Sokes
Wingboxes
Thu Feb 18, 2021 9:30 am
Why do wingboxes often project the fuselage so much?
https://en.wikipedia.org/wiki/Airbus_A320_family
https://en.wikipedia.org/wiki/Airbus_A330
https://en.wikipedia.org/wiki/Airbus_A380
But it's not always so extreme.
https://en.wikipedia.org/wiki/Boeing_737
From the area rule I would expect that a wingbox should project the fuselage as little as possible. Actually the fuselage should project the wingbox. But I assume that makes the joint complicated. Was it ever done for a pressurised aircraft?
Why can't the world be a little bit more autistic?
tommy1808
Re: Wingboxes
Thu Feb 18, 2021 9:53 am
Wave drag is lowest when the cross section area is the lowest, but to avoid creating shock waves causing drag you want those area changes to be smooth as well. It would appear it is just worth hauling the extra structure around, and the cost to build it, since the 737 would otherwise look bad drag wise. Much, much improved mathematical models and orders of magnitude more computing power to drop on those also makes a lot easier to find the optimum shape. If you compare those over time it would also seem that the involved shapes get a lot more complicated the newer the air-frame is. The A350 for example as a step in the change that almost seems like someone extracted some extra lift from it.
best regards
Thomas
Re: Wingboxes
Thu Feb 18, 2021 10:23 am
- Wingbox: The structure that joins the wings and the fuselage. This is not visible from the outside.
- Wing-body fairing: The aerodynamic fairing that covers the wing/fuselage join.
The area rule does not imply that the wing-body fairing should not be proud of the fuselage ("project from"). The area rule states that the same cross-sectional area distribution gives the same wave drag, and that cross-sectional changes should be smooth.
Effecting said smooth cross-sectional change is done mostly by fine-tuning the shape of the wing-body fairing, the nacelles, or the flap-track fairings.
As tommy1808 says, you want changes to be smooth. This is in order to decrease interference drag.
Users browsing this forum: Starlionblue, VMCA787 and 15 guests
