VSMUT wrote:It has been discussed in the past. If I recall correct, the A330-200 is more powerful than the 757-200, so the new 757-200 has been around for over 20 years already.
chonetsao wrote:VSMUT wrote:It has been discussed in the past. If I recall correct, the A330-200 is more powerful than the 757-200, so the new 757-200 has been around for over 20 years already.
I thought the OP is talking about A220 rather than A330?
Turnhouse1 wrote:I always assumed the noticeable take-off push in the 757 was as it had a good power to weight ratio, but was probably old enough not to have an electronic launch control which reduced thrust unless at MTOW. A newer plane might have a similar or even higher power to weight ratio, but would never use full thrust unless loaded which would dampen the perceived acceleration anyway.
hitower3 wrote:Dear Swiss03,
Question : was your takeoff performed on a contaminated runway? Was this a short flight, e.g. Zurich-Geneva? Was the cabin rather empty?
If yes, you were lucky to experience a full power takeoff in a light plane.
Starlionblue wrote:On a contaminated runway, it could well have been a fixed derate.
PatrickZ80 wrote:It is pretty powerful indeed, mostly due to the fact that the same engines are being used on the bigger A220-300. If it has to be powerful enough for the big one, it's therefor overpowered for the smaller one.
They were able to develop a 757-300 because the engines for the 757-200 were powerful enough to power a larger aircraft.
By the way, the 717 is pretty powerful as well. It also pushes you back in your seat on take-off, for which it needs remarkably little distance.
hitower3 wrote:Starlionblue wrote:On a contaminated runway, it could well have been a fixed derate.
Dear Starlionblue,
Oh, ok - I thought that contaminated runways (e.g. snow) would often mandate a full power takeoff as per SOP, because the start-stop distance is longer.
I stand corrected then.
Hendric
Dear Starlionblue,
Hendric
Armadillo1 wrote:still do not understand how change Vmin-control can change V1, which in any case controllable.
Starlionblue wrote:
The explanation for why you might derate on a contaminated runway is a bit complex, but bear with me.
SAAFNAV wrote:Armadillo1 wrote:still do not understand how change Vmin-control can change V1, which in any case controllable.
Because the lowest V1 must be greater or equal that Vmc.
So suppose you are able to get a lower V1, you still have to make it artificially higher to satisfy Vmca requirements.
If you can bring down Vcma by derating the engines, you can then bring down V1.
Dear Starlionblue,
Thank you very much for your extensive and insightful answer.
I might need to read it a few more times to fully understand it, though...
Hendric
N965UW wrote:IIRC the CRJ-700's T/W is up there near, if not slightly higher than the 752. I had the opportunity to fly on a CRJ7 and connect to an A332, so I got to compare both on the same day. The -700, especially from a 6500-foot runway was a little rocket and had me pushed into the seat. While the A332 is powerful, it didn't have the same seat-pressing effect as the CRJ.
DylanHarvey wrote:N965UW wrote:IIRC the CRJ-700's T/W is up there near, if not slightly higher than the 752. I had the opportunity to fly on a CRJ7 and connect to an A332, so I got to compare both on the same day. The -700, especially from a 6500-foot runway was a little rocket and had me pushed into the seat. While the A332 is powerful, it didn't have the same seat-pressing effect as the CRJ.
Also remember the 332 is a lot more likely to be loaded up with passengers and cargo. It will not exactly jump off the ground on a 9 to 10 hour flight. I was on a CR7 that rolled about 2100 feet on a 30 minute flight with six passengers, Plus it was maximum available thrust due to a contaminated field with the restrictions that Starlionblue had mentioned
N965UW wrote:DylanHarvey wrote:N965UW wrote:IIRC the CRJ-700's T/W is up there near, if not slightly higher than the 752. I had the opportunity to fly on a CRJ7 and connect to an A332, so I got to compare both on the same day. The -700, especially from a 6500-foot runway was a little rocket and had me pushed into the seat. While the A332 is powerful, it didn't have the same seat-pressing effect as the CRJ.
That is true. The A332 flight I described was a 7.5/8hr hop and had a good amount of passengers. I'm not sure how much cargo AA carries on seasonal routes between CLT and Europe, but we were light enough for a FL370 initial cruise (380 on the return).
The CRJ flight was nearly full on a 1hr20min trip, no runway contamination and still had impressive performance. The return was probably about 3/4 full and I know it was a reduced thrust takeoff since climb thrust was set higher after rotation.
Starlionblue wrote:N965UW wrote:DylanHarvey wrote:Also remember the 332 is a lot more likely to be loaded up with passengers and cargo. It will not exactly jump off the ground on a 9 to 10 hour flight. I was on a CR7 that rolled about 2100 feet on a 30 minute flight with six passengers, Plus it was maximum available thrust due to a contaminated field with the restrictions that Starlionblue had mentioned
As mentioned, you can't get a valid comparison from the cabin. For starters, almost all take-offs use reduced thrust.
Any airliner, especially a twin, has gobs of excess thrust, but you never really use it. On a ferry flight with no payload, you'd typically use reduced thrust.
The only time I really felt that ultimate power was during base training. A330 with no pax or cargo. Only about 20 tonnes of fuel. Touch and goes with TOGA. Talk about rocketship. You were at 800 feet and reducing thrust before you could blink.
But again, that kind of performance is available in any airliner.
You can make pretty much any aircraft a rocket ship. If you firewall a 77W you’d think you were going to get some impressive performance. Why use 3000 feet of a 15,000 runway when you have no performance limitations and you can derate comfortably
rjsampson wrote:I remember being a passenger departing from KATL on a NW 75 back in the day. However they crunched their speeds up front: I was in a state of surprise, and inadvertently blurted "Holy @$#@!" out loud as it seemed that from spool to Vr... felt like mere seconds, jumping off a long, dry runway. She got homesick to the angels faster than the Lancair I had flown a week prior. Perhaps I was lucky enough to experience the requisite full-power T/O?
T/W ratios are one thing. The wing on the 75? I can't imagine any other airliner (even lightly loaded at TOGA) doing this:
https://youtu.be/ddusBoFNr-s?t=19
GalaxyFlyer wrote:I don’t if it’s still true, but there was a requirement to do a rated power take-off on some schedule to ensure it was available. I’ve done them on light airplanes only because it was scheduled.
quarryking wrote:Experienced something similar a few years back on a KLM 777-300 between DPS - SIN. Flight was full, but the take-off thrust did feel pretty solid & way more than a regular 777 take off roll. Not sure if there were any Runway limitations being enforced that day, but it certainly did feel like he was going all out that evening.
DylanHarvey wrote:Twin engine aircraft have so much excess thrust. Derates can you be in order of 20+ percent in a lot of instances. You do not need to come close to firewall and a 77W at MTOW.
LCDFlight wrote:It bears repeating, but a heavy B739 at full thrust will accelerate and climb more strongly, in some cases, than a lightly loaded 752 on a derated takeoff. Not a pilot, but I think this statement is correct.
GalaxyFlyer wrote:LCDFlight wrote:It bears repeating, but a heavy B739 at full thrust will accelerate and climb more strongly, in some cases, than a lightly loaded 752 on a derated takeoff. Not a pilot, but I think this statement is correct.
Maybe
GalaxyFlyer wrote:How “lightly” is lightly? How much of a derate applied? Is “full” thrust full or at reduced setting or full at the derate? Remember “full” means at the rating, so you can have “full” derate 1 or wash out the derates. Is the 757 so light, the TO is based on reduced thrust on the derate power. And nobody in the back will know any of this.
744SPX wrote:The Learjet 31 (and earlier 23) takes the cake for civilian aircraft, and that includes the Concorde.
rjsampson wrote:744SPX wrote:The Learjet 31 (and earlier 23) takes the cake for civilian aircraft, and that includes the Concorde.
Apparently, flying those early Learjets wasn't worth the T/W ratio. There's a user on this forum, tb727. His color commentary is quite... interesting (as are the hundred+ posts that followed)
viewtopic.php?t=774999
Buckle up. Apparently, those were terrible airplanes.
