Anonz263x
Why was N106US the a320 involved in the hudson river ditching never repaired?
Wed Jan 20, 2021 7:58 am
As my question goes why wasnt N106US repaired instead of being put as a display, as I did read into another flight that ditched although by mistake, Japan Airlines flight 2, which the dc-8 was repaired afterwards, or is it that the a320 had more that makes it unfeasible compared to say had it been a 737 instead?
flyingturtle
Re: Why was N106US the a320 involved in the hudson river ditching never repaired?
Wed Jan 20, 2021 9:16 am
AFAIK a damaged aircraft (temporarily) belongs to the insurance. Then the insurance decides whether it's worth to repair the aircraft, or not.
Reading accident reports is what calms me down
unimproved
Wed Jan 20, 2021 9:52 am
Engines were a write off, electronics drowned, and lots of structual issues. At that point it's cheaper to start looking at the second hand market.
Wed Jan 20, 2021 10:33 am
Japan Airlines 2 was a very gentle impact. N106US was very much not.
kurtverbose
Wed Jan 20, 2021 1:29 pm
Check out the state of the aircraft and how much further damage was done when it was lifted. No was was this ever going to be an 'economic repair'.
https://www.baaa-acro.com/crash/crash-airbus-a320-new-york
Crackshot
Wed Jan 20, 2021 3:49 pm
JAL2 is a great story. First you have a pilot unintentionally making a perfect water landing, and then when questioned about the incident comments "as you Americans say, I f**ked up!"
ikolkyo
Wed Jan 20, 2021 4:57 pm
I don't think JAL 2 ever ended up being basically fully submerged in water like N106US did.
FGITD
Wed Jan 20, 2021 5:14 pm
JAL 2 was in less than 10 feet of water...at high tide. I believe the nose barely even touched the water, saving the cockpit. Not too bad.
US1549 was towed a few miles, lost an engine on the way, then mostly sunk and stayed that way for a few days before being craned onto a barge. Overall a much more “traumatic" event
Lpbri
Wed Jan 20, 2021 5:42 pm
Saltwater immersion.
BlueberryWheats
Wed Jan 20, 2021 9:50 pm
A DC8 is going to have less complex systems to repair compared to an A320.
The tallest blade of grass is the first to be cut.
N1120A
Thu Jan 21, 2021 5:03 am
The rest of the aircraft hit exceptionally hard, causing the pressure vessel to be breached. That airplane was way too expensive to fix.
flymad
Thu Jan 21, 2021 7:00 am
Interesting pictures. What was the cause of the starboard forward door being damaged?
shamrock137
Thu Jan 21, 2021 2:23 pm
I think it was either one of the ferry boats pushing the fuselage or during the recovery of the aircraft. Videos and the NTSB report show and state the R1 door and slide were successfully used and deployed for the evacuation.
https://youtu.be/fwIe-e7Apkc?t=151
Time to spare? Go by air!
Wacker1000
Thu Jan 21, 2021 4:10 pm
A day or two after it happened, the FAA said they'd never let it fly again. No further discussion was necessary.
GalaxyFlyer
Thu Jan 21, 2021 6:08 pm
The FAA just has to issue an AD on that serial number. RR did it on the Global damaged at Fox Harbor, NS so the engines and parts couldn’t be put back into service.
Charleytuna
Thu Jan 21, 2021 6:35 pm
Would saltwater immersion be a death sentence for most aircraft ? Aluminum, electrical, hydraulics .
chimborazo
Thu Jan 21, 2021 8:35 pm
It took a hell of a battering during the impact. I suspect there is much more structural/internal damage than that which is easily seen from external pictures.
That lifting system won't be doing it much good either. It's necessary to allow a crane to lift it from the water of course, but it's likely putting stresses not designed for in a relatively small surface area at those points very close to wing root. Aeroplane wings are immensely strong as we all know, and they have a jacking point in each one, structurally integrated, but those straps won't be doing a great deal of good for the wing structure.
Saltwater and airframe/electronics already mentioned.
Note the lifting strop configuration: of interest there is a double strop on port wing and single on starboard, even though port wing is the one missing the motor (it could be that starboard double strop has slipped in towards fuselage - can't see in the photos).
N1120A
Fri Jan 22, 2021 1:36 am
The Hudson was likely still mostly freshwater at that point during that time of the year.
trex8
Sun Jan 24, 2021 6:06 pm
Qantas repaired the 747 which overran BKK at its own expense, insurers wanted to write off, Qantas wanted to preserve its "never had a jet hull loss" record.
Sun Jan 24, 2021 11:04 pm
Indeed they did. As you say though, it was very much an image-driven repair. It was not a good economic decision.
N1120A
Tue Jan 26, 2021 12:35 am
Well, it may have been a good economic decision in other ways.
BoeingGuy
Tue Jan 26, 2021 2:33 am
That’s not the reason. As others noted, JAL 2 landed on a sand bar with minimal impact and immersion.
By comparison, a TWA 707 freighter ran off the end of runway 1R and into the bay during an RTO at SFO in 1972. It was damaged beyond repair and not put back in service.
A number of posters have given good accurate answers to the OP’s question. Some posts are just making up something.
Tue Jan 26, 2021 3:05 am
Image driving economics. Yes, fair point.
hitower3
Tue Jan 26, 2021 3:43 pm
OK, no further questions - the electronics bay and all other sensitive systems were submerged. The engines ripped off. Exitus.
You most certainly could find desert-stored A320s in OK condition, which could be re-activated at lower total cost (acquisition & necessary maintenance).
Hendric
Wacker1000
Tue Jan 26, 2021 6:01 pm
https://data.ntsb.gov/Docket/?NTSBNumber=DCA09MA026
Specifically docket items #76 and #79. If it was repaired, it would have been too shady for even the shadiest of third world operators.
N1120A
Sat Jan 30, 2021 10:11 pm
Ultimately, a combination of the FAA and insurance is making the decision on this. There was no way the insurance wasn't going to total that airplane.
Philippine747
Mon Feb 01, 2021 12:03 am
I'm aware of the reputation issue but I read somewhere it was cheaper to repair that 744 than order a new one at the time?
A319 A320 A321 A332 A333 A343 AT75 AT76 B732 B733 B738 B744 B752(M) B763 B772 B77W DHC7 DH8C DH8D D328 MA60
2P 5J 6K CX DG EK GA KE MI PR VN OS QR A3 OK TG RA U4 JL GK UB K7 WE BR
FGITD
Mon Feb 01, 2021 6:40 am
744 has an interesting history of being repaired. AF also fixed the 744 that went for a swim in Tahiti despite fairly extensive damage. The aircraft was well known internally as F-GITANIC
trex8
Tue Feb 02, 2021 1:54 am
That may well be true but the point is the cost of the repair was higher than the value of a used 9 year old plane
TTailedTiger
Tue Feb 02, 2021 1:59 am
Why would anyone think repairing it would have been a good idea? It wasn't a simple bump on the ramp. It was submerged in water. Most smartphones don't even recover from that. Not to mention that US Air's A320 fleet was much older than their A319 and A321 fleet. And notice it was also a much smaller fleet. There was zero reason to even entertain the idea of repairing it.
Philippine747
Tue Feb 02, 2021 4:47 am
That repair job was quite impressive, especially after being exposed to saltwater...
Fair..
Users browsing this forum: 747classic, Charleytuna, seabiscuit and 28 guests
