L1011TheTriStar
How do passenger windows get so scratched up?
Tue Feb 16, 2021 8:35 pm
I've noticed when flying on older 757s and other 20+ year old aircraft, some of the passenger windows seem quite scratched up on the outer pane. I'm curious how this happens?
I know it can't be from passenger traffic because the scratches are almost never on the inner plastic window pane we all can touch from the passenger cabin.
Here is an example of what i'm talking about
https://i.imgur.com/xNPZDxR.png
fr8mech
Re: How do passenger windows get so scratched up?
Wed Feb 17, 2021 1:22 am
Crazing is common.
Environmental conditions can also cause mechanical damage. Age/UV damage. Cleaning crews.
unimproved
Wed Feb 17, 2021 6:37 am
Sand and dirt hitting it at high speed. Paint also starts stripping from rivet heads and panel edges due to that.
Wacker1000
Wed Feb 17, 2021 10:54 am
Minimum wage contract cleaners that don't know or care to follow proper procedures.
787SIN
Wed Feb 17, 2021 11:45 am
As fre8mech says, if on the outside its most probably crazing. Generally acceptable to a point then the glazing panel has to be changed. Check the depth of the defects with optical micrometer.
Inside, pax and cleaners using the incorrect methods on the inner panes.
Strebav8or
Wed Feb 17, 2021 7:03 pm
Gremlin on the outside of the aircraft?
77west
Thu Feb 18, 2021 3:28 am
In 2019 I flew on the last 737-300 off the line and the windows in the first few rows all seemed to have the 1998 date stamped on them from when the plane was built. They had a few scratches but didnt seem too bad considering.
battlegroup62
Thu Feb 18, 2021 4:30 am
Outside too. That's what happens when the cleaners drop the rag on the tarmac, pick it up, and use it on windows anyway.
Users browsing this forum: seven47, zanl188 and 4 guests
