Boeing757100
FAA putting inspections on 737-300, -400, and -500 Autothrottle wiring
Mon May 17, 2021 1:20 pm
https://www.reuters.com/business/aerosp ... 021-05-14/
On Friday, May 14, the FAA said it was to inspect 143 737 Classics operated by US airlines. An airworthiness directive was issued to ensure that the flap synchro wire, which plays part in controlling the autothrottle, is safely connected to a sensor. Any disconnection of the wire could go undetected by the autothrottle system and could pose a safety risk. Suspicion started to arise after the Sriwijaya crash a few months ago.
A simple flying link- https://simpleflying.com/faa-classic-aircraft-ad/
orlandocfi
Re: FAA putting inspections on 737-300, -400, and -500 Autothrottle wiring
Mon May 17, 2021 1:53 pm
SJ182 took off into an area of thunderstorms and crashed, but this wire is what they find suspicious? I’m not trying to defend Boeing, but it feels like the world is bending over backwards to exonerate crews that made fatal errors by blaming the automation.
Aesma
Mon May 17, 2021 1:59 pm
It's the Swiss cheese again. Without the crew reaction to the issue (non reaction rather) the crash wouldn't have happened. Without the A/T malfunction, the crash wouldn't have happened. Shouldn't we try to plug as many holes as possible ?
orlandocfi
Mon May 17, 2021 2:50 pm
If only aircraft systems worked perfectly 100% of the time. The Swiss cheese of aviation is mostly hole and very little actual cheese. The pilots are too often called upon to fill those holes.
Vicenza
Mon May 17, 2021 3:03 pm
A fault in automation systems has a very high potential of causing crews to make fatal errors.
737max8
Mon May 17, 2021 4:34 pm
Who is still flying 737 CL in the USA? Alaska still have any 400s?
FX1816
Mon May 17, 2021 5:01 pm
Not Alaska, they retired them a few years back. iAero (formerly Swift Air) and Sierra Pacific come to mind as the only ones carrying people. iAero, Mesa, Kalitta Charters II, Aloha Cargo and Northern Air Cargo are all flying -300's and -400's as freighters.
CRJockey
Mon May 17, 2021 5:56 pm
Where are you flying? Mozambique? In hundreds and hundreds of flights I had to fill holes for the automation like five times.
m007j
Mon May 17, 2021 10:34 pm
iAero Airways (formerly Swift) has a bunch. IIRC Alaska has gotten rid of all of their classics.
WIederling
Tue May 18, 2021 6:33 am
Have you had a look into REALITY?
Not taking the "crew made fatal errors" as sole cause lock stock and barrel
is not "bending over backwards to blame Boeing."
orlandocfi
Tue May 18, 2021 12:11 pm
You use quotations yet you’re misquoting me. Either you don’t understand what I’m saying, or you’re intentionally twisting my words. The REALITY is that there’s plenty of blame to go around for recent accidents. I feel that some countries do not want to take responsibility for their poor aviation safety cultures and instead blame the machine rather than address the human factors involved.
737max8
Tue May 18, 2021 1:41 pm
Thanks for the info, I think AS was the last time I flew a classic.
Aesma
Tue May 18, 2021 2:32 pm
When the 737 had its rudder issues, some pilots made it, some crashed. Surely the aircraft didn't need any improvement, just train pilots better ? Same for the MCAS ?
N1120A
Tue May 18, 2021 7:40 pm
This was almost certainly the result of the crew not identifying a fault and hand flying the aircraft, being over reliant on automation. Fly the airplane.
Users browsing this forum: No registered users and 16 guests
