bigb wrote:I guess, would be for fire detection and protection. Most a/c, the fire protection and detection system is on the DC side of an electrical system.
Flow2706 wrote:The APU can’t be started unless the batteries are on and also it will auto shutdown if the batteries are turned off. The reason for this is indeed the fire protection, which is not available with the batteries off. It’s quite common however to have the aircraft parked at the gate with batteries off and external power on.
zeke wrote:Flow2706 wrote:The APU can’t be started unless the batteries are on and also it will auto shutdown if the batteries are turned off. The reason for this is indeed the fire protection, which is not available with the batteries off. It’s quite common however to have the aircraft parked at the gate with batteries off and external power on.
This is incorrect, APU can be started from batteries, the normal electric system, or ground power.
See this attached this old FCOM 1.49.10 P1 https://www.smartcockpit.com/docs/A320- ... r_Unit.pdf
It will shut down if the batteries are the only source of DC power and turned off.
Mr AirNZ wrote:I can assure you all day long on the baby bus, without the batteries on, you will can never start the APU.
I can not speak to the bigger buses but on the A320 family, this is the case.
zeke wrote:bigb wrote:I guess, would be for fire detection and protection. Most a/c, the fire protection and detection system is on the DC side of an electrical system.
Not sure about that, the A330 has a Mel for A/C only start of the apu.
The GPU connects to the AC bus like the engines would on the A320, DC BUS 1/DC BUS2/DC ENT are powered from the two AC busses via a transformer rectifier.
I know the APU year on the A320 cannot be started if a battery charge limiter has failed.
bigb wrote:I was answering the op question regarding why the Bat switches must be on prior to starting the APU. You need the DC system for fire protection/detection. Unless the fire detection/protection is on some kind of hot battery bus... But having those batteries switch in the ON position gives you a back up to power the necessary DC busses for your fire detection system in the event of T/R malfunctions.
