Kayro
Can a B777LR take off at MTOW from a wet 2,7km rwy?
Sat Jun 19, 2021 9:17 am
Hello
Emirates pre covid was flying from Fort Lauderdale to Dubai with a B777-200LR. Their longest runway is 2743m.
Currently they are flying from Miami to Dubai with a B777-300ER in ca. 14 hours.
My guess is now:
the OEW of a B777-200LR is about 155 tonnes?
(I read somewhere Emirates' planes are always very
heavy because of their heavy first and business class).
Plus food, pax and cargo let's say 45 tonnes = 200t
What is the average fuel flow for a LR for a 14hours flight? 8 tonnes? Plus reserve they would need about 120t of fuel.
Let's assume, TOW would be around 320t. If you look at Boeing's chart, a LR with GE90-115BL engines would need 2,5km at 30°Celsius, zero winds.
Does this chart mean TOGA thrust? And do pilots rotate at 2,5km or are they already airborne at 50 feet or something?
How much more runway would be necessary, if it was raining?
Can they take off with MTOW at 347t from a wet 2,7km runway, with only 320t or what would be the limit in this case?
mxaxai
Re: Can a B777LR take off at MTOW from a wet 2,7km rwy?
Sat Jun 19, 2021 12:04 pm
Takeoff runway length requirements are calculated with the assumption that one engine fails. So the runway must be long enough to either stop within the remaining distance or continue the takeoff with only one engine. Stopping is usually possible only up to a certain speed, called V1. If there's wind or if the runway is wet or icy, that must be accounted for.
A normal takeoff should be much higher than 50 ft at the runway end. You would expect to get airborne at around 1/2 to 3/4 of the runway length, give or take. FLL's runway would enable takeoffs up to ~335t in calm and dry weather, according to the chart. This chart assumes TOGA thrust.
Note that the pilots use a different chart that's customized to their specific aircraft configuration and regulations (or rather, they run the numbers through a computer). If the runway is longer than necessary, which is often the case, they can choose less thrust to reduce noise and engine wear and tear.
CosmicCruiser
Sat Jun 19, 2021 12:47 pm
Is the runway grooved?
Aaron747
Sat Jun 19, 2021 12:55 pm
Indeed it is:
Runway 10L/28R
Dimensions: 9000 x 150 ft. / 2743 x 46 m
Surface: asphalt/concrete/grooved, in excellent condition
Weight bearing capacity:
PCN 95 /R/B/W/T
Single wheel: 100.0, ST 175
Double wheel: 200.0
Double tandem: 468.0
Dual double tandem: 800.0
http://www.airnav.com/airport/kfll
Sun Jun 20, 2021 5:45 am
Kayro wrote:
Hello
My guess is now:
Trip fuel would probably be around 100 tonnes, with around 110 tonnes in total required with contingency and reserves. The weights you are using are reasonable.
I think the aircraft should be fine on a 9000 ft at those weights, essentially it’s a sea level, that being said that chart is just for runway performance, takeoff performance includes the runway performance and obstacles after liftoff which can be controlling. That is the difference between using that chart, and the real FLL.
I think it wouldn’t need TOGA, pilots rotate the aircraft when the rotation speed is reached, not when a specific distance is passed on the runway.
The authoritative answer would have to come from someone with access to the obstacle database and performance program for FLL.
“Don't be a show-off. Never be too proud to turn back. There are old pilots and bold pilots, but no old, bold pilots.” E. Hamilton Lee, 1949
Woodreau
Sun Jun 20, 2021 10:57 am
If the runway is grooved it’s considered to be a dry runway even when raining. At least that’s how it is at the three airlines I’ve worked at.
CRJockey
Sun Jun 20, 2021 8:54 pm
Interesting. We handle it differently as we simply say: does the runway look wet, calculate wet. Does it say wet on the ATIS, calculate wet.
The calculation tool (not OEM, but airline specific) then takes the groove into account which more or less produces „dry“ performance regarding distances.
Sun Jun 20, 2021 11:39 pm
That isn’t the way the FAA sees it.
Tartarus
Mon Jun 21, 2021 4:17 am
KFLL
B77L
Wind calm
30'C
29.92/1013
Alt CG
APU-to-Packs
TOGA
10L:
Dry...307,704 kgs
Wet...304,383 kgs
28R:
Dry...320,537 kgs
Wet...316,859 kgs
Mon Jun 21, 2021 5:16 am
Thank you, that tells me there is something in the takeoff splay
Mon Jun 21, 2021 6:22 am
It's weird that 10L would be more limiting. The terrain is flat as a pancake. Looking at Google Maps, the airport charts, and the VFR chart I can't see any notable obstacles in that direction. It's just a highway, some low light industrial buildings, a waterway, and then the ocean. Street view from the road beyond the runway end shows a whole lot of nothing. There is a 580ft minimum altitude a few miles out but it's the same in both directions.
EDIT: Found it. Container port. But it's pretty far off to the south of the extended centerline. I guess not far enough. :)
Google Maps: https://www.google.com/maps/place/Fort+ ... 80.1506022
Airport Charts: http://www.airnav.com/airport/fll
VFR Chart: https://skyvector.com/?ll=26.0715864445 ... 301&zoom=1
GalaxyFlyer
Mon Jun 21, 2021 1:27 pm
Lauderdale used to have a rail line off the end of the easterly runway. Weight manual had a penalty if there was a train on the track, so container port might be an improvement.
e38
Tue Jun 22, 2021 1:10 am
Kayro (Topic author)
Reference your question below:
I'm not sure I quite understand what you are asking, but pilots do not rotate at a specific distance down the runway. Instead, rotation is initiated at Vr.
As you know, takeoff data is predicated on losing an engine. Should it occur prior to V1, the takeoff is rejected; after V1, the takeoff is continued. In the event of the loss of an engine at V1, for the takeoff data to be valid, the aircraft must cross the departure end of the runway at least 35 feet above DER. If all engines are operating, this will of course, be higher. From what I can determine from the chart you posted, the Takeoff Field Length depicted on the left side of the chart represents the amount of runway required to accelerate to V1, then either bring the aircraft to a stop on the runway in the event of a rejected takeoff or achieve an altitude of 35 feet if the takeoff is continued.
e38
TropicalSky
Sun Jun 27, 2021 9:17 pm
rail line is still there and operational
AirKevin
Sun Jun 27, 2021 9:25 pm
So how did they determine if there was a train on the tracks.
Captain Kevin
GalaxyFlyer
Sun Jun 27, 2021 10:54 pm
You looked down the runway, pretty simple but not infallible. Generally the data assumed a train. Many a late afternoon B727, load reduced by three occupants termed infants, temp was 1 or 2c below the current temp and 5 knots of HW in the calculation. Usually it cooked enough not delay things, pretty predictable. The effect of a couple of infants being on board, much less so.
GalaxyFlyer
Sun Jun 27, 2021 10:56 pm
Yes, but much improved, below runway surface now.
AirKevin
Mon Jun 28, 2021 12:42 pm
I was about to say, if you had the data for without a train, and you look down the runway and there is one, then you're screwed unless you wait for the train to go away. But I guess if the data always assumes a train is there, then that's a different story.
Captain Kevin
GalaxyFlyer
Mon Jun 28, 2021 1:45 pm
It wasn’t a huge penalty, maybe 500-1000 pounds, but every take-off on a warm day in KFLL was at the limits in a 727-200 with D9 engines.
Users browsing this forum: No registered users and 18 guests
