UA857
777-200LR/300ER vs 777X common type rating
Sun May 09, 2021 9:09 am
Hey Guys, is there any common type rating between the 77L/77W and the 77X? Can a 77L/77W pilot be able to fly a 77X?
Re: 777-200LR/300ER vs 777X common type rating
Sun May 09, 2021 12:10 pm
AFAIK definitely yes.
There's a common rating with the 787 too.
VMCA787
Sun May 09, 2021 1:56 pm
EASA has a common type rating with the 777/787, however, the FAA does not. The 787 is a separate type rating.
Fly fast, live slow!
e38
Mon May 10, 2021 1:17 am
Yes, for operation under Federal Aviation Administration jurisdiction, the reference is FAA Order 8900.1, Volume 5, Chapter 2, Section 19, effective 17 December 2020.
You can quick link to this at: https://registry.faa.gov click on Airmen Certification; Aircraft Type Rating Designator.
e38
Okcflyer
Mon May 10, 2021 2:21 am
There are enough small differences that a differences course should be required. Meaning a pilot rated on the 77W has to take a short training before he/she can fly the 9.
N1120A
Mon May 10, 2021 4:01 am
It surprises me that the 777 and 787 would have a common type anywhere. The avionics are pretty different.
I'd imagine the change in avionics alone would require that.
Mon May 10, 2021 5:17 am
The A330 and A350 also have a common type rating as well, and they're also pretty different.
VSMUT
Mon May 10, 2021 6:08 am
Note that common type rating doesn't necessarily mean you can go from one to the other without additional training ;)
Just going from old ATRs to -600s was a 10 day course when I did it, and that's the same type!
BoeingGuy
Mon May 10, 2021 6:45 pm
The 777-200/-300 Avionics are a different architecture from the 787, but it doesn’t matter what’s going on under the hood. It matters what the pilots see.
The 777-9 and 787 Avionics and Flight Control architecture is almost identical.
Mon May 10, 2021 7:20 pm
They are not a common type rating with the FAA either.
“Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.” E. Hamilton Lee, 1949
Horstroad
Tue May 11, 2021 1:06 pm
OP asked for the flying part of the industry specifically... but I would like to share some things from that part that stays on the ground.
For us technicians it's not a common type rating. There isn't a differences training course either. You'd have to go through the whole type training process again, like for any other aircraft.
For the technicians it's quite the opposite... obviously.
The next generation B777 isn't even considered a 'similar aircraft' to the old B777 when it comes to keeping your license active. (To keep a type rating active we have to have worked on that aircraft type in the past 2 years. We can also keep the type rating active when we have worked on a 'similar aircraft' in the past 2 years). EASA defines 'similar aircraft' quite vaguely as "Two aircraft can be considered as similar when they have similar technology, construction and comparable systems".
In my environment the B77L/W is grouped together with the A320/330/340, ERJ170/190 and BD-500, while the B77X is in a group with the A350/380 and the B787.
N1120A
Tue May 11, 2021 7:01 pm
Hence the point about a differences training.
Wed May 12, 2021 12:52 am
Absolutely.
Adding the A350 is non-trivial. A few days of classroom, a knowledge test, a procedure trainer session, half a dozen sim sessions and a few sectors with a training captain.
Once you have the common rating, you alternate A330 and A350 on the proficiency checks. And there are some currency requirements.
Users browsing this forum: bradyj23, flyer408 and 19 guests
