CDGIAD
737's main landing gear length
Mon Jun 28, 2021 9:34 pm
The 737 having a too short landing gear keeps popping up.
The first versions (732, 733, 734 and 735) had engines that were smaller in diameter, and the short landing gear allowed integrated airstairs which were popular at the time.
But when designing the NG, with the need to fit bigger engines and airstairs being discontinued because of weight, why didn't Boeing lengthen a bit the main gear by moving it 15-20cm outboard of each wing.
How complex is this?
JBo
Re: 737's main landing gear length
Mon Jun 28, 2021 10:15 pm
I'm wondering if it had to do with retaining commonality with the Classics.
jimatkins
Mon Jun 28, 2021 10:20 pm
Pretty sure it requires a whole new center wing box.
Starfuryt
Mon Jun 28, 2021 10:22 pm
Not to be an asshole, but there are a number of 737 related threads where this has been asked, discussed, and beaten to death more than once. Surely we don't need another thread on this.
miegapele
Mon Jun 28, 2021 10:30 pm
Airstairs discontinued? But Ryanair has them on threir 737-800
77west
Mon Jun 28, 2021 11:42 pm
AFAIK they are available still on request on any new builds. Airbus even has them as an option for the A319 ACJ and theoretically could be fitted to a pax frame. So gear length is not a huge deal
Max Q
Tue Jun 29, 2021 4:53 am
None of these threads are mandatory reading
yeelep
Wed Jun 30, 2021 5:06 pm
That's exactly what they did. The NG main gear is located 24.5cm outboard relative to the earlier models.
CDGIAD
Wed Jun 30, 2021 10:04 pm
So the NG is higher vs the ground than the classic?
Interesting.
Still nowhere near enough to accommodate the Max engines.
FriscoHeavy
Wed Jun 30, 2021 10:37 pm
Interesting.
Why would the NG need the MAX engines?
The MAX accommodates the MAX engines, so there is no issue there.
CDGIAD
Thu Jul 01, 2021 7:42 am
FriscoHeavy wrote:
Interesting.
Of course the NG doesn't need the Max engines.
I just wondered if the landing gear modification was only implemented for the Max, as even for the NG, especially the 739 we heard it was too low already.
FriscoHeavy
Thu Jul 01, 2021 5:13 pm
CDGIAD wrote:
FriscoHeavy wrote:
Interesting.
The gear being too low is very subjective. Does it need more runway than say an A321? Sure. However, to say it's too low isn't an accurate statement as most major airports can handle it without issue and the 737-900ER can fly transcontinental flights without issue.
CDGIAD
Tue Jul 06, 2021 5:33 pm
I'm not saying the 739 is an inefficient airplane, simply that it's often mentioned it must take off at a rather shallow angle to avoid a tail strike.
Also during deboarding I've read a couple of times it's tail heavy and passengers seated at the back must deplane first.
Esthetically aircrafts too high vs the ground like the 757 or A350 don't really appeal to me ;-)
Users browsing this forum: CosmicCruiser, Lukas757, N965UW and 16 guests
