PhilipBass
Which planes run out of engine hours first
Wed Apr 07, 2021 6:35 pm
Are there any particular smaller planes under 80 seats which run out of hours on their engines long before the airframe is due to be scrapped.
Of course you could replace/refurb the engines but the engines are expensive to the point that the airframe will go to the scrapper rather than investing in a new engine.
acecrackshot
Re: Which planes run out of engine hours first
Wed Apr 07, 2021 7:03 pm
I'm not sure of the thrust of your question (pardon the pun) but in my experience its usually the opposite.
For example, on King Air 200/1900/King Air 350s, the PT-6s, even with programs like MORE, will time out far before the fuselage.
There are lots of 1970s/1980s vintage 200s on the market with dated but decent interiors, compliant avionics, decent paint at pretty low prices due to the fact the aircraft is at a weird point where the residual value of the aircraft is really below the value point to upgrade with new/OH motors.
fr8mech
Thu Apr 08, 2021 12:28 am
The only time I've ever seen a new engine on an aircraft is when it was delivered.
We pull engines all the time, way before the airframe is even close to going away. When the time comes to scrap an airframe, the engines will be replaced with high time engines that are no longer economical to overhaul, or the engines are pulled at the boneyard.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
battlegroup62
Thu Apr 08, 2021 10:28 am
Same. I've never seen the likes of a CRJ or E-jet engine make it to a major part life limit before it comes off for some other reason. Most of the time it's due to FOD damage in the HP section or getting CANNED because all the spares are still in the engine shop getting overhauled. For the CF-34 family they average 15k hours on wing, doing the math for the fuselage limits its about 4-6 engines if the fuselage is used to the fullest.
We have to keep planes airworthy. That doesn't mean they have to fly.
PhilipBass
Thu Apr 08, 2021 12:55 pm
Thanks.
OK. So a CRJ is a likely candidate where it is due it's N.th expensive engine overhaul which is enough to send it to a scrapper.
Any turboprops similar to that? Is there a time on an ATR 42 or Q300/Q400 where the cost of investing in an engine overhaul isn't economically justifiable for an old airframe?
CARST
Thu Apr 08, 2021 2:25 pm
PhilipBass wrote:
Thanks.
I think we can assume that it is the same for the turboprop aircraft you mentioned, as it is for the KingAirs or CRJ/ERJs/E-Jets mentioned above. And for all other aircraft.
But just because you mention the Q300 (and as well the Q100/Q200), when we talk aircraft that don't get manufactured anymore, it might be worth investing in extending the airframe's hours and cycles and put new engines on it, simply because there is no alternative to these old airframes or because new aircraft are even more expensive than overhauling the old airframe and putting new engines on it.
unimproved
Thu Apr 08, 2021 5:41 pm
PhilipBass wrote:
Thanks.
It's not like a car where it's considered a single "part" that gets worked on. The things that write off frames are almost always damage or nearing heavy maintenance checks. Engines are tracked unrelated to the wing they might currently reside under.
When covid first hit we were playing musical chairs with engines for weeks, just to move the ones with nearing maintenence to the frames going into storage.
fr8mech
Thu Apr 08, 2021 6:57 pm
Engines are no more “attached” to an airframe, than the wheels assemblies are. They are replaced when it circumstances dictate they be replaced.
fr8mech
Thu Apr 08, 2021 7:40 pm
PhilipBass wrote:
Thanks.
I just read that closer...the airframe is NOT due its engine overhaul, the engine is due the overhaul. The engine gets pulled and a serviceable one is installed in its place.
bigb
Fri Apr 09, 2021 7:44 pm
The outbord engines on the 747 or A380 most likely.
lightsaber
Sat May 01, 2021 2:05 am
Exactly. They are more durable than before, but the maintenance budget is expensive.
I wonder how insane the overhaul market will be on the rebound... There will be a period where there are insufficient engines available.
Lightsaber
5 months without TV. The best decision of my life.
extender
Sat May 01, 2021 1:16 pm
GE parts are getting pricier. We deal with the CF6-50, -80A and -80C, and a lot of parts for the engine mounts are becoming scarce with long lead times. The shop visits for the CF-34 are not cheap.
CRJockey
Sat May 01, 2021 9:29 pm
What?
battlegroup62
Sun May 02, 2021 6:27 am
lightsaber wrote:
fr8mech wrote:
When covid first hit we were playing musical chairs with engines for weeks, just to move the ones with nearing maintenance to the frames going into storage.
Lightsaber
I can tell you for aircraft powered by the cf-34 family, replacement fan blades, and other rotable parts are hard to keep on hand due to a backlog at the overhaul facilities. The aircraft that use them had been working hard picking up some of the slack of the parked larger aircraft..
Users browsing this forum: kalvado, LCDFlight, woodcutting and 16 guests
