IFlyVeryLittle
Grass landing strips
Mon Mar 22, 2021 1:35 pm
I realize the early-days-of-aviation-romance of the grass landing strip and its quaint, throwback history but are they inherently more difficult to handle than pavement? Particularly, when dew covered or wet from a rain? I always imagined them as manicured as a golf fairway, but then I remembered how slippery wet fairways can be in a golf cart, driving at 20 mph, never mind landing a Cessna at four times the speed on tires roughly the same size. Ive never landed a plane on grass, but I have spun out my share of golf carts.
Flow2706
Re: Grass landing strips
Mon Mar 22, 2021 2:27 pm
I have flown gliders for many years, mostly from Grass runways (they are still very common for gliders nowadays). Grass Runways are actually more "forgiving" than hard surface (for firm/hard landings). If the grass is mowed regularly it poses not particular challenges. Long grass can be critical as it can increase the takeoff distance and can be a contributing factor in ground loops.
Mon Mar 22, 2021 2:42 pm
A key difference is that a golf cart transfers power for locomotion through the wheels. An aircraft does not. Certainly a slippery surface has an effect, especially on braking, but the engine(s) provide forward impetus and this factor is unaffected by the runway friction coefficient.
Grass runways require some considerations. But definitely not as much of an impact as driving a car on ice versus dry asphalt.
GalaxyFlyer
Mon Mar 22, 2021 2:52 pm
Flying taildragger off grass is a whole different deal than off asphalt—the forgiveness of slipping is great.
CanadianNorth
Mon Mar 22, 2021 7:33 pm
I've found them fine to operate on, never had an issue, though to be fair they've always been quite a bit bigger than I actually needed so there was lots of room to act if things started sliding.
The POH for my airplane mentions grass runways, but the only mention I know of is in the takeoff and landing section it says "For operation on a dry, grass runway, increase distances by 15% of the "ground roll" figure."
HS-748, like a 747 but better!
AntonioMartin
Mon Mar 22, 2021 8:26 pm
I was just wondering if there are any grass air fields with commercial airline ops....
CosmicCruiser
Mon Mar 22, 2021 11:19 pm
True. My J-3 was based on grass and all the tail wheel warbirds use the grass at Duxford 95% of the time
glen
Tue Mar 23, 2021 10:16 am
Thats's the reason I always require a trainee to do quite some landings on concrete before Solo when they start flying taildraggers. Usually when they begin their training on grass, they think, it's not that big deal flying a taildragger. But with the first landing on concrete the fun begins...
Back to the topic question: Usually grass runways are not so well maintained like a golf course and the combination of the grass and the soft underground is quite considerable and adds al lot of drag.
However I remember an instance many years ago. I was landing on very well, golf course like maintained, fresh cut grass runway. Right before landing a short rainshower had wettened the grass, but was too short to soften the underground. The result was a very poor braking action and it was probably more luck than skill to keep the plane on the runway.
"The horizon of many people is a circle with zero radius which they call their point of view." - Albert Einstein
mxaxai
Tue Mar 23, 2021 11:37 am
I've seen a few larger aircraft get stuck on grass runways, usually WW2 warbirds, when the ground was wet and soft. If they're doing a tight turn or just standing there for a while, the gear can start digging a hole.
Similarly, in wet conditions you'll often find a lot of dirt on the aircraft after landing, thrown up by the main gear.
The surface is generally not as smooth as a golf course. You should expect some bumps and potholes. The grass is kept short, though.
CARST
Tue Mar 23, 2021 3:25 pm
If you look not only at Europe and North America, I'm sure you will find a quite a few grass runways in the world with commercial ops. Especially in remote areas, which are only reachable by aircraft. Perhaps no scheduled pax flights, but at least commercial ops for cargo, charter and business traffic, stuff like that...
Heck, we have Barra in Scotland, where the aircraft land on the beach at low tide. Multiple times daily. Since decades...
https://edition.cnn.com/travel/article/ ... index.html
And then there are all the gravel runways which basically turn into ice runways in Alaska and northern Canada which all see commercial ops. Even with the 737-200 to this date in 2021.
The ATR72 and 42 are certified for unpaved runways inlcuding grass runways AFAIK, so there will be some customers using these planes for such ops. Even the Pilatus PC-24 jet is certified for grass runways.
flipdewaf
Tue Mar 23, 2021 4:45 pm
I seem to remember with one of my instructors that when we flew in to a particular field (Full sutton) that the best course of action when taking off was to raise the nose gear off slightly ASAP on takeoff as the drag on the grass on the nose wheel was more than the additional drag from a few degrees of AoA. I seem to remember as well being told "As long as you'll make it over the hedge at the end, don't worry about climbing too much, its better to try and get some speed"
Fred
N1120A
Tue Mar 23, 2021 9:24 pm
Taildragger pilots often prefer grass to asphalt, as it is more forgiving and less likely to lead to a ground loop if you are too fast. Some tricycle gear aircraft handle grass better than others, usually because of ground clearance.
Wed Mar 24, 2021 1:50 am
Indonesia would like a word. :D
AntonioMartin
Wed Mar 24, 2021 12:19 pm
LOL...what airline is that??
AntonioMartin
Wed Mar 24, 2021 12:21 pm
Oh yeah! I forgot those! Thanks for the info!!!
trijetsonly
Wed Mar 24, 2021 12:50 pm
Famous Susi Air
They even have an awesome TV Show.
Happy Landings
chimborazo
Wed Mar 24, 2021 1:18 pm
Fred
That’s quite normal for short/soft field, although there are different techniques dependent model. I found the PA-28 works better by NOT using the column pulled all the way back as it’s such a big stabilator is has a large braking effect. 2 stage of flaps... Let it run (slowly as it does) up to 45kn then give it a yank to get the nose off the floor. And it really does need a yank on wet grass. Get it off the ground and accelerate before climbing. Whereas on a C172 you can do whatever you want... it just wants to leap off the ground, even when heavy.
I learned at Peterborough Sibson which really does teach short field technique - have a look at the displaced thresholds on 06/24 (and on 15 with its prerequisite hedge at the end of a 600m grass runway prone to water logging). The trees on the end of 24 are a delight when gusty, get some nice rollers off them and have to get the plane flying (up the hill and over the ski-ramp) then hold it there to accelerate well above stall speed before climbing. It’s good fun because despite the fact you are apparently heading for the trees you have to tell yourself the correct thing to do is build speed then climb.
AntonioMartin
Wed Mar 24, 2021 6:45 pm
Famous Susi Air
Oh nice! Thanks for the info!!
Thu Mar 25, 2021 1:33 am
Famous Susi Air
Most of the episodes are on YouTube. There's a bit of dramatic voiceover syndrome but interesting stuff. I've met a few pilots who've worked in the area and it is indeed as depicted.
Flying the Knife Edge by Matt McLaughlin is a good memoir on the subject. https://www.goodreads.com/book/show/255 ... knife-edge
https://youtu.be/HT5gUKJidi0
seat55a
Thu Mar 25, 2021 6:50 am
Lots of grass field ops in Papua New Guinea on the youtube channel Missionary Bush Pilot. It's a busy operation with both pax and cargo using Quest Kodiak. Other aspects of the ops are interesting too, mix of old skool and high tech.
Chemist
Sat Mar 27, 2021 11:30 pm
Missionary Bush Pilot's videos are really interesting and super high quality IMHO.
GayFA
Sun Mar 28, 2021 4:52 pm
I agree. And very different in what you get to see about flying, from the single engine long overwater flight to Cairns with an ILS approach, to your typical mountain and jungle terrain visual approaches into very remote airfields.
Users browsing this forum: adipasqu, CanukinUSA, DH106, Flanker7 and 30 guests
