy, I got that clearance only had the traffic’s lights in sight. Not a fan.
GalaxyFlyer wrote:Just one example, hard to identify the traffic the tower referring to. Like MaxQ, we’re accustomed to the clearance to enter the runway AFTER the landing traffic touches down. I don’t see where it speeds things up.
N1120A wrote:In the US, you'll get a LUAW once the landing aircraft has crossed the threshold or the point at which you're holding, but not necessarily after it touching down.
GalaxyFlyer wrote:N1120A wrote:In the US, you'll get a LUAW once the landing aircraft has crossed the threshold or the point at which you're holding, but not necessarily after it touching down.
That’s reasonable, but the FAA procedure of issuing the landing clearance to two planes both on final sounds fishy to me, too, as it does for many non-US pilots.
n92r03 wrote:Just a guess here but the OP may be watching the aircraft (either in person or on FR24) while listening to ATC via Live ATC or other. If so, there is often a slight delay in the audio which can give the impression the aircraft is moving before clearance/instruction is given.
GalaxyFlyer wrote:Fairly common across Europe. One day in Lisbon, hazy, I got that clearance only had the traffic’s lights in sight. Not a fan.
GalaxyFlyer wrote:Yes, KLGA with crossing runways does that a lot, too. Love Warsaw, spent 10 days during the Great Iceland Volcano shutdown.
CanukinUSA wrote:The reason the phrase was changed was that the previous command "Line Up and Hold" was believed to have been misinterpreted by the KLM 747 flight crew in the worlds worst aircraft accident in Tenerife when the 2 747s collided in the fog. It was believed that the KLM 747 crew while multiple radio transmissions were taking place at the same time on the same frequency somehow thought that they had been cleared for takeoff and the rest is history. The International Civil Aviation Organization (ICAO) adopted this phase quite a while ago along with most countries and the United States was one of the later countries to adapt it.
Woodreau wrote:My favorite one is still Aspen... Rwy 15/33 same piece of concrete - 8000ft runway.
(holding short of Runway 33) "Line up and wait, opposite direction landing traffic on 9 mile final runway 15, call traffic in sight."
sure enough there are the landing lights of the opposite direction traffic lined up down the centerline of the runway we are on. "Traffic in sight"
"Cleared for takeoff Runway 33"
Tower now addressing the aircraft landing on 15 "Cleared to land Rwy 15, traffic departing Rwy 33, has you in sight."
"Cleared to land Runway 15."
as we fly towards each other at 240kts... and play the game of airway chicken that the departing aircraft always loses because it turns right after departure and then left to fly under the landing aircraft.
As we're under the landing traffic, the next guy is checking in " Tower, aircraft xyz, visual 15."
"aircraft xyz, aspen tower, continue, traffic to depart runway 33 prior to your arrival..."
the controller then proceeds to tell the next aircraft to line up and wait on 33.
N1120A wrote:Not all controllers do, but I don't see a problem with it either. A clearance can always be cancelled and it saves the problem of a very late landing clearance in a critical phase.
