UAUA
Is it possible to access the cargo compartment from the passenger compartment?
Fri Apr 16, 2021 6:58 am
https://aviation.stackexchange.com/ques ... -in-flight
Is it possible to access the cargo compartment from the passenger compartment? Guess so?
I have seen people gaining access to the cargo compartment from the passenger compartment in MANY movies.
So I wonder.....
My former profile name was United Airline.
FGITD
Re: Is it possible to access the cargo compartment from the passenger compartment?
Fri Apr 16, 2021 7:05 am
Yes you can, on most widebodies.
Depending on container positioning though, it wouldn't be useful for really anything.
It looks nothing like the movies and is definitely a place you couldn't sneak down to.
VSMUT
Fri Apr 16, 2021 8:36 am
Yes, on some aircraft you can. I have seen videos of pilots crawling through the floor hatch in the A350 into the avionics compartment, and from there into the cargo hold. I think I've seen the same for an A330. ATRs have direct access to both cargo holds, unless it is one of the rare examples fitted with a forward entry door, in which case the forward hold is only accessible from outside.
Byrdluvs747
Fri Apr 16, 2021 9:09 am
Was there a door/hatch to access the cargo hold via the lower galleys of the older 747s & L-1011's ?
The 747: The hands who designed it were guided by god.
DIJKKIJK
Fri Apr 16, 2021 9:11 am
Read somewhere that IL-86 was designed in such a way that the passengers could board the cargo hold first, place their own bags in there and then climb up into the main cabin to occupy their seats. Apparently, this was popular in the erstwhile USSR.
Never argue with idiots. They will bring you down to their level, and beat you with experience.
tommy1808
Fri Apr 16, 2021 9:15 am
also made for short, light build in stairs. And a place to leave (winter) coats....
best regards
Thomas
VSMUT
Fri Apr 16, 2021 9:37 am
The Presidential Il-96 also has this feature. Not sure about the regular passenger Il-96s though.
TheFlyingDisk
Fri Apr 16, 2021 11:36 am
Didn't Lockheed try to do this with the L-1011?
I FLY KLM+ALASKA+QATAR+MALAYSIA+AIRASIA+MALINDO
Fri Apr 16, 2021 12:05 pm
I've gone through the avionics hatch in the cockpit, into the avionics compartment, and into the forward hold.
Of course, once the cans are loaded, they would take up that space so they would block access.
You can't get from the forward hold to the rear hold because the wing box is in the way.
In other words, those movies are not realistic.
mxaxai
Fri Apr 16, 2021 3:15 pm
The E-4B has integrated airstairs through the forward cargo hold as well.
I doubt that it's actually used for cargo, though.
Agent
Fri Apr 16, 2021 7:55 pm
In some A340 it is possible to enter forward (through the E&E) and aft cargo (through the mobile crew rest) comparments during flight.
Woodreau
Fri Apr 16, 2021 9:44 pm
On Canadair regional jets you can access the aft cargo bin thru the aft lav. Though you need tools to remove the access panel to gain access to the cargo compartment.
Sat Apr 17, 2021 1:11 am
Indeed. However, as I mentioned above the cargo hold is typically full of cans so it is a bit academic. In-flight, you'd basically open the door from the avionics compartment and see the side of the nearest can.
Lpbri
Sat Apr 17, 2021 3:11 am
On a 777, you can access the forward cargo from the E&E compartment, which itself is accessed from a hatch in the floor in the first class galley. To open that hatch you need to be able to unlock it. The 787 has no such access.
hitower3
Sat Apr 17, 2021 5:24 am
Good morning!
Is it true that you can also escape from the avionics bay to the tarmac by opening another hatch that gives access to the nose gear bay?
Hendric
fr8mech
Sat Apr 17, 2021 7:20 am
Hendric
No, not to the nose gear well, but directly out of the fuselage. At least on all the types of worked on. I've never seen access to the nose wheel well from the interior.
****Edit: It appears that the MD11, and presumably the DC10, does have an access door from from the avionics bay to the NWW...at least according to the AMM.
Strangely, I don't have an MD in the hangar today, so I can't go take a look.
Most, if not all, transport category aircraft have an exterior access door to the E&E compartment or avionics bay. Some have two.
I should add, that those access doors are all plug doors. You ain't going to open them while the aircraft is pressurized.
When seconds count, the police are minutes away, or may not come at all.
It’s hard to win an argument with a smart person, but it’s damn near impossible to win an argument with a stupid person. ~B. Murray
Lpbri
Sat Apr 17, 2021 7:48 am
You must be thinking of the movie Commando
Sat Apr 17, 2021 8:09 am
hitower3 wrote:
Good morning!
Hendric
Yes, there is an exterior door. However, as mentioned by fr8mech, the avionics bay door is not in the gear well. It's on the exterior.
On a widebody it is a bit of a drop. If you need to get out in a hurry, cockpit windows or escape hatch are the way to go. They at least have escape ropes. :D
Pedantic side note: It isn't "the tarmac". Surfaces on which aircraft move are apron/ramp, taxiway and runway. In some cases, the material is tarmac, but that isn't a term that is used in the industry.
Max Q
Sat Apr 17, 2021 10:11 am
‘Please don’t wake my friend, he’s dead tired’
GGg
Horstroad
Sat Apr 17, 2021 11:21 pm
This door does exist and it's easy access to the aircraft (when the locking pin is not installed) without the need of any stairs or power... if you're slim and flexible enough to fit around the avionics rack.
There's that urban legend that back in the days of the DC10 one brave flight engineer went down through the E&E and out that door in flight, to pull the gear pin of the nose landing gear which has been forgotten, to prevent an inflight return. I don't know if it's true, but it's definitely possible. You'd have to walk over the forward gear doors though and all that's holding them up are some ball bearings in the manual door release mechanism of the door drive link.
DL_Mech
Sun Apr 18, 2021 3:09 am
It’s possible that a brave (read: not smart) pilot did this. Sometimes people don’t realize how close they come to serious injury/death.
This plane is built to withstand anything... except a bad pilot.
Former AMT on A220,A310,A319/20/21,A330,A350,B707,B717,B727,B737,B747,B757,B767,B777,DC-9,DC-10,L-1011,
MD-80/90,MD-11
AirKevin
Sun Apr 18, 2021 10:38 am
A Lufthansa A340 crew actually tried this, but I don't know what actually ended up happening.
https://www.youtube.com/watch?v=2fs9HcdhUFI
Captain Kevin
VSMUT
Sun Apr 18, 2021 10:54 am
Probably a not so insignificant wind pressure as well.
Lukas757
Sun Apr 18, 2021 5:19 pm
The A340 has an integrated foldable ladder to access the aircraft from outside.
Here is a training video: https://www.youtube.com/watch?v=eKrHO6a04Cw
fr8mech
Sun Apr 18, 2021 8:18 pm
The B747 has one also. A little simpler than that contraption. I want to say our A300 have them too, but I haven’t been in the avionics bay in a long time.
Of course, those aren’t som much as access ladder as convenience ladders for maintenance. Since you have to be in the aircraft to deploy them, or have a ladder to access them, so you can deploy them.
Agent
Sun Apr 18, 2021 10:04 pm
A300 has it as well. Back in the days this ladder was standard, with the A350 you have to pay an extra dime...
Mon Apr 19, 2021 12:30 am
Many operators have removed the ladder. I guess it saves a bit of weight not to have it.
Finding a ladder tends not to be a problem at most airports. ;)
KingOrGod
Mon Apr 19, 2021 10:08 am
I once worked a 767 bizjet and they brought their own ground engineer who later entered the aircraft via a ladder and hatch in the front somewhere... Got a photo somewhere in my archives...
BubbleFrog
Mon Apr 19, 2021 11:39 am
We were once stuck on the tarmac in a 744, and somebody came into the cabin by way of the nose wheel and through a hatch on the cabin floor. Can anyone enlighten me how that worked?
Absolute Relativist
fr8mech
Mon Apr 19, 2021 1:05 pm
They came through the EE Bay access door that is aft of the nose gear. Climbed the integral ladder into the passenger cabin. The floor access door is inboard of the L1 door just to the left of the aircraft centerline. On a pax bird, the door is covered by a flap of carpet.
unimproved
Mon Apr 19, 2021 6:12 pm
Climb on the nose strut, open avionics door, climb up. Repeat for the cabin floor hatch.
889091
Mon Apr 19, 2021 7:19 pm
https://www.youtube.com/watch?v=AKzM9R21LZc
Goto 10:20
889091
Mon Apr 19, 2021 7:23 pm
fr8mech, I have a couple of questions:
1. I assume there is a locking mechanism/you need a key to gain access from the outside? Otherwise anyone can gain access into a 744 parked on the tarmac?
2. Would you get a Door Open/Unsafe light in the cockpit if it is not properly secured?
3. It would be impossible to open the door if the cabin is pressurised?
Thanks.
Horstroad
Mon Apr 19, 2021 8:09 pm
Thanks.
There are no Keys required to open any commercial aircraft exterior doors. It would be pretty bad if the mechanic who has the key in his pocket is off for the weekend :D
Security seals are installed when necessary.
Most exterior access doors, especially those in pressurized areas, have a cockpit indication on modern aircraft. IIRC they retrofitted a switch on the internal access to the E&E in the cabin of the 747 post 9/11. On the 777 the E&E access is in the forward galley and in theory always "guarded" by a flight attendant. On the 777F the access is covered by carpet, because couriers might be unattended in the galley/supernumerary area.
It is not possible to open any exterior access door in the pressurized area when the cabin is pressurized. You would be able to access the E&E from the cabin, but you wouldn't be able to open the exterior door.
crimsonchin
Mon Apr 19, 2021 9:42 pm
Can't imagine that ladder set up weighs much. Does this insignificant weight actually matter that much in terms of fuel burn?
fr8mech
Mon Apr 19, 2021 9:52 pm
Thanks.
I can’t add much more to what Horstroad wrote above.
As it pertains to keys, there are none. This is why the TSA regulations we deal with on the ramp are political theatre. We ‘secure’ aircraft by pulling equipment away and closing doors. Quite simply, it would take me about 30 seconds...well, maybe 45 seconds, now that I’m older...to get into a B747, from the moment I touch the nose gear.
All the regulations do are deter the casual ‘potential offender’. Someone even remotely determined will be able to do damage.
Our Classic freighters did not have a warning switch that the interior panel was open. Our new builds did. In fact, that same switch deactivates the nose area loading system. It just wouldn’t do to have someone’s head taken off by a pallet.
Thrusty69
Mon Apr 19, 2021 10:02 pm
Thanks.
1. No locking mechanism from the outside. Also want to point out even tho most of these bigger planes have stairs that drop down, any physically fit individual can climb up the back of the nose gear and monkey themselves in. It’s about 7 or 8 feet up on a 744.
2. Yes. (On the door synoptic page)
3. Correct.
Horstroad
Mon Apr 19, 2021 11:21 pm
A few years ago we had a weight savings program for our aircraft. They told us each kilogram removed from every aircraft in the fleet would save €30.000 per year. I'm not sure how they defined "fleet"... All A340 (for example)? All wide body aircraft? All aircraft in the airline? All aircraft in the group? Doesn't matter. In the end it's a bean counters calculations. They removed coat hangers and left only two per aircraft (cargo fleet) to save weight. But they didn't restrict the weight of the pilots. So one pilot alone could counteract the effort of removing 200 coat hangers if he weighed 130kg instead of 80kg. The fuel quantity indication is only accurate to the next 50kg. 200kg more or less fuel is a "rounding error". The fuel measuring sticks only need to be accurate to about 2% of the full tank capacity. So you could have 12,000 coat hangers worth of fuel more on board than known.
That being said and with all the variations and uncertainties, each kilogram that can be saved will save you money in the long run. An A330 fleet with the ladders installed will have burnt more fuel after 20 years than an A330 fleet with the ladders removed.
I have not weighed the ladder assy on the A330/340 but I assume it's around 10kg or somewhere in that ballpark.
FGITD
Mon Apr 19, 2021 11:51 pm
Thanks.
Ain’t that the truth. If you want in and know anything about the aircraft, you’ll get in.
EE bay was my go to access point for diversions when the handling company was stretched too thin or the stairs were out of service. Give the engineer a lift, then he’d give me a hand up. Not exactly company policy, but it works
RetiredWeasel
Tue Apr 20, 2021 12:32 am
During initial checkout as an FE on 747-200's we got to open the hatch and proceed down to the nose gear/EE compartment. Basically it was to show us how to drop the nose gear if the two primary emergency methods failed. It involved unscrewing a bunch of bolts to release a brace of some sort. Even the wrench was located nearby the brace. Farther back, you could separate a insulated canvas/fire break material (think it was velcroed closed) and see (or access) the forward lower cargo compartment. This is from memory, so details may be off.
fr8mech
Tue Apr 20, 2021 2:49 am
That was a 7/16th wrench on a lanyard. It was used to remove the bolts holding the one of the nose door rod supports. The hope was that if the doors jammed, removing that support would allow the weight of the gear to force the doors open. As I recall, the bolts to remove had their heads painted red.
That wrench was part of my walk around at Pan Am.
hitower3
Tue Apr 20, 2021 7:59 am
Hello Horstroad,
In very simple terms, a jet aircraft will burn about 1/25th to 1/40th of its current in-flight weight of fuel per hour. The 1/40th figure would apply for the most advanced long range twin jets.
So, if you manage to reduce the OEW by a kg - may it by through the removal of unneeded equipment, reducing fuel reserve, putting the crew on a diet :-) - you will save a kg of fuel burn within 25 to 40 flight hours. Assuming that a commercial jet will fly between 3'000h and 5'000h per year, weight reductions will save between 75 and 200 times the weight reduction worth of fuel per year. Assuming a lifespan of 25 years, one kg of weight reduction will yield accumulated fuel savings of 1'875kg and 5'000kg.
So, looking at a yearly figure of let's say 150kg of fuel savings per kg of weight saved and assuming a fuel price of 0,50USD/kg that's 75USD per aircraft per year. So the statement of your company (with the current assumptions) is correct for a fleet of 400 aircraft (75 * 400 = 30'000).
Hendric
Horstroad
Tue Apr 20, 2021 8:30 am
Hello Horstroad,
Hendric
Thanks a lot. This went pretty far off topic by now :D
But that's why I like this forum so much. You learn something new every day, even when you don't expect it.
Tue Apr 20, 2021 8:44 am
Locks only appeared after MH370 ......
“Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.” E. Hamilton Lee, 1949
BubbleFrog
Tue Apr 20, 2021 8:51 am
Thanks everyone. Now I know a bit more. Really appreciate it.
Absolute Relativist
VSMUT
Tue Apr 20, 2021 1:22 pm
That's not true. Many low-sitting aircraft such as the ATR have locks on the doors, and the aircraft get delivered from the factory with keys. Never seen them in use out in the real world however, presumably for the exact scenario you suggested, with somebody running off with the keys in his pocket.
FLALEFTY
Tue Apr 20, 2021 5:42 pm
PSA (the original airline) experimented with L1011's briefly back in 1974-75. Since PSA was a short-haul airline that didn't fly lots of cargo, one of the features of their L1011's was a below-deck lounge located in what would have been the forward cargo hold. The lounge had access to the main deck above and to the outside via a door exit with folding airstairs that could reach the ramp.
https://travelupdate.com/psa-lockheed-tristar-lounge/
N965UW
Tue Apr 20, 2021 8:09 pm
https://youtu.be/LxS2RR-Vx_s
Access to the A350's forward hold via the E&E compartment at 1:22
You can always go around
Wed Apr 21, 2021 12:33 am
Compared to the A330, the A350 hatch is nicely off to the side and a bit out of the way. The wide cockpit can accommodate that position. On the A330 it is right in front of the cockpit door, which you definitely want to close before opening the hatch. Otherwise, someone coming in might not see the opening and fall in. Yes, this has happened.
That plane definitely still has that new plane smell. So clean! Doing walkarounds on brand new A350s it was almost startling to actually see squeaky clean gear wells. :D
uclax
Sun May 02, 2021 7:06 pm
I'm sorry if I missed a response to the earlier question about the L1011. I know there was a galley under the main cabin, with a small elevator for the flight attendants. I don't know if it also allowed access to the cargo compartment.
...those who wait for the Lord�s help...rise up as if they had eagles� wings Isaiah 40:31
Users browsing this forum: boeing767322er, dennypayne, GalaxyFlyer, litz, Nomadd and 23 guests
